I installed a set of the side marker lights as well as the rear reflectors on my 2O14 last week and the only time I had it out for a drive the TPS warning appeared. Love the look of the lights and have ordered some of the chokes to install - probably next week. Hopefully that solves the problem. If no, Jhonathan has said returns accepted for up to 99 days.
Unfortunately, very few are responding to the poll. It appears essentially only those with a problem have seen/responded to it. These numbers are low in comparison to the number of units sold given the number of group buys.
The poll specifically mentions the JW product. I purchased from RPI and experience the same problem intermittently. 2017 Z06/Z07
I’m happy to participate in the poll but I didn’t want to “contaminate” the results with a non JW product.
That being said, from the photos on both sites and pricing, they might be sourced from the same manufacturer?
what does everyone here say? Same source? Same product?
OK, I know some snot is going to be snarky again but I changed the poll to read "Non Oracle" side lights. I didn't know that there was a plethora of vendors putting the same kind of light out in the world.
I have a 2015 Z51 Stingray that would get the TPS warning. I installed two "chokes" on the Drivers side rear light.
One that fit over the two wires right before the plug and one that fit snug over the wire harness about a 1/2" back.
I took a 50 minute ride on the highway and no TPS warning the pressures on all the tires updated.
That is good news ! I have not yet been able to drive my '19 GS after I installed the lights as yet. there are some things that have to be addressed first and foremost.
Once again I appreciate all of this legwork to make this happen.
Rich
Vette Ski First drive your car with the lights on and see if you have the TPS warning problem.
If you do try the "chokes" on the left rear drivers side. You need to do a 20-25 minute drive at
highway speeds.
highway speeds.
Marty
Marty,
Thank you, will be busy here on the farm for a 'lil bit.
Rich
Update on the LED side marker install on my '14. Got the service TPS message and ordered the ferrite chokes to see if that cured the problem. Over the past couple of days, got the chokes installed on all four corners. Put two chokes on each wiring harness. Took the car out for a drive today with the lights on and thankfully the chokes seem to have cured the problem. Lights look great BTW.
