Dewayne, before you go to deep check the air pressure in the tires. If they are at 35 psi cold that is part of the problem. I set mine at 30 psi, and now you can't feel every little rock, or imperfection in the road. Maybe that will help.
Check out the Ask Tadge thread about PTM modes...small screenshot below
Awesome info thanks
Surprised to see PTM Dry uses Sport - I just assumed once you went into Track that the steering and mag-ride were in Track and only the TC and eLSD were effected.
You can set the steering to stay in the mode you like- Tour, Sport or Track.
In other words, my steering effort stays in Sport regardless of what mode I select on the little ****.
I presume that will also keep it in your manually-selected mode when using PTN?
Mine's slumbering on the tender right now, so I can't check for myself.
I have a 2015 stingray and it road not so well and noisy , I didn't like the Super Sport tires (Run Flats) I bought the non run flat AS 3+ what difference it made , quieter and softer ride, traction is better also , way better.
I'd try dropping the tire pressure some more, just due to the size of the tires. 325 vs stock 285, that's over 1.5" wider. Stock fronts are 245 (you never said what your fronts were, just that they were wider).
But, I still think that the wider wheels & tires are probably quite a bit heavier than the stockers, and the suspension is designed with the stock wheel/tire weights in mind. Not to mention the wider footprint provides more opportunity to find road bumps and dips, etc.
So, IMO, either you're going to learn to live with the NVH, or go back to stock wheels/tires, OR (thinking out loud) spend some really serious coinage to get high quality lightweight wheels.
Didn't realize you were running 20 inchers up front. That's a REALLY low profile tire for a street car! As far as width goes, it's 20mm, not as far out as your rears.
I didn't know there were 20's up front til now too. You think this car was mainly at the track? would that be the benefit going that way for the fronts.
Not trying to be a SA......but define what Ride Quality means to you and adjust to it.
Stiffer sidewalls usually equals rougher ride and with any tires,you can play with the AP some.Try going down in 1/2 lb increments and see if that helps.
If anything you want smaller wheels at the track. Dropping down to an 18 / 19 combination for example. Sure wide tires are great for additional grip, but not at the expense of more weight. I assumed they were heavy before but having 20" up front confirms this.
I never said it was hidden. I stated what the video was labeled and what it said. Not everyone may know of it or take the time to look it up. Especially a new owner like the op. But you're that guy that has to say something huh.
The MSRC settings in PTM modes are exactly the same as they are in regular Tour, Sport, and Track modes. The PTM modes are also about much more than MSRC settings, and influence throttle mapping, steering boost, stability and traction control, as well as eDiff settings.
PTM Wet = Tour MSRC setting
PTM Dry = Sport MSRC setting
PTM Sport 1, 2, and Race = Track MSRC setting
OP,
Bigger low profile tires, coupled with cold temps on summer max performance tires mean a very rough ride. The PSS rubber compounds are rock hard below 40ºF and have very little grip to boot. Even when hot, it's going to be a rougher ride on an imperfect surface the lower profile you run.
OK, can't hush, gotta add something. Since the tires are sticking out like that could they have spacers behind the wheels? I wonder if that helps in making it ride like a 2 horse wagon?
lol... yeah. when my back heals up Im gonna take the wheels off and see if there are spacers on it or not.
I think the front and rear rims were ordered by previous owner with incorrect offsets....or the previous owner liked the rims so much that owner got the best/closest offset for the style of wheel offered and knew that they would need spacers for caliper clearance. Regardless, I would first make sure the suspension is returned to stock if it is not stock already, and then sell the current rims and tires and purchase 19 inch front and 20 inch rear rims in the correct sizes and offsets so that the tires tuck in the fenders and will not scrape or bottom out while driving it normally.
I like this solution but I don't think OP can just go back to stock. Assuming the wide body kit are GS parts then he could go with GS spec wheels&tires, or at least start with those sizes and work from there. Problem is $$$$, though.
Dewayne, you've had a good attitude about all this; I appreciate that. Not defensive, just want to find the problem. You've got good suggestions & observations, hopefully they'll get you on the right track.
