Best Catch Can for Supercharged Base
LMR is a no brainer for boosted applications
Then an appropriate mighty mouse can (there are different options)
Here's the greatest irony of this thread.....Cars and trucks go hundreds of thousands of miles and the owner/driver has never heard of a catch can. We, the enthusiasts, are borderline maniacal about clean combustion, clean crankcases, clean exhaust tips, etc.
If you live in the normal world, every single one of us looks like a crazy person....the buyers, the sellers, the talkers and the listeners. We can make a case for this stuff to each other but there are millions more who don't care at all.
And you are correct as the vast majority will never see this or be aware.
As far as emissions go I do not care if the squirrels fall from the tree's when I drive by
What is the best setup to keep the engine clean. I'll be adding meth which should get rid of the coking and will change my oil every 2500 miles or so.
Dude there are hundreds and hundreds of cars on the roads with LMR and Lashway breather setups that are essentially identical. I myself run the lashway can just because at the time they were the only vendor that offered the pop on connectors as apposed to welding the LMR fittings. Now of course LMR has the pop ons.
I can tell you the the lashway can has two filters on the exits of the cans and those filters do get dirty from oil fumes and reside. Which tells me there is no suction there. It is a pressure exit, not a suction. However there are filters there for this reason.
And anyone that is comfortable doing so, then it is a free world. By all means run what you want. But if you do NOT evacuate these damaging compounds as soon as they enter the crankcase, then they quickly settle and mix with the oil and are not coming out.
Anyone can prove what I am stating yourself, no need to fight and insult anyone....just look and see and do an oil analysis. It is your engine to wreck, not mine or anyone else's. This is only accurate, verifiable info I am sharing. Not trying to offend anyone or fight with anyone.
So... what is wrong with the UPR Catch Can System????????
My only complaint is that the catch can oil reservoir is so long that I have to unbolt the mount to unscrew and empty it. At 3,100 mi and over 2,800 mi on catch can system I have NO oil in my intake system and had about 2 oz in the catch can.
One thing most of us can at least agree on is that any catch can is better than no catch can. Still, why can't GM do what Ford has done on it's 3.5 TT DI engines and build in a catch can into the valve covers that automatically overflows into the engine???????
Of course, there are things Ford could do better that GM already does as well......
Pick your poison. Ford or GM, open or closed catch can.
This is one Youtube as well:
And a great explanation of why they have the issues:
To answer your other question, you cannot make a air/oil separator more than 20-30% effective or it also traps the damaging compounds that must be removed so your engine lives. As the EcoBoost only evacuates say 5-10% of the time it is running, it is common to see the oil level actually rise with these compounds trapped in the crankcase to accumulate:
http://www.f150forum.com/f70/ecoboos...250722/index5/
And this reply from a Ford dealer also posted on the ecoboost issues:
So no, I would NOT want the issues Ford has as these are caused by improper evacuation. And these compounds are what stay in the crankcase of any system that defeats the evacuation and flushing functions as described. I ask any that have doubts, start searching yourself on all I have stated here...don't take my word for it, and don't be confused by those wanting to not have this info shared.
Thanks guys. That will tell a good story. Look at water & fuel levels alone to start and see how excessive it is along with the soot and carbon your leaving in the crankcase. None of this should be in your engine oil.
You cannot get an engine to last a long time w/out removing these compounds.
RX Dual Check Valve Catch Can and 2013 Ecoboost F150 - YouTube
2014 Ford F150 EcoBoost Catch Can Installation Instructions - YouTube
Ask me any questions if you haven't followed it all. You MUST evacuate and remove these damaging compounds before they can settle in the oil....do some Google searches (weed out the forum opinions the search brings up) and look only at industry or technical papers on this to see.
As for that first pix of oil presumably from an aftermarket catch can, I can only say that my oil has never looked like that.
While some people may have had issues with the EcoBoost Truck engines, only people who abused their EcoBoost car engines have had any issues that I am aware of. While they are similar, there are still many internal and external variations, so as to give the truck more torque.
This vehicle is the best overall automobile I have ever owned, in that it is an over achiever at virtually everything a car can do. It is fast, handles great with Pilot Super Sports & Megan Coilovers, can tow nearly 5,000 lbs and also haul 6 - 6 foot people in relative comfort for a couple hundred miles. Yes, I have had several vehicles that were more fun, and handled better, like my 15' Z51 A8, several other Corvettes, Shelby Mustangs, and even my 2 G8 GT's, but none can do everything a big family needs and still be fun to drive.
And Ford didn't have to beg Uncle Sam for $$$$ to stay in business.
As for UPR Catch Cans... do a Google search and see for yourself.
I personally have not had ingestion problems with the Ford turbo motors but my 2011 Raptor did. Noticed the intake had oil residue but to your point it was a non turbo.
You can go to the Raptor sites and do a search it is documented--may even see posts from me about it from a couple of years back.
http://www.fordraptorforum.com/f24/r...tml#post857714
The car engine in SHO, EB Flex, & Explorer Sport have a maximum towing capacity of 5,000 lbs in Explorer and 4,500 lbs in Flex. Car engine sits crossways and is predominantly a FWD system, with a limited amount of power going to rear. When I referred to the built in catch can in the valve cover I only refer to the 3.5 TT DI engines.
Have no idea about oil ingestion in the Raptor V8 which is port injection. At least with port injection, the intake valve stems/heads get cleaned off by fuel entering the combustion chamber.
Back on topic. I strongly recommend a catch can that is designed for your application, whether it is a DI Vette, or any other type of engine in your motor vehicle. with fuel injection. I have them on all of my vehicles. Arguing over what brand is always going to be a matter of opinion.... NO WINNERS...
I have a question, you don't have a Supporting Vendor designation, yet you post your logo and push your products on this and LS1tech where the rest of us have to pay a good amount of $ each month to support the forums....why are you given a pass on this? Should we all be allowed to do the same and quit paying?
Being a supporting vendor allows the forum to exist and give all members a great place for info, etc. Why not step up like the rest of us and follow the forum rules? Some members have already told be in PM they can PM you and you sell to them, so your skirting the rules here and the other forums we all pay a pretty hefty amount to be vendors on. Can you explain this?
Yes, Mighty Mouse does this full time with selling one product whereas we do not and sell more than 20k products. Is that what you are saying?
If you refuse to leave a voice mail while we are on the line with another customer, no one can force you to. Frustrate yourself by calling multiple times instead of calling once and leaving a message. We are busy. We are not selling just one product and we are not doing this on the side. And a least we are in THIS post giving technical support and yes, with that we are going to push our products. WE PAY TO BE HERE. Problem?
I have reported your post to the admins.
