C7 3LT Dash Problems
Old Nov 5, 2024 | 09:59 PM
paulr3579@yahoo.com's Avatar
paulr3579@yahoo.com
Default C7 3LT Dash Problems
Wondering how many people have had the leather bubbling/pulling loose/etc. problems
Old Nov 5, 2024 | 11:36 PM
76-Vetteman's Avatar
76-Vetteman
Mine has pulled away some, but it's not growing larger, or really bothersome to look at. Never told the wife and she doesn't know the problem exist.
Old Nov 6, 2024 | 12:50 AM
clydecpa's Avatar
clydecpa
I bought my 2017 3LT GS 7M vert 4 weeks ago and this was on my inspection punch list. There was a bubble above the HUD smaller than the palm of your hand and sticking up maybe 1/8”, not very noticeable. Also some minor lifting up around the dashboard vents where you can push down on that and it moves slightly but no noticeable bubbling. I doubt this has been active for some time and it was acceptable to me as none of it stands out.
On the flip side, I really like the 3LT trim with the sueded steering wheels and other areas. The vented seats push air through the sueded part of the seats better than on any car I’ve had, including my BMW X7m50i.
Old Nov 6, 2024 | 06:01 AM
449er's Avatar
449er
CF Community Team
This issue is now 3 generations old starting with the 4lt C6 dashes
Old Nov 6, 2024 | 07:13 AM
DGA3's Avatar
DGA3
There are plenty of threads on this forum about the issue.
Search, and you shall find!
Old Nov 6, 2024 | 08:23 AM
Exactly. A search should turn up a number of threads on this issue.
Old Nov 6, 2024 | 09:35 AM
kodpkd's Avatar
kodpkd
I have a 2014 3LT and the dash is still good. I have owned it for less than 2 years. I have a suspicion it's caused by someone slathering some kind of leather conditioner on.
Old Nov 6, 2024 | 09:58 AM
ZumZum's Avatar
ZumZum
Maybe also how much time the car spends in the sun. Hot climate like Phoenix may make a difference.
My 2014 3LT with no dash problems. Of course mine is garaged at home. My employer also had solar panels installed over the parking lot, so it's sits in the shade when I take it to work.
Old Nov 6, 2024 | 05:20 PM
Skid Row Joe's Avatar
Skid Row Joe
Never had any trouble with it.
Old Nov 6, 2024 | 07:57 PM
G8ME's Avatar
G8ME
This is a known issue with 3LT Dashes
Old Nov 6, 2024 | 08:44 PM
Raidercop's Avatar
Raidercop
My 2019 3LT has no issues. They used different glue and added extra staples on the 2019 models. Can't speak for other years
Old Nov 7, 2024 | 12:02 AM
Skid Row Joe
*some
Some dashes. Not ALL dashes. MOST have ZERO issues...
Old Nov 7, 2024 | 11:43 AM
Shayb79's Avatar
Shayb79
My 2019 had the issue. I was playing whack mole with the syringe and glue. My 2017 is a 2LT for good reason.
Old Nov 7, 2024 | 12:05 PM
kodpkd's Avatar
kodpkd
Did anybody put any kind of conditioner on the dash?
Old Nov 7, 2024 | 02:58 PM
cowboy casey's Avatar
cowboy casey
my 1st 3LT Stingray had it bad. My 2nd Z51 did not because I went to the extreme to stop it.. I had 70% Ceramic Tint installed and a dash cover.. It worked great and did not fail in 60k miles/5 years.. I bought a 2lt for my Z06 so no issue now..
Old Nov 7, 2024 | 03:09 PM
c5arlen's Avatar
c5arlen
GM's on top of this product problem..
Old Nov 7, 2024 | 04:36 PM
Always Red Dave's Avatar
Always Red Dave
3Lt dash fix - CorvetteForum - Chevrolet Corvette Forum Discussion
To C7 3LT Dash Problems
Old Nov 7, 2024 | 07:31 PM
user051728's Avatar
user051728
Originally Posted by Skid Row Joe
*some
I'd modify your statement slightly. Most have MINOR almost unnoticeable issues. Mine is likely one of those, I'd say its pretty common to have some loosening around the center vent, you might not even notice it unless you stare at it very carefully.
Mine has over the years gotten slightly worse. The issue is the dash is two pieces, the lower portion (below the stitch seam) seems to have had legitimate and problematic issues on 2014 and 2015 models. 2016 had some improvements and on mine for example I notice no issues on this lower larger portion. The upper portion is another story, and I think until the 2019 changes with extra staples and longer tabs with more glue there are issues. Most are a ever so slight lifting or bubbling on the lip of the vent. Mine was like that for years. Now I have some lifting on the vertical surfaces between the lip and the vent, but is it an issue? No. Would I have them rip out the dash to fix it, absolutely not. I might try a syringe to prevent it form getting worse. If my car wasn't asleep I'd grab a picture, because its 99% unnoticeable.
You are correct, people with MAJOR dash issues are an extreme minority. The design up near the vent is poor and it will eventually fail in some way unless you have a 2019 dash.
Old Nov 7, 2024 | 07:37 PM
user051728's Avatar
user051728
Stuff like this is harder to fix than you'd think.
The ends yes can be controlled and made better by longer tabs and more stables. But that of course has a money cost.
The glue is another story, like many substances in your car there are trade offs, and getting it to layer right and consistent on the dash can be an issue (and that would be at a dash sub supplier not at GM). No production process or material or substance (glue, grease, etc) is perfect you always get variation and you have to deal with issues like environmental conditions (while factories are climate controlled you don't have near perfect control of things like humidity and temperature down to an exact value).
This is more of a boutique process gluing on leather to a dash, most other leather like dashes (on high volume product) are using some sort of molded process and are not real leather (rather a plastic designed to look and even feel like a leather or a vinyl style top). Unless you buy a high end luxury product and then they spend more time on labor, remember Corvette is a mass produced vehicle by a volume run of the mill manufacturer.
Old Nov 8, 2024 | 07:43 AM
DGA3's Avatar
DGA3
That's the method I used.
