Catch Can For NA C7
Old May 5, 2014 | 06:13 PM
  #41
Wormwood's Avatar
Wormwood
Originally Posted by sirjames_CO
My dry sump system was dumping oil out of the ProCharger blow off valve after we supercharged it. I have a feeling after looking at the way things are done that all this oil was previously going into the intake. The BOV just gave us a low point for the oil to leak.
I would like to know if STOCK dry sump owners are seeing oil at the intake. The hose runs from the canister to the intake. Please take a look if you are so inclined and let us know if this is a design problem.
My opinion is that this is a design flaw.
-Jim
I'm bone stock z51 & just cleaned out the intake for the 2nd time. You have to be very mindful of your rpm's until you warm up & no longer hear the oil splashing around in the reservoir. Nevertheless, I'm still getting oil burped up into the intake in the picture is a plastic water bottle regular size (500ml) this what I've poured out twice now.
What concerns me as well is the strong smell of gasoline in the oil & yeah it's enough for the vapor to ignite. I'm all for bypassing this system altogether, for the cost of everything to date, I could have planted 2 dozen trees & more than offset the carbon footprint this system is trying to prevent. As it stands right now the runners need cleaning & so do the heads, any oil, liquid or vapor, that comes in contact with the metals close to the cylinders will stick & begin to harden, the operating temps of this new engine don't help matters either.
Build date:11/14/13
Vin:8693
Z51 NPP MRC
no mods; stock
3000 miles
Old May 5, 2014 | 06:22 PM
  #42
sirjames_CO's Avatar
sirjames_CO
Build date:11/14/13
Vin:8693
Z51 NPP MRC
no mods; stock
This is unacceptable in my opinion
Old May 5, 2014 | 06:25 PM
  #43
sirjames_CO
"I'm bone stock z51 & just cleaned out the intake for the 2nd time. You have to be very mindful of your rpm's until you warm up & no longer hear the oil splashing around in the reservoir. Nevertheless, I'm still getting oil burped up into the intake in the picture is a plastic water bottle regular size (500ml) this what I've poured out twice now. "
Build date:11/14/13
Vin:8693
Z51 NPP MRC
no mods; stock
Can you determine that this is sourced from the canister and NOT the PCV (right side) of the motor?
Old May 5, 2014 | 08:33 PM
  #44
567Chev's Avatar
567Chev
-Jim
I just pulled off my CAI on my otherwise stock Z51 with 2500km on it to take a look. No oil in intake.
Old May 5, 2014 | 09:49 PM
  #45
Wormwood's Avatar
Wormwood
Build date:11/14/13
Vin:8693
Z51 NPP MRC
no mods; stock
I'd say the canister, because when I'm cleaning everything out, I first hang the PCV lines on the overhead door rails & the long one always has some oil in the line & the short never has.
Another member just posted about removing his CAI. The stock intake system & the cavities where the PCV ports are would act like siphons. The more air that moves passed the entrance of those cavities, the higher the vacuum it would create at the ports. Similar to blowing air across the mouth of a milk jug. I haven't seen a CAI system that has all these goofy labyrinth designed intake, so that said I'd think a aftermarket intake may just as we'll fix the issue, but may unknowingly create a higher than normal case pressure since there's no longer a constant vacuum applied to the engine case. I'd like to check that out myself, if I could find a sensor that would work for this application...
Wormwood
Old May 5, 2014 | 10:22 PM
  #46
xp800's Avatar
xp800
Wormwood,
I've been looking at CAIs and catch cans. The new aFe has one of these suction pods with two fittings for the OEM PCV system. Looks like tapping an extra fitting into it for one of the dual outlet Elite cans would be pretty straightforward. I'm leaning this way...
http://forums.corvetteforum.com/c7-t...l-release.html
Old May 6, 2014 | 02:02 AM
  #47
Wormwood's Avatar
Wormwood
Originally Posted by xp800
Wormwood,
I had no idea aFe had released that! I talked to someone at Elite this weekend who said they've got something coming out specifically for the Z51. The only concern I had was the placement of those dual cans right beside the exhaust. I don't think it matters how many SOS pads you put in a catch can, if the temperature isn't lower than the vapors coming in, no condensation would take place. Placing the catch can at the lowest point will certain utilize gravity for any droplets formed within the plumbing but for a catch can to be effective it has to be lower in relative temp. to the vapors coming in. Correct me if I'm wrong but that's what I've thought to be true.
My suggestion was to mount the catch cans forward of the front wheel well, I'm still waiting to hear back from Elite on that. In any case, Elite is what I'm looking at as well, it just may be modified.
