C7 2014 Electrical Problem
Old Nov 2, 2014 | 08:33 PM
bruceappelbaum's Avatar
bruceappelbaum
Default C7 2014 Electrical Problem
Several times, my climate controls stop illuminating. The digital temp and fan speed display on the drivers and passenger side stops working along with all the indicator lights on the various climate control buttons. The heat and ac continues to function however and the digital display of temp and fan settings appears on the main display.After turning the car off for a short period of time and restarting, everything is working again. You can't just turn it off and restart immediately however to get everything back to normal. Takes a while.
Any ideas or suggestions other than just bringing it in to the dealer? I have had no luck fixing vette problems that are intermittent, without the problem occurring when at the dealer. Anyone had this problem ?
Bruce@optonline.net
Old Nov 5, 2014 | 10:56 PM
michaelrm1's Avatar
michaelrm1
Default hvac
I had the same issue once with the temp display. Came back on the next time I started the car.
Bruce@optonline.net
Old Nov 6, 2014 | 09:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LMAO.... The C5 HVAC head unit experienced the same crap. There were some surface mount resistors that literally popped off the circuit board on some units. Others had poor solder joints that lost conductivity under load. The entire display would go dark. A simple re-solder on the resistors solved the problem.
You would have thought that GM would have used some better vendors for the C7. SAD,, Plain and simple,,, SAD!
Bill
Old Nov 10, 2014 | 07:18 PM
Butch_N's Avatar
Butch_N
Default Similar problem 2015 week old :)
I'm having similar problems with 2015 also display flickers and gauges go to zero while driving for a sec .No ac display .
Taking it in tomorrow this sucks $70 000 vehicle
To C7 2014 Electrical Problem
