2019 Navigation Update
Old Aug 9, 2018 | 01:55 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Default 2019 Navigation Update
Yes, this topic has been covered in other threads but I just got my update and the "RULES" have changed as to the process the update.
I quote the first line of the instructions:
DO NOT drive your vehicle during the update installation. To insure success, it is highly recommended that your vehicle remain running and in PARK during the entire installation.
Most of us have shoved in the thumbdrive and then went driving while the update took place. Whelp, the "DO NOT" in caps seems to say different.
The rest of the rules:
Park your vehicle in a safe, well ventilated place outside. Otherwise, you risk carbon monoxide poisoning.
DO NOT attempt to install this update in "Accessory Power Mode"
If you have any other USB devices connected, remove it before beginning these instructions.
Special Notes:
The map update process takes approximately 50 minutes. The progress bar may move slowly or remain on a percentage for several minutes. This is normal.
Updating the Map:
  1. Insert the USB device into any available USB slot in the infotainment system or center console
  2. The navigation system will recognize the USB as a map update and ask whether you would like to update. Select "Update". The display will inform you that the navigation and weather will be available during the update ( I thought you shouldn't drive?)
  3. Select "Continue". The system will begin updating.
  4. When loading is complete, you will see a screen that indicates "Update Complete". Select "Dismiss". The system will restart. When the restart is complete, you may remove the USB and use the navigation and weather functions.
So, the rules are you can't drive the car and it sits there idling for 50 minutes while the map update happens. That kinda sucks.
Elmer
Old Aug 9, 2018 | 02:06 PM
Vet Interested's Avatar
Vet Interested
That is different to say the least!
Old Aug 9, 2018 | 02:12 PM
Kracka's Avatar
Kracka
Thank you for posting. I did the V2017 update on my 2014 and plan to either grab this V2019 or wait until the V2020.
Old Aug 9, 2018 | 02:14 PM
Keefer07's Avatar
Keefer07
The printed instructions say do not drive. Once you start the update, the screen says vehicle may be driven.
Old Aug 9, 2018 | 02:15 PM
Kracka's Avatar
Kracka
WHOA it's on sale for only $99, I'll bite, going to order it today!
http://gmnavdisc.navigation.com/
Old Aug 9, 2018 | 02:19 PM
eboggs_jkvl
Moderator emeritus
Surely this doesn't confuse anyone? Does it? It must be some of the "Settled Science" stuff.
Elmer
Old Aug 9, 2018 | 10:12 PM
BELVIN20's Avatar
BELVIN20
Cannot believe that shipping is $29.95, what at rip off, so much for a huge savings.
Old Aug 9, 2018 | 10:37 PM
Keefer07's Avatar
Keefer07
Ordered mine on 8/1 and it came in on 8/8, shipping was $3.95.
Kracka's Avatar
Kracka
I paid $3.95 S&H today. Total price including tax was $112.52
Old Aug 10, 2018 | 02:09 AM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
So does this new edition begin to approach Google goodness? Or does it just update new streets and freeways?
Old Aug 10, 2018 | 02:47 AM
Judgment Day's Avatar
Judgment Day
Hmm...I might pull the trigger on this so I can get my hands on the update before Labor Day weekend hits.
Old Aug 10, 2018 | 08:48 AM
eboggs_jkvl
Moderator emeritus
Only if you live in Canada! Are you sure? Mine was $3.95 to Florida.
Elmer
Old Aug 10, 2018 | 08:52 AM
raylo's Avatar
raylo
Yup, $3.95 shipping in USA. I ordered mine a few days ago after reading the post about the sale. The onboard nav is mostly superfluous these days if you have a phone but there are times when it is convenient to use. Worth it for $99.
Old Aug 10, 2018 | 09:23 AM
spinkick's Avatar
spinkick
It's not a software feature update, just current map data.
Old Aug 10, 2018 | 09:50 AM
Kracka's Avatar
Kracka
I like it for not only all the new streets around here (tons of construction on the highways and new neighborhoods being built) but also for the updated gas stations which come in handy on roadtrips and car cruises (which I happen to have coming up in two weeks).
Old Aug 10, 2018 | 12:43 PM
Null Pointer's Avatar
Null Pointer
Exception ID 10T
Elmer
Thanks Elmer. I ordered mine Monday this week, and it still hasn't shipped. How long did yours take? Shipping to Florida was $3.95 for me. To those seeing 29.95 for shipping, make sure you are not on the Canadian ordering site.
Old Aug 10, 2018 | 01:09 PM
Keefer07's Avatar
Keefer07
Mine was delivered to Oklahoma in a week.
I was planning on driving it around while it updated but the instructions said not to. After I started the update the message on the screen said I could continue to drive while the system was updating.
I was at work so I just left it running. At about an hour the progress bar was at 100% and the car shut off. I don't know if it shut off because the update was done or if it was the car had been running without the FOB inside.
After I started it back up, I got a message that a file was missing. Looking back at the instructions, I noticed it said to ignore the message. Everything seems to be working fine.
To 2019 Navigation Update
Old Aug 10, 2018 | 01:25 PM
Bill Dearborn's Avatar
Bill Dearborn
Haven't ordered the Corvette update yet but the update for my Terrain says to leave the car in Park with the engine running for the first 10 or 15 minutes. The update is a two step process where the first step is called Update Radio Software which takes 10 to 15 minutes. Once that is done the screen shows Start Software Update and that is when you can drive the car if you want. Once the message appears you push Continue on the screen. The instructions just say not to start or turn off the engine during that part of the update which will take 25-35 minutes. Don't know if the Corvette Instructions are different but the update manual seems to be fairly standardized.
Bill
Old Aug 10, 2018 | 01:38 PM
markei's Avatar
markei
Paid the same yesterday
Old Aug 10, 2018 | 01:42 PM
raylo's Avatar
raylo
This helps a bit. I was having trouble understanding why a map update which should be no more than a file copy operation from the thumb drive should be such a PITA. It sounds like the car is updating firmware and perhaps retrieving some or all of the map data via the onboard 4G. If you were to be driving around at a critical point and lost 4G cell connection it might fail... or just perhaps take extra time. The thumb drive is probably just used to mediate the transaction for the particular VIN.
Bill
