The Corvette from hell [continued]
Old Jul 9, 2020 | 06:28 PM
  #61
Kevin A Jones's Avatar
Kevin A Jones
Originally Posted by arbitrator
Now I smell gasoline around the car. Would that be normal?
Considering the work described on your work order I'm not surprised it smells like gas, smell will probably go away by tomorrow.
So all looks good, they didn't damage anything?
Old Jul 10, 2020 | 06:44 AM
  #62
cowboy casey's Avatar
cowboy casey
watch over the weekend and on Monday if it still smells like gas get it checked out again...
Old Jul 10, 2020 | 07:16 AM
  #63
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Something doesn't sound right about the initial diagnosis at the dealer.
Old Jul 10, 2020 | 08:18 AM
  #64
dave_2012_tt's Avatar
dave_2012_tt
I have the fuel up issue on my C7. Every fuel station I went to had an issue. Two things I have found so far...
If you get fuel at halfway mark or before no issue
Go to a Costco and any fuel level and no issue. Tried to different Costco in two different states.
Old Jul 10, 2020 | 11:45 AM
  #65
arbitrator's Avatar
arbitrator
I took it back today, they looked it over and believe it was residual odor from dropping the tank etc. I agree. Nothing appears damaged. Thank you all for sharing your knowledge.
Old Jul 11, 2020 | 03:02 PM
  #66
arbitrator's Avatar
arbitrator
Default Vette from hell - continued
Took a little ride with the wife last evening, every thing is rosy in our brand new Corvette. Got up early this morning and fueled it at Quick Trip. I ran the pump on the medium flow setting and it filled all the way up before the pump shut off. Did not "top it off". Brought it home and left it in the driveway. About 1 pm I started it up to sync the sat radio. It was running between 10 and 15 minutes. I decided to pull it in the garage to let it cool off before washing it later after the afternoon sun was gone. Noticed at least a pint of some kind of oil on driveway, can't really say whether its from engine or elsewhere. Go in the house to show wife the oil on paper towel. Go back to garage, see fluid running to the port side on floor. Smells like gasoline. Look under car, can see steady drip drip drip hitting floor. Quick panic on risk mitigation, decide car has to get out of garage. Didn't know how to get in neutral without starting, so started it, backed out, and left in position for flatbed to rescue it.
Back to see the dealer Monday, to be continued, same Bat time, same Bat channel.
Old Jul 11, 2020 | 03:23 PM
  #67
62RPO582's Avatar
62RPO582
For future reference...…………………
https://www.corvetteforum.com/forums...sh-new-c7.html
Old Jul 11, 2020 | 03:26 PM
  #68
TxLefty's Avatar
TxLefty
Sounds like they left something loose or damaged something. They will eventually get it figured out and repaired correctly. Thus far, knock on wood, I've had very good luck with my local Chevy dealership. The only issue I've had was that the tech doing the alignments on my C6 didn't tighten the suspension adjusters tightly enough and that ended up being a problem as I had to have it realigned (half day+ lost) while leading a club road trip. If you can see it dripping, it should be easy to diagnose.
Old Jul 11, 2020 | 03:28 PM
  #69
Kevin A Jones
As your C7 was idling between 10>15 minutes was there any condensation dripping to the floor from above? Should have been.
Old Jul 11, 2020 | 03:49 PM
  #70
Steve Garrett's Avatar
Steve Garrett
CORVETTE TODAY Show Host
CORVETTE TODAY Host
St. Jude Donor'15
OP, your 2 threads have been merged together. If you have updates, post them here. If you would like your thread's title updated, just let a Moderator know.
Old Jul 11, 2020 | 05:09 PM
  #71
MMD's Avatar
MMD
Condensation???...
Old Jul 11, 2020 | 06:42 PM
  #72
arbitrator's Avatar
arbitrator
Thank you
There was condensation on the garage floor but I'm embarrassed to say I don't specifically remember seeing any on the driveway.
Last edited by Steve Garrett; Jul 12, 2020 at 09:05 PM. Reason: Merged Posts-Please use the Multi-Quote button to bundle responses in one reply!
Old Jul 12, 2020 | 10:13 AM
  #73
Bigredwing's Avatar
Bigredwing
So sorry and very disappointing. Hopefully this is something simple and you'll be trouble free after this repair.
Old Jul 12, 2020 | 10:20 AM
  #74
Kevin A Jones
Originally Posted by MMD
Condensation???...
Yes, from the air condition system. What you have the only C7 that doesn't drip?
Old Jul 12, 2020 | 10:27 AM
  #75
Kevin A Jones
I was just wondering if that may be what appeared to be leaking from above as it can sometimes be a little oily.
Old Jul 13, 2020 | 07:09 AM
  #76
Xavierbank's Avatar
Xavierbank
WoW this car has more problems.... maybe he needs to take it back
Old Jul 17, 2020 | 10:36 AM
  #77
arbitrator's Avatar
arbitrator
UPDATE
Dealer reports that the tech was reassembling crossover pipe and could not get it to fit up. He consulted tech support and ascertained that the tank [not sure which one] is missing the sealing surface. New tank will not ship from Flint for 2-3 weeks. Observations based on today's "facts":
1. vehicle left factory with defective fuel tank.
2. fuel level sensor failed shortly after delivery to me, resulting in the CEL
3. I ran it out of gas because of combo of no gauge and leakage
4. first trip to dealer for repairs failed to detect defective fuel tank.
5. I took it back after first repair due gas odor, they said it wasn't leaking. So it was the THIRD trip to dealer before it detected defective fuel tank.
6. what I thought was oil on driveway was result of gas dissolving asphalt
Old Jul 17, 2020 | 10:47 AM
  #78
kennyjames21's Avatar
kennyjames21
UPDATE
I think you need to find a better dealer/service department.
Old Jul 17, 2020 | 10:53 AM
  #79
MMD's Avatar
MMD
UPDATE
Guess it was just gas condensation like someone said. .
