Navtool.......OK
Old Mar 4, 2020 | 08:45 PM
I got your ZO6's Avatar
I got your ZO6
My 3.0 unit is in the mail. Anyone have a video on the install? I've read the threads but still a video would be very helpful
Old Mar 4, 2020 | 09:00 PM
Midgetracer31's Avatar
Midgetracer31
No video needed its simple follow Elmers pics and look at my post above to see how the newer unit plugs in, Carplay has a few items onscreen and phone settings to clearly make it work that NavTool does not discuss at all.
Old Mar 4, 2020 | 09:55 PM
Tinkertech's Avatar
Tinkertech
I believe my small 4 pin black connector has 4 wires in it instead of 3 but I believe its the same one. (This is the connector that is at the end of the coiled up wire harness with the grey connectors that appears to go to the radio module).
Old Mar 4, 2020 | 09:58 PM
Tinkertech's Avatar
Tinkertech
Originally Posted by Kansasz06
I got the same camera Elmer used.
Which one the first (PYLE) or second one he purchased?
Old Mar 4, 2020 | 10:07 PM
Tinkertech's Avatar
Tinkertech
Thanks Midgettracer31
Now I think I understand where every connector goes.
I can't believe after all my years in electronics that this unit is so difficult. Actually after a lot of advice and past experience from those that did it, the unit isn't all that hard to understand. Thats why I find it hard Navtool does not have a really detailed install guide.
I'm sure Elmer would have a few things to say on how 'easy' it is!
If only they had a simple and correct diagram, just imagine...........
Old Mar 4, 2020 | 10:09 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
The Pyle is quite adequate. The second one I purchased is awesome. It allows me to select from 3 views. Straight forward, split looking out at 45° and the best thing ever is STRAIGHT down. I look down at the tip of my splitter from the top and it gives you the look to stop within inches of contact! Friggen Awesome! I highly recommend it over the Pyle but the Pyle will work.
I had to braille the installation. Navtool wasn't much help then and apparently not now.
Elmer
Old Mar 4, 2020 | 10:14 PM
Tinkertech's Avatar
Tinkertech
One last question Midgetracer31,
Did you connect the 2 black flat 24 pin connectors together, one from the Navtool main cable the other from the screen module cable?
Old Mar 4, 2020 | 10:19 PM
Tinkertech's Avatar
Tinkertech
Elmer
Thanks Elmer,
I looked up your second camera on Amazon and its no longer available at this time. I guess i'll go with the Pyle.
Everyone should get together and write a manual and charge Navtool royalties!
Old Mar 4, 2020 | 10:27 PM
Tinkertech's Avatar
Tinkertech
Migetracer31,
I'm going to program my unit tomorrow after I look up the correct setting that were noted in past threads.
Old Mar 5, 2020 | 08:04 AM
Midgetracer31
yes the flat black connector coming from radio module and screen module harness's plugs into the black flat connector from the NavTool module.
Old Mar 5, 2020 | 12:59 PM
Tinkertech's Avatar
Tinkertech
Thank you very much, just never can be too sure with this system.
Old Mar 5, 2020 | 07:56 PM
Kansasz06's Avatar
Kansasz06
I am having a HORRIBLE time getting the white connector unplugged from the back side of the BCM. Is there any kind of clip or lock that keeps it from coming apart. I’m frustrated as hell with this thing. Some advice would be very much appreciated.
Thanks in advance.
Roger
Old Mar 5, 2020 | 08:49 PM
  #33
eboggs_jkvl
Moderator emeritus
It does have a squeeze lock. Look at the 2 grey plugs that came with the kit and you might get a clue how the plug releases. I took off the BCM from on top of the radio unit and had a straight shot at the grey plug.
Elmer
Old Mar 5, 2020 | 09:27 PM
  #34
Kansasz06's Avatar
Kansasz06
Thanks Elmer. I don’t know what I’d do without this forum:-)
Old Mar 6, 2020 | 02:54 PM
  #35
Tinkertech's Avatar
Tinkertech
Did anyone disconnect their battery when they installed their Navtool?
Old Mar 6, 2020 | 03:21 PM
  #36
eboggs_jkvl
Moderator emeritus
Nope, not me. BUT! I'm pretty dumb and work on live 110 in the house. 220 and power gets cut.
Elmer
Old Mar 6, 2020 | 03:47 PM
  #37
Midgetracer31
I did not unhook my either
To Navtool.......OK
Old Mar 7, 2020 | 06:32 AM
  #38
Tinkertech's Avatar
Tinkertech
Kansasz06 hows the install coming? Hope you finally got the radio connector loose, follow Elmers advice..
I'm still waiting for my camera from Amazon before starting.
John
Old Mar 7, 2020 | 10:11 AM
  #39
Midgetracer31
Roger did you take the alum shield loose from the floor, then you can slightly pull up on the BCM and reach behind and pull the radio module out from behind and get to the connector easily
Old Mar 7, 2020 | 04:14 PM
  #40
Kansasz06's Avatar
Kansasz06
Ok, I still need a little help:-(. I got this monster installed. The problem I have is this. When I put it in reverse the screen goes balck(no signal). When I put it in drive the rear camera shows up on the screen. I f I switch the front camera video feed to the rear camera input cable the front camera comes on in reverse and the rear camera comes on when shifting to drive. What have I got crossed up?
