Bought our 2016 in Jan 2018 with 19,500 miles. Checked the 3LT as I knew about the possible problem. Dash was perfect. Car is kept in garage and I always use a windshield shade, never any kind of chemicals on the dash when cleaning. By September dash was coming up around defroster vents and HUD.
Missed the 3 year warranty by 2 weeks, GM ended up paying 2/3rds, I paid 1/3rd - about $950. So far the replacement has been perfect.
I'd modify your statement slightly. Most have MINOR almost unnoticeable issues. Mine is likely one of those, I'd say its pretty common to have some loosening around the center vent, you might not even notice it unless you stare at it very carefully.
Mine has over the years gotten slightly worse. The issue is the dash is two pieces, the lower portion (below the stitch seam) seems to have had legitimate and problematic issues on 2014 and 2015 models. 2016 had some improvements and on mine for example I notice no issues on this lower larger portion. The upper portion is another story, and I think until the 2019 changes with extra staples and longer tabs with more glue there are issues. Most are a ever so slight lifting or bubbling on the lip of the vent. Mine was like that for years. Now I have some lifting on the vertical surfaces between the lip and the vent, but is it an issue? No. Would I have them rip out the dash to fix it, absolutely not. I might try a syringe to prevent it form getting worse. If my car wasn't asleep I'd grab a picture, because its 99% unnoticeable.
You are correct, people with MAJOR dash issues are an extreme minority. The design up near the vent is poor and it will eventually fail in some way unless you have a 2019 dash.
I wouldn't. If all 3LTs had any dash problems, it would be all. But, MOST do not. That's MOST C7 3LTs. Problem free. Including mine.
I have a 2014 3LT and the dash is still good. I have owned it for less than 2 years. I have a suspicion it's caused by someone slathering some kind of leather conditioner on.
No it's not.
Originally Posted by ZumZum
Maybe also how much time the car spends in the sun. Hot climate like Phoenix may make a difference.
Has nothing to do with it.
My 2014 3LT with no dash problems. Of course mine is garaged at home. My employer also had solar panels installed over the parking lot, so it's sits in the shade when I take it to work.
Luck of the draw.
Originally Posted by G8ME
This is a known issue with 3LT Dashes
Yes it is
Originally Posted by Raidercop
My 2019 3LT has no issues. They used different glue and added extra staples on the 2019 models. Can't speak for other years
No they didn't.
Originally Posted by cowboy casey
my 1st 3LT Stingray had it bad. My 2nd Z51 did not because I went to the extreme to stop it.. I had 70% Ceramic Tint installed and a dash cover.. It worked great and did not fail in 60k miles/5 years.. I bought a 2lt for my Z06 so no issue now..
Again, luck of the draw, it had nothing to do with it. There is no ryme or reason when it happens, only that it happens on 3LT's.
Here's why I can say you're wrong.
Working in automotive I know how warranty and quality is tracked. Parts get changes for two reasons, one is they are changed to be made cheaper, two they are changed to fix a design flaw. The only reason to fix a design flaw is if the warranty cost exceeds the cost to change the design (yes, this is where they say automotive companies are heartless because it does come down to cost).
Anyway, the fact that GM has made multiple changes means the warranty cost is high enough to do so. Further statistics tells you that not everyone makes a warranty claim and not all failures happen in warranty. If there is a large enough monetary case to make a design change due to warranty then the problem is actually quite common if not present in some way on all units.
It's not luck, there are reasons: environment, quality of the original unit (which again likely has to do with environment as much as manufacturing process), which design you have (there are design changes, and while perhaps not all 2019's have them it seems there are some with the staples).
To just say its luck is actually a very ignorant thing to say. To say its due to a combination of disturbance factors some which are understood and others which are not is correct. Now maybe to an untrained person that looks like luck, but no part fails due to luck. There is a statistical distribution which can predict these failures and each failure has a cause and it can be documented.
I don't think so. 10 garage queens under the exact same circumstances 5 bubble 5 don't, I'd call that luck.
The people that I want to hear from,,,,,,,,,, Those of you that have had your car since new, and have NEVER put anything on your dash. People that bought the car used, have no idea what the previous owner did. People that have put just a "LITTLE" on your dash don't count. People that have only used _______ on the dash don't count.
People that have only used a dry towel on their dash,,,, that counts. Please chime in.
You are totally disregarding the manufacturing process and latent failures. You do understand that not every car starts at the same point right? Things like to the week the car was built, the lot of glue, the specific line it was built on at the sub supplier, the shift. How long it was stored, where was it stored, how was it transported, all of those are disturbance factors. And by stored I don't mean the finished car. I mean the dash assembly.
But also transport of the car, how long the finished car sat at the factory. What did the dealer do to it?
I've only used a damp towel. So I guess that doesn't count either. Which honestly good luck, I'm probably one of the people who has done the least. Finding a person who never put a liquid on it, good luck.
How about did the line worker pick his nose and rubbed his bugger on the dash before he installed it? Maybe that contributed to it. Or maybe after he took a leak he forgot to wash his hands. Stop it now, First paragraph your talking about the dash and the second your talking complete opposite, the car. What is it?
So do you know of this case, when this happened? Or is this just your guess?
This 3LT dash delamination has been beaten to death thru the C6 C7 C8 generations on here. Forum members from all walks of the environment have told countless stories of their dashes letting loose, or not. My guess? lol Been reading this forum for 13 years now and the garage queens are far far from immune. Like I said, luck of the draw. I used 10 as a round number just so I could differentiate half and half ( don't know what it is actually) it is a lot more than that tho. That is fact.
In a nutshell. ^^^^
I find the most vehemently opposed to 3LTs, have never owned one....
