I would be interested to know what parameters are measured or analyzed to determine a "perfect" engine. Are "less than perfect" engines then corrected, or are they installed in cars?
Are you sure you are looking in the right place ? ALL M7 2019 GS should have one.
I've had much of this motor apart, and the intake manifold off... I no gots...
Edit:
Not to overly flood this one with pics, but I removed the valve cover trim pieces too just to show a little deeper pic. I'd love for this one to have a plaque too, but I'm pretty sure it does not.
This is a 2019 GS M7, but like I said before it is an early one (was built 6/2018). It's also one of the few Admiral Blue 2019's (they switched quickly after). I am guessing that I was early enough in the build that they put that last motors they had laying around into the early 2019 cars before making the switch. No big deal, I plan on running this one as the same way with or without the plaque!
Edit:
Driver's side:
Passenger side:
Sticker (2019 GS M7)
Wouldn’t worry about it, engine is built to the same specs regardless of PCB or not. The engine must be a good one otherwise they would have installed in a Camaro, at least according to a certain member who shall remain nameless
Edit:
Driver's side:
Passenger side:
It will remain a mystery. It would only be on the drivers side front under fuel rail.
I’ll be adding $5,000 to the value of my car due to it being rare now!
