Dyno Tuned
Old Oct 1, 2013 | 07:02 PM
tail_lights's Avatar
tail_lights
Originally Posted by rcallen484
You are but that is obviously your nature. Do your best with the way you are.
I'll try. Just not happy with what GM gave us for the base/Z51 C7.
Who drank half my water???
Old Oct 1, 2013 | 07:04 PM
C7lover2's Avatar
C7lover2
any plans to add some E85 and a retune? Wondering how the fuel system will handle E85 stock. How are the injector duty cycle's after a tune?
timmyZ06's Avatar
timmyZ06
damn you beat me to it
what's up with the supercharge/TT tables that sound VERY promising!! Where did gain the most? Is the timing or the fuel was very conservative? Is there room for E85?
Old Oct 1, 2013 | 07:05 PM
tail_lights
Ahh, that's a good question
Old Oct 1, 2013 | 07:10 PM
C7lover2's Avatar
C7lover2
I live in So Cal the land of 91 octane (Aka ****). I love running E85 in all my cars! E85 is liquid gold in my eyes.
Old Oct 1, 2013 | 07:11 PM
rcallen484's Avatar
rcallen484
Water...?
Old Oct 1, 2013 | 07:14 PM
OnPoint's Avatar
OnPoint
The Consigliere
Any more info on FI tables?
Old Oct 1, 2013 | 07:17 PM
tail_lights
Water...?
Nice!
Old Oct 1, 2013 | 07:27 PM
NoOne's Avatar
NoOne
Maybe I'm a "negative nancy", but GM should have just given us better numbers to begin with.
What this post implies is that they are holding back with their 460 horses like many of us thought.
Because tuners like 21st Century can do as they please without the EPA looking over their backs.
Old Oct 1, 2013 | 07:43 PM
Raced Guy's Avatar
Raced Guy
What were the gains below the curve ? Looks like strong gains from 4k to 5k !!!
Old Oct 1, 2013 | 07:49 PM
21STCENTURYMUSCLECAR's Avatar
Premium Supporting Vendor
I will post up some screen shots tomorrow
Old Oct 1, 2013 | 07:53 PM
You wouldn't believe me if I told you..........
19
See......
There goes my injector sales!
Best Regards,
John Page
Old Oct 1, 2013 | 08:08 PM
  #33
tail_lights
I seriously doubt a better tune to pick up a few ponies up top will hurt MPGs, shoot, I bet the 21st Century tune gets better that stock MPG
Edit:
I guess I should say I'm sure a company as big as GM could find a way to put a better tune to pick up a few ponies up top without hurting MPGs. They just didn't want to.... YET....
Old Oct 1, 2013 | 08:27 PM
  #34
C7lover2's Avatar
C7lover2
Only 19 percent? Wow they left some crazy room in the injectors if the number you provided is percent based. Wonder what the limitations of the fuel pump will be. Never replied with any info on the E85 tune ! Any plans or not your cup of tea? Thanks for your input by the way. Very exciting stuff and I look forward to the future of this vehicle.
Old Oct 1, 2013 | 08:33 PM
  #35
C7lover2's Avatar
C7lover2
Edit:
I'm sure they could have found more power but keep in mind that all engines are not built equally nor will they dyno exactly the same. Gm has to leave room and a safety margin for fuel grade, weather and other factors. That's the beauty of a custom tune you are able to push the vehicle further and determine your specific engines limitations (knock, fuel spray pattern, cylinder diferrences and many other factors) to achieve optimal performance.
Old Oct 1, 2013 | 08:47 PM
  #36
FastMatt2's Avatar
FastMatt2
19
See......
Best Regards,
John Page
GM seems to be going way over board with injectors on there DI motors. The injectors that come stock in the 2.0L turbo ATS that put about 220 hp to the wheels stock threw a auto have already been pushed to nearly 500 whp and there still not even close to maxed out.
Old Oct 1, 2013 | 09:17 PM
  #37
keagan's Avatar
keagan
Nice numbers for tune only, looking foward to seeing what's up with the TT and Supercharger.
To Dyno Tuned
Old Oct 1, 2013 | 09:49 PM
  #38
arghx7's Avatar
arghx7
19
DI engines are not like PFI. You can't really go by injector duty cycle. You have to look at the start of injection and end of injection timing as well as the rail pressure. On most engines, any SOI before 340BTDC firing and EOI after 50BTDC firing will have smoke and oil dilution. This is because the fuel hits the piston or cylinder wall.
Call it 19 percent if you want, but that's thinking in PFI terms really. On a PFI engine, you tune the injection timing first by the end of injection. It's either open valve or closed valve injection. Typically full load is open valve, and if you fully max the injectors out they keep spraying on the back of the valve all through the 4 strokes.
Again, they will max out if you care about fuel impingement, oil dilution, and throwing fuel out of the exhaust valve. Which, I admit, nobody here cares about that much.
But to say GM left a bunch of headroom is simply not getting into their mindset and not understanding how DI engines are designed. Injection timing, rail pressure, and number of injections are all important factors, and they can affect horsepower.
Old Oct 1, 2013 | 10:27 PM
  #39
Racer X's Avatar
Racer X
Originally Posted by 1320vetteran
Where? I'd like to read it. Tried sending you a PM.
http://forums.corvetteforum.com/c7-g...lable-now.html
It is worth downloading and strolling through the Corvette file in Demo mode. If you are into the technical details.
Old Oct 1, 2013 | 10:31 PM
  #40
OBSSSD's Avatar
OBSSSD
But GM engineers said that the C7 PCM would be tuner-proof
