Removing fish
Old Jun 5, 2021 | 09:34 PM
johnfin's Avatar
johnfin
Default Removing fish
Any of you guys removed the fish? Was wondering if it could mess up the clear coat. Fishing like to remove, right?
Old Jun 5, 2021 | 09:38 PM
vbb's Avatar
vbb
Ok, I'll bite.
Are you talking about the stingray emblem on the side of the car? If so, it removes easily with some heat and some fishing line (someone stop me) or dental floss without damaging the clear coat.
Old Jun 5, 2021 | 09:46 PM
johnfin's Avatar
johnfin
Yes stingray on side of fender
Old Jun 5, 2021 | 09:55 PM
Elk's Avatar
Elk
Curious, why remove the ray? It is a neat emblem.
My Z06 of course does not come with the ray, but I enjoy seeing them on other cars. It is distinctive.
Old Jun 5, 2021 | 10:17 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
They’ll come off, any good bodyshop can remove them for ya for an hours labor around here thats 50 bucks if you’re nervous about it.
Old Jun 5, 2021 | 10:53 PM
Easy to remove without damaging the paint/clearcoat as mentioned above. Your choice to do it or not, but I too like the look of the emblem on the car.
Old Jun 6, 2021 | 12:27 AM
Skid Row Joe's Avatar
Skid Row Joe
Fishing line. Yes, fishing line eased under, then rip gently with up and down sliding action while pulling it through. Gently!
I'm into modifying a new Mercedes-Benz van's unwanted exterior accessories, and rustproofing the areas, and fishing line is what you need. Been You Tubing Owl Vans in California, that's where I learned it.
Personally, I like the Fish.......
Old Jun 6, 2021 | 06:32 AM
449er's Avatar
449er
CF Community Team
Take some heavier fishing line and work it behind the emblem in a sawing motion....the line will cut through the adhesive without damaging the paint
Old Jun 6, 2021 | 07:23 AM
NashvilleGrandSport's Avatar
NashvilleGrandSport
And get some 3M Adhesive Remover for any residual adhesive left after removal.
Old Jun 6, 2021 | 07:55 AM
Red08's Avatar
Red08
I was wondering the same thing. What's wrong with it?
Old Jun 6, 2021 | 09:19 AM
WPGZ06's Avatar
WPGZ06
Little heat and fishing line, and then any product that removes residue. Sometimes you can just heat up the residue and roll it off with your fingers.
Old Jun 6, 2021 | 09:24 AM
Maxpowers's Avatar
Maxpowers
I used heat and a plastic pry tool. Goo gones works well to get rid of the adhesive.
Old Jun 6, 2021 | 09:58 AM
Vette Ski's Avatar
Vette Ski
Slow and easy heat from a heat gun or hair dryer, dental floss, remove fish, prep sol or alcohol and "very soft cloth " or alcohol pads to remove goo, then wax . Slow and easy !! SIMPLE and EASY !!
Rich
Old Jun 6, 2021 | 10:18 AM
Bird67's Avatar
Bird67
Make sure you get your fishing license in advance, and keep it in your glove box. You don’t want to get pulled over by marine patrol. The fishing line to use is Spectra Pro Braided in a 15# test, color-matched to your paint for best results. Once you get started and hook up, go easy. Be patient and let it come to you.
Also, you should decide in a advance whether you’ll catch-and-release or keep. Some people actually mount them.
Tight lines!
Old Jun 6, 2021 | 10:31 AM
golden2husky's Avatar
golden2husky
I removed mine - just didn't like them - I used dental floss to cut through the foam adhesive, starting at the tail. The residue was removed with citrus goo-be-gone. Each side took about 15 minutes. Zero sign that they were ever there. I kept them so when I sell the car, they next owner can restore the look to factory if they want to.
Don't be afraid to DIY - this is a cakewalk.
Old Jun 6, 2021 | 11:14 AM
hotrod03's Avatar
hotrod03
IF you don’t want I want it. I’ll take it off your hands!!!! Let me know!!
Old Jun 6, 2021 | 11:21 AM
Vette Ski's Avatar
Vette Ski
I just knew it would get to this, Fishing license, OMG !!!
Rich
To Removing fish
Old Jun 6, 2021 | 11:22 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
I would suggest the GM blacked out ones for your ride OEM NEW Fender Emblem Badge Stingray Carbon Flash Black 15-19 Corvette 23183706
https://www.ebay.com/itm/19188134970...YAAOSwoPRanvEO
You can also get the blacked out emblems for all of them on your C7 go look around
Old Jun 6, 2021 | 11:41 AM
Elk's Avatar
Elk
Do only the base cars have the stingray and is this why people remove them?
My experience is most people who debadge their car have the base model, be it a BMW or whatever.
Old Jun 6, 2021 | 11:49 AM
Maxpowers's Avatar
Maxpowers
I removed mine (on my base model) because they look like guitars.