The Vette's going to the dealership this week for a new windshield & intake cleaning. so I'll have some extra time to see what Elite says...
This was what I had on hand last Friday night, it's a Moroso can breather, but what's nifty is it fit on the horn mount perfect!!
Wormwood
Old May 6, 2014 | 08:55 AM
  #48
567Chev's Avatar
567Chev
Wormwood
The two intake lines feed air into the PCV system, not vapours into the intake, so I doubt removal of the stock baffles would increase crankcase pressure. But that's just a guess.
Old May 6, 2014 | 10:05 AM
  #49
Higgs Boson's Avatar
Higgs Boson
This is the intention of the design but under low vacuum, high intake flow the fresh air lines can indeed allow vented crankcase gasses to include oil and other poop into the intake. This was more prevalent in previous gen cars (LSx motors). I have yet to see this occur on the LTx; only dry sump cars burping oil into the intake, which is separate from the dirty PCV issue. Wet sump (non-Z51) cars seem to be ok. The part throttle/idle dirty U-Tube line remains to be seen whether it will introduce poop, but so far mine seems to be staying clean.
Old May 6, 2014 | 01:50 PM
  #50
567Chev's Avatar
567Chev
Good point. Not sure that would be different between a cold air intake and a stock intake - wouldn't they both be the same on that?
Old May 6, 2014 | 02:51 PM
  #51
Higgs Boson
possibly. I guess it depends on the design of the intake. I would think having a separate section that nullifys the effect would help. the stock intake has it, the afe has it.....so far my stock intake has had no issue but that could also be due to the internal redesign of the LTx system.
Old May 6, 2014 | 05:46 PM
  #52
Wormwood's Avatar
Wormwood
Wormwood,
XP800,
Take a look at Elite's website, they've added instructions & purchase options for the Z51 with dry sump. They're adding more website content tomorrow that's specific to the Z51's...
Looks like they have got a solution to the problem.
Wormwood
Old May 6, 2014 | 05:53 PM
  #53
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
XP800,
Wormwood
Not completely updated yet, but we're getting there.
http://www.eliteengineeringusa.com/c...el-years-2014/
Old May 7, 2014 | 04:27 PM
  #54
sirjames_CO
-Thanks for your input!
Old May 7, 2014 | 04:44 PM
  #55
sirjames_CO
I am tired of oil all over my garage floor. ProCharger has not seen this problem on any of the units that they have done, nor heard of this problem from any of their customers. I also do not think that the supercharger is the problem.
I have coughed up another 4~5 OZ. in the past two days... Does anyone know if there would be any problem with plugging the outlet from the dry sump supply as shown in the attached?
anyone, anyone? Bueller?
Old May 7, 2014 | 04:46 PM
  #56
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I have coughed up another 4~5 OZ. in the past two days... Does anyone know if there would be any problem with plugging the outlet from the dry sump supply as shown in the attached? [IMG]C:\Users\jim\Desktop\Z51 Problems Mod.jpg[/IMG]
Redo your link. It ain't gonna work if it's local on your computer. (try it as an attachment)
Old May 9, 2014 | 03:48 PM
  #57
Elite Engineering
Supporting Vendor
St. jude Donor '14
All, thanks for your orders and your patience. We're on schedule to ship all orders complete next week.
Again, thank you and have a nice weekend
To Catch Can For NA C7
Old May 9, 2014 | 08:46 PM
  #58
Higgs Boson
I would not plug it but what might be a better solution for the dry sump cars is to simply relocate the burp line into a catch can with an open filter on top. let it burp out the excess and drain it.
sort of like a coolant reservoir but without the potential or need for it to go back into the radiator or cooling system. just for overflow.
it could be mounted right by the dry sump tank with a short line.
Old May 12, 2014 | 10:50 AM
  #59
Elite Engineering
Supporting Vendor
St. jude Donor '14
Not a good idea. That is the source of the critical fresh make up air for the PCV system to do the "flushing" of the damaging combustion byproducts that constantly enter as part of the blow by. Doing so will not only defeat the critical evacuation process, but would also allow vapors in the sump tank to mix with the oil contaminating it and increased engine wear would also result much like any system that defeats the PCV system (a breatherd system will also result in much reduced engine life).
Old May 13, 2014 | 02:58 AM
  #60
3 Z06ZR1's Avatar
3 Z06ZR1
-Jim
I'm on board. When my stock intake came off. 1/4 cup of oil was inside.
I thought it may have been my error. By failing to drain it completely
on an oil change.
Then after driving. I'm getting oil through the blow off valve.
