Cup holder problem solution!!!!!
Old Jun 30, 2019 | 02:53 PM
  #41
Boxcar's Avatar
Boxcar
Life Starts at 120 mph
NCM Lifetime Member
Just ordered mine...or should I say for the Wife.
Old Jun 30, 2019 | 03:30 PM
  #42
imaposer's Avatar
imaposer
Brought the car home yesterday, ordered today. One drive with the top down was enough.
Old Jun 30, 2019 | 06:57 PM
  #43
dbritey's Avatar
dbritey
Just received mine today. Took car for a ride with cup of coffee today . AWESOME !!!! No more holding my coffee or water bottles. A must have for any C7 owner.
Old Jun 30, 2019 | 08:06 PM
  #44
AeroJim's Avatar
AeroJim
St. Jude Donor '08-'09
Will it void the warranty?
Old Jul 1, 2019 | 01:02 AM
  #45
blackedgs's Avatar
blackedgs
I bought and installed the stop flop. First time I tried to use it I purchased a bottle of Mountain Dew. Mind you, I don’t drink the dew often but i wanted one anyways. The bottle wasn’t even close to fitting. The bottom barely fit at the top of the stop flop. Also, I installed it correctly but the lid bumps part of the stop flop and it rubs every time I close the lid. I’m uncertain as to if I will keep it in the car. I think I expected more from it for the cost of 47 dollars. Unless what ever your drinking has a narrow base, the drink won’t fit! Just my 2 cents.
Old Jul 1, 2019 | 09:51 AM
  #46
Stop Flop's Avatar
Stop Flop
Supporting Vendor
Hi, if the lid is bumping the cup holder then its not centered.. If its centered then theres almost 1/4 inch room on each side.
Old Jul 6, 2019 | 07:53 PM
  #47
Stop Flop's Avatar
Stop Flop
Supporting Vendor
FYI, just the injection molds cost $9000 never mind development and inventory. also there is some value to the design! No one else attempted to make these!
dave
Old Aug 2, 2019 | 11:38 AM
  #48
Boxcar's Avatar
Boxcar
NCM Lifetime Member
Received it, and what a great addition to the traveling comforts. Took it inside and found two insulated travel cups that fit nice and snug. I did have to use a piece of sturdy foam to stabilize it in the OEM Opening. Great product, highly recommend it.
Acknowledgement: I had to use the foam by my choice. I did not want to use the provided sticky Velcro on the bottom, other wise I'm sure it would remain in place. I stand by my recommendation that Stop Flop is a great product and I would buy this product again.
Old Aug 2, 2019 | 12:05 PM
  #49
Stop Flop's Avatar
Stop Flop
Supporting Vendor
Hi and thanks for the feed back. Just courious why you needed to stabilize it? What area?
dave
Old Aug 12, 2019 | 10:52 AM
  #50
Stop Flop's Avatar
Stop Flop
Supporting Vendor
Please note that its really not sutible for the insulated yeti mug.
Old Aug 26, 2019 | 11:26 AM
  #51
Stop Flop's Avatar
Stop Flop
Supporting Vendor
bump
Old Oct 18, 2019 | 12:49 PM
  #52
Boxcar's Avatar
Boxcar
NCM Lifetime Member
When you place it in the OEM console cup holder hole, it slides (moves) around. I simply used a stiff piece of packing foam to hold it in place. Maybe I'll get a pic for ya.
Old Oct 18, 2019 | 03:58 PM
  #53
Stop Flop's Avatar
Stop Flop
Supporting Vendor
Hi, dave here. its not supposed to move around as has velco on the bottom to attach it. Are you using the velcro?
Old Oct 23, 2019 | 02:48 PM
  #54
silver19's Avatar
silver19
I bought this product a couple of weeks and ago and would call it an overall decent product. The install worked perfectly, but when I raise it up it won't lock into place. Every time I put a cup in it I have to hold the sleeves up. Also doesn't fit the 32oz stainless steel cups.
Old Oct 23, 2019 | 03:16 PM
  #55
Stop Flop's Avatar
Stop Flop
Supporting Vendor
Hi, did you raise each cup up until you feel a pop before installing as that lets you know they are now in the locked position and more important, how much pressure to use after its installed. There are 3 small raised nubs inside the first 2 cups, these are the locking tabs.Since this part of the mold is small it might take a bit of pressure to lock them but the more you lock it the easier it will lock.Let me know and if your still having difficulity i will send you a new one that more easy to lock.
dave
Old Oct 24, 2019 | 07:12 AM
  #56
Boxcar's Avatar
Boxcar
NCM Lifetime Member
Stop Flop Bump to the top.
After speaking with Dave of Stop Flop I wanted to post a follow up to my previous "update post 120 & 144". I posted that I had to use a piece of foam to keep it in place. That is because I chose not to use the Velcro sticky bottoms that are provided with the product.
Acknowledgement: I had to use the foam by my choice, other wise I'm sure it would remain in place. I stand by my recommendation that Stop Flop is a great product and I would buy this product again. If you own a C7, this is a must have product.
I wish Dave and the Stop Flop team continued success.
Old Oct 24, 2019 | 03:50 PM
  #57
silver19's Avatar
silver19
dave
Dave,
Thanks for the reply. I went out to the car and checked the cup holder. I don't see any nubs. Like I said in my post, the installation went perfectly, but when I raise the cup holder to the full position, it will mostly stick in the up position, but definitely doesn't lock. If I put in a large cup it will sometimes collapse, but other times remain up.
To Cup holder problem solution!!!!!
Old Oct 24, 2019 | 04:01 PM
  #58
Stop Flop's Avatar
Stop Flop
Supporting Vendor
Send me your address in the private message and i will send you a new one no problem.
dave
Old Oct 24, 2019 | 06:55 PM
  #59
*GrandSport*'s Avatar
*GrandSport*
I have one it’s a very useful product. Works great.
Old Nov 1, 2019 | 05:49 PM
  #60
millpond's Avatar
millpond
Ordered from Amazon on Monday, installed today. My travel cup fits nice and snug.
