Engine oil
Old Feb 12, 2014 | 07:55 PM
  #121
bnall40's Avatar
bnall40
Originally Posted by W88fixer
If GM Dexos is as good as Mobil 1, why do they recommend 15W-50 Mobil 1 for racing with the Z51? Must provide better protection than the OEM Dexos fill. Don
Don, I had exactly the same Q; It's right there in the C7-Z51 manual. It appears that GM considers Mobil 1 best for cars under track stress, therefore a better oil. Another oil Q; Does anyone have experience with AMSOIL? A very nice guy gave me a whole case of 5w30 synthetic.
Old Feb 12, 2014 | 08:18 PM
  #122
Theta's Avatar
Theta
St. Jude Donor '14-'15
Damn, that was a nice guy!
You're in luck - there's an Amsoil rep posting in this very thread.
Old Feb 12, 2014 | 08:29 PM
  #123
SilversledC7's Avatar
SilversledC7
I have been using AMSOIL in all of my cars and bikes for 15 years. I am on the preferred customer program so the prices I pay are as cheap as buying them from the big box stores. I dumped the Dexos stuff at 1500 miles and put in the AMSOIL Signature Series.
Old Feb 12, 2014 | 11:04 PM
  #124
bnall40's Avatar
bnall40
Thanks guys for the AMSOIL replies. Sam
Old Feb 13, 2014 | 08:07 AM
  #125
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I've been using AMSOIL in both my Vette at the track (racing oil for the engine), all my personal vehicles, and my lawn and garden equipment since 2004. I do used oil analysis periodically on all my vehicles less the Vette to monitor my engines - all are doing well. Don't do it on the Vette as I have the engine rebuilt after every season or two. I know from these tear downs that the bearings, rings, pistons, etc are all not seeing any significant wear.
Obviously very happy with AMSOIL or wouldn't still be using it.
AMSOIL makes three tiers of street oils; Signature Series, XL, OE. Which one did you get?
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Feb 13, 2014 | 12:30 PM
  #126
glass slipper's Avatar
glass slipper
Originally Posted by ByByBMW
Hmm, so educated guess might be a large ocean going vessel, might be steam turbine driven and probably not military. Close?
In any case, the plot thickens, and changes, when you start throwing combustion products into the mix. Agreed?
Absolutely agree, that's why I clearly stated the equipment is for power transmission. That's why we look at TAN and internal combustion engines look at TBN...they're the exact same thing, just different.
Your close on your guess...you got the ship part correct but it is military, US Navy. And they use gas turbine engines not steam turbine. I'm still trying to find a good video to show how these "hot rods" of the sea run. I have a great one on my phone but I don't want to share it online...
Old Feb 13, 2014 | 12:37 PM
  #127
glass slipper
Originally Posted by t.renz791
I know I had a tough time finding it too, this stuff is confusing isn't it?
Going to the UK Mobil 1 site shows that it is current Dexos approved. The product description sheet shows that 0w40 Euro formula (as marketed in the US) is the same product as Mobil 1 0w40 ESP in the UK:
"Mobil 1™ 0W-40 European Car Formula (North America) or Protection Formula (rest of the World) Advanced Full Synthetic Motor Oil is engineered for the latest gasoline and diesel (without Diesel Particulate Filters or DPFs) engine technology delivering excellent all-round performance. It provides exceptional cleaning power, wear protection and overall performance. Mobil 1 0W-40 keeps your engine running like new in all driving conditions."
Links:
http://www.mobil.com/USA-English/Lub...l_1_0W-40.aspx
http://www.mobil1.co.uk/which-synthe...ngine-oil.aspx
Also reviewing those sheets shows that Mobil 1 0w40 does indeed have a colder pour point, higher viscosity index and higher temperature viscosity than M1 5w30
The Mobil 1 0W-40 in the UK is dexos 2 certified while the Mobil 1 5W-30 in the USA is dexos 1 certified....the C7 in the USA requires dexos 1, not sure what it is in Europe but if I was a betting man I would say its dexos 2.
In general, dexos 1 is for gasoline engines and dexos 2 is for diesel engines. But since Europe is mostly diesels, dexos 2 is what is available and is used for gasoline engines there also. In the USA, we're mostly gasoline engines and dexos 1 is what is available and is used in diesel engines here also. I know, crazy...
Old Feb 14, 2014 | 09:13 AM
  #128
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
No need for the pics, I was nuclear navy, surface, and your GT ships were one of the reasons the surface nucs were retired.
Old Feb 20, 2014 | 08:15 PM
  #129
Gr8ful's Avatar
Gr8ful
Great read. Some smart guys here. I just dumped my Z51 oil at 995 miles. Went with Mobil1, AC Delco filter and 2 magnetic plugs for a total cost of $64. I feel like I can play harder with the car now. No facts just feelings except did trust my life to MobilJet2 oil in big jet engines with No oil related issues in 8000 flight hours.
