Catch Can For NA C7
Old Apr 28, 2014 | 10:50 AM
gthal's Avatar
gthal
Originally Posted by Higgs Boson
The dry sump problem is due to overfilling and puking. Not PCV, which pulls air out of the crankcase. Makes me glad I have a wet sump. My intake manifold and intake tube are dry as dinosaur bones.
But I guess as George Costanza once said, "They're all tubes, Jerry!"
I checked my Z51 last night and I was bone dry too with the dry sump. I have driven the car pretty hard and it has been fine so far. As you note, don't overfill the dry sump and you are probably fine.
Old Apr 28, 2014 | 11:04 AM
Higgs Boson's Avatar
Higgs Boson
Old Apr 28, 2014 | 07:44 PM
49northls3's Avatar
49northls3
nice C6 you have there. catch cans work on the ls motors for sure......the C7 does not have an LS motor. things change. the pcv system is night and day different now.
Thank you, I stand corrected with respect to the oil vapor threat on a C7.
Old Apr 28, 2014 | 09:58 PM
Cdn996's Avatar
Cdn996
Probably fine on clean side oil separation that is. As noted above, the jury's still out on the need for a catch can which doesn't have anything to do with dry sump oil puking but rather addresses dirty side PCV emissions into the intake.
Old Apr 29, 2014 | 06:52 AM
leadville1's Avatar
leadville1
I think this is more of a direct injection issue, leading to coking on the valves. BMW's almost all need to run catch can's or are needing to have their intake manifolds removed to clean them eventually.
The Catch can helps with this more than anything, Almost every modern DI car can benefit for this reason alone.
Old Apr 29, 2014 | 07:05 AM
Higgs Boson
because all direct injection engines are the same. because chevrolet looked at the bmw for guidance on how to design their new pcv system.
outside of the dry sump puke issue, has anyone had oil in their intake manifold due to the pcv system itself (the u tube).
Old Apr 29, 2014 | 08:28 AM
leadville1's Avatar
leadville1
I installed Catch cans in all my DI cars, Audi, BMW they all have the same problems. I can't imagine it will be any different for GM. It can't hurt, the proof is in what you pull out of them every oil change.
Old Apr 29, 2014 | 09:40 AM
Higgs Boson
I agree, however, I also check my dirty side PCV line every single time (yes, literally every time - OCD) I drive the car and it is always clean. They completely redesigned the system on the LTx and so far it seems to work.....as long as the U-tube dirty line is clean, I have zero concerns.
Let's be honest, a catch can is not expensive or permanent. If it makes you feel good, put one in!
Old Apr 29, 2014 | 10:22 AM
zoomz's Avatar
zoomz
Catch cans are not really for brand new cars .
A new well built STOCK motor will have such minimal blow by , a catch can is not needed .
If you are going to drive your new corvette on the weekend , put 10k miles on it then sell it , you don't need a catch can , Ever .
If you are going to mod your new vette and start making bigger hp
numbers you are going to have more blowby and your not going to want that oil diluting you octane levels , Period
Old Apr 29, 2014 | 11:44 AM
Higgs Boson
numbers
Agree.
Old Apr 29, 2014 | 12:02 PM
Motohead279's Avatar
Motohead279
I put one on after I boosted my car. Cheap insurance and to me worth it.
Old Apr 29, 2014 | 01:25 PM
leadville1's Avatar
leadville1
Agree.
Well I plan on modifying my car just like every car I have owned. Maybe that is the problem with the approach to this thread. We have a lot of Corvette owners who think a performance modification is adding All Season Tires.
I have a CAI, Headers and a tune going on my car right after break in, and plan on using at the track all summer long.
Old Apr 29, 2014 | 02:40 PM
  #33
zoomz's Avatar
zoomz
We have a lot of Corvette owners who think a performance modification is adding a CAI, Headers and a tune .
Still shouldn't need a catch can yet on a stock motor imo .
Not until you have 30-50k or so miles on the rings and notice blowby or add a cam or a forged bottom end or FI , then you will need a catch can .
Old May 1, 2014 | 12:08 PM
  #34
Magister Ludi's Avatar
Magister Ludi
Gentlemen,
Forgive me for reviving an aging thread, but I am hoping to be educated on a catch can issue. I am one of those that has discovered considerable oil in the rubber and plastic structures leading from the air filter box to the throttle body. To wit:
I had hoped to address the issue with a catch can, but as I look at where the can is situated, it really doesn't look like it serves this purpose. Looking at the pictures of KenHorse's install (thanks, by the way), it looks like the can simply intercepts vapors going from the crankcase back into the intake manifold:
If that's the case, I don't think a catch can would help my problem. Do you agree?
Old May 1, 2014 | 01:46 PM
  #35
zoomz's Avatar
zoomz
Originally Posted by Magister Ludi
Gentlemen,
The lines coming off the valve covers need to route through the catch can also .
Those 2 lines will always spu oil into the filter/intake tract .
Old May 1, 2014 | 01:57 PM
  #36
Higgs Boson
Except that they don't on this car. Ludi is correct that the oil in his intake is not from the PCV system but the line coming off the dry sump tank. A catch can will not prevent this, only proper oil level will.
Old May 1, 2014 | 02:22 PM
  #37
Magister Ludi
That sure is what it looks like to me on my Z51. I suppose one could install a catch can in the line that goes directly from the dry sump tank to the air intake, but, being a rookie at this, I'm not inclined to experiment.
Concerning proper oil level, I really hope that's all it was. But the jury is still out. I checked my oil level not long after break in and it looked fine. I didn't discover the oil in the intake system until several thousand miles later. While it's possible that it was overfilled at the factory and was done puking by the time I checked it, I'm also concerned as to the role that "aggressive driving" may have played, as described in this GM alert (Thanks Theta):
One curious thing about this document is that it talks about aggressive driving "pushing oil through the PCV system" and all the way into the air box. I'm at a loss as to what path this would take, but one would assume GM knows its engine. (I suppose that even the line from the dry sump tank to the air intake is still designed to control pollution and may be regarded as part of the "PCV system".)
To Catch Can For NA C7
Old May 1, 2014 | 05:33 PM
  #38
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Originally Posted by ajkelly
Looking for suggestions on best catch can for a NA C7. Guessing I do not have to spend $700-800 to do it right on a non-boosted engine? Thanks in advance!
Take a look at this thread please:
http://forums.corvetteforum.com/c7-g...post1586798189
Old May 1, 2014 | 07:26 PM
  #39
Magister Ludi
Thank you Thank you.
Old May 5, 2014 | 05:59 PM
  #40
sirjames_CO's Avatar
sirjames_CO
Default There is an oil problem
Originally Posted by Rock'n Blue 08
Not really! There is an oil problem even on stock dry sumps!
My dry sump system was dumping oil out of the ProCharger blow off valve after we supercharged it. I have a feeling after looking at the way things are done that all this oil was previously going into the intake. The BOV just gave us a low point for the oil to leak.
I would like to know if STOCK dry sump owners are seeing oil at the intake. The hose runs from the canister to the intake. Please take a look if you are so inclined and let us know if this is a design problem.
My opinion is that this is a design flaw.
-Jim
