Performance exhaust
The key for the OP was his question, should he not buy a car because it didn't have it. No problem he can buy an aftermarket system that IMO is somewhat better.
That said, price out an aftermarket exhaust then add it to the price of the car to see if the car is still a great deal.
I did just that when I found a real nice new '16 Convertible with all the right stuff and price, but lacked the NPP option. I had a Borla ATAK axleback installed on it and problem solved. $1250 and had it installed for $130.
Being able to switch from quite to load seems perfect. Clearly NPP on loud mode is much louder than standard non NPP exhaust but would want to know if NNP on quite mode is as quite or quieter than the standard non NNP exhaust?Thank you
I had NPP on my last two Camaros but I always wound up pulling the fuse since I didn't really like the way it sounded when the NPP valves would close. To make matters worse, the Camaro NPP valves would rattle, which was really annoying.
One of the best things about owning a performance car is changing things about it and then feeling the difference it makes.
the most fun I ever had with any mod was a cut-out on the stock exhaust. You get a quiet cruiser that never makes a peep, and with the flick of a switch becomes a fire breathing dragon.
Would be less expensive is to have a muffler shop install a cut-out kit, shown below, than an aftermarket muffler. Only ~$120 on eBay. Reminds me of what we did "in-the-day" using a choke cable to operate! These operate with a supplied remote electrical switch!Would have to weld into the exhaust pipe before the muffler.
~$120 on eBay.
~$120 on eBay.
Remember you would be cutting into the OEM exhaust system you planned to "throw away anyways" so there is no loss.
-I won a cutout from ebay for $30 shipped once.
You can have it quiet or loud with the turn of the dial and no droning - I think it is much improved over the C6 system in that regard.
I would keep looking or just order one to get exactly what you want with no regrets.
Good luck & Happy New Year!
In my case I back the car into the garage each night, have some baffling in the back of the garage, start the car each morning and idle until the cold start goes away BEFORE I open the garage door!!!
Yes it is wake up the neighbor loud... I temper that with coasting down the driveway throwing it into 4th and idling out of the hood.
I think all my neighbors like me....... one who is a car guy asked me to leave on at a regular time.......... as he loves to hear me idle out as he used that as his alarm.
Now that I leave in single digits....... yea it's audible!!!!
UMP...... as other have suggested search the forum for the cutoff option. There are folks cutting off their stock mufflers and running without mufflers and Corsa even sells a kit for the tips. The Cats keep the car reasonably quiet.
https://www.corvetteforum.com/forums...st-review.html
What I HATE about stock NPP is your car sounds like all the other NPP cars..... it more of a truck sound and there is a tinge of droan, yes there is!!! And it cuts out at certain RPMs unless you override the sound management system, but then it is wide open all the time.
Even with my corsa extreme I can control it with my right foot.
The NPP is a nice factory exhaust option for sure but I think the real question is whether you should pass on a car that has everything else you want but the NPP option.
Something to consider before passing on the car.
1. You can easily add an aftermarket setup. Borla, Corsa, BBE, etc. all have nice setups that look to improve the exhaust note. Keep in mind, like most parts on a car GM doesn't make the NPP mufflers, I believe it is a company called Walker or Dynomax.
2. As mentioned earlier in the thread, some folks save the big cost and do a muffler delete. Cut the pipes and have a muffler shop weld on some 4" tips. The 4 cats in the factory exhaust keep the sound level reasonable.
3. Most owners with NPP like how it sounds when the valves are open, which is why it is so common to see folks pulling the NPP fuse. I found it annoying when the valves would open and close on their own based on the drive mode you are in. Even if you hard code the exhaust to Track mode the valves still close at certain rpms and speeds. I find it more fun controlling the exhaust with the gas pedal.