I won't let the dealer change my oil unless it would be needed because of a component change and I will bring the Mobil1. I never have good experiences with GM dealers. One told me my brake rotors warped because the got wet when they were hot. Scary.
Old Feb 20, 2014 | 08:58 PM
  #130
Trackaholic's Avatar
Trackaholic
A few years ago I saw something on the Discovery channel that was showing the sea trials of some type of high speed, medium sized ship (destoryer maybe?). The program focused extensively on the geartrain that converted the high RPM power of the gas-turbines to the high-torque, low RPM power of the prop shaft. The technicians were using pens to mark the gears and check the wear patterns from the initial runs. Based on that wear they would shim the gears as necessary to optimize the mesh. As a mechanical engineer I thought the show was excellent, but I have not been able to find it online.
-T
Old Feb 20, 2014 | 09:13 PM
  #131
Theta's Avatar
Theta
-T
Was it, by chance, 'Mighty Ships' on Discovery? That was a series, and it sounds like what you're describing.
Old Feb 20, 2014 | 09:17 PM
  #132
leadville1's Avatar
leadville1
I talked to Spring Mountain Raceway today where they have a bunch of C7's and said all their cars are running 15w50 race oil and that they are overfilling their sumps by 1/2 a quart. I thought this was interesting given that the rule seemed to be to run less.
I know for sure I am installing a catch can on this car.
Old Feb 21, 2014 | 09:23 AM
  #133
NickHall's Avatar
NickHall
Madison Wisconsin
Interesting: I just got a notice from GM on the importance of the engine breaking-in period and for following the instructions on speed and RPMs limits during break in. Seems some people thought that you could push this engine direct from the factory. Oh My! Not smart.
GM does not allow RPM above 4000 or use of the cruse control during break in. I cannot believe that people think this engine needs no break-in period. GM has said that not following their break-in (see owners manual) instructions voids the warranty.
Old Feb 21, 2014 | 11:58 AM
  #134
bluedevil 1's Avatar
bluedevil 1
Default slippery subject
TIME2RUN: I find it quite interesting that your service manager says that the C7's are being filled at BG with Mobil 1 when the manual and the dry sump fill cap specifically say other wise. Also, if you read the fine print in the manual (just kidding) it says that if you are going to track the car...go to Mobil 1. Just my observation but factual
Old Feb 21, 2014 | 12:12 PM
  #135
NickHall's Avatar
NickHall
Madison Wisconsin
Originally Posted by bobby777
Dexos from GM--is made by Mobil--it is in fact Mobil 1 5-30 oil=
That is my understanding also. Dex1 is the standard and Mobil1 meets the standard and in fact the standard was made to keep products like Mobil1 as the oil of choice. If A=B then B=A.
Old Feb 21, 2014 | 01:12 PM
  #136
Theta's Avatar
Theta
Then you're both incorrect...
Dexos1 is a standard, not a product. The factory and dealer fills are ACDelco Synth Blend products.
Those ACDelco products are in no way related to Mobile 1 other than both being engine lubricants.
Old Feb 24, 2014 | 10:34 AM
  #137
bnall40's Avatar
bnall40
There is obviously a lot of high tech experience on this thread so I have an oil Q:
I will run 2-3 laps in my Z51 behind the pace car at the Barber Motor Speedway on April 23rd and 10-12 high speed (150 max) laps at Talladega on May 24th. I also have an oil change due just before BMS. (I realize Mobil 1 20w-50 is recommended for track but I don't consider either event as a prolonged high stress event). I would prefer to change oil only once and I am considering Mobil 1 5w-30 Extended Performance DEXOS approved as the choice. This is the really expensive (gold) Mobil 1 5w-30 with higher engine temp protection. Other than these two events my beauty will only be "cruisin'". Advice, suggestions please.
TX, Sam
To Engine oil
Old Feb 24, 2014 | 11:39 AM
  #138
LT1xL82's Avatar
LT1xL82
TX, Sam
I base this on nothing but gut feel...I don't see a need to use special oil for these 2 events, especially the first. I'm assuming you have the Z51 dry sump and that it will not be seriously hot at Talladega in May. But...you know what they say about "assume"!
Now for my question! How did you come to be able to do these two runs?
Old Feb 24, 2014 | 06:01 PM
  #139
NickHall's Avatar
NickHall
Madison Wisconsin
Ahhhhh. Okay,.... did you read the post? Read it again. This time carefully.
As a petroleum chemist you may want to look again. Just saying...
What we said is correct.
Dex is a standard,...
products "like" Mobile1. See the word "like"?
ACDelco sysn is very much "like" Mobil1. Look at the chemistry spec sheet. Do you see any difference at all in their physical or chemical test results. Like means "like". If A=B then B=A.
Just saying.... What I said is correct.
Old Feb 24, 2014 | 06:03 PM
  #140
NickHall's Avatar
NickHall
Madison Wisconsin
To the Nuck Navy. Great respects.!!!
You guys were awesome to deal with when I was with NSA.
Totally great group of guys.
Nick
