P0420 - Cat Code ???
Old Oct 19, 2015 | 10:44 AM
JPK_NJ's Avatar
JPK_NJ
Default P0420 - Cat Code ???
Posted in the general forum but not much response, so maybe you tech guys have a better idea. 2014 M7 7K miles. Dealer just rebuilt the manual trans to replace two bad synchros, some rings, gaskets, etc. Got the car back and almost immediately threw a P420 code. Back to dealer, they look over and find no mechanical issues. GM tells them to reset to comp/code, take a long drive, and it appears fine. I take it out two days later and the code 420 CEL pops back on, car running sluggish, loud, probably running rich dumping fuel etc. At the dealer now but no word.
Any ideas?? Could a cat really go bad at 7K?
https://www.corvetteforum.com/forums...bad-at-7k.html
Old Oct 19, 2015 | 04:20 PM
bob guzzy's Avatar
bob guzzy
http://westersgarage.eidnet.ca/obd2%...le%20codes.pdf
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
Old Oct 19, 2015 | 04:25 PM
JPK_NJ's Avatar
JPK_NJ
Right, I know thats the code that came up. But GM told the dealer to just reset the comp last week as a "fix". Then I drove it up around 80-85mph and the thing came right back on . Trying to see what could cause this???
Old Oct 20, 2015 | 08:20 AM
xp800's Avatar
xp800
I recall another member having similar issue. One of the O2 sensors got banged up in an exhaust removal/reinstall. Replaced sensor and all was well. Could also possibly be wiring harness or connector not seated or damaged. They need to drop the whole torque tube assembly for the trans repair, so the exhaust aft of the manifolds comes out. Really easy to smack the O2s the wrong way...
The problem with the other poster is that I believe the O2 was "ok" electrically when scanning, but the guts had been damaged in a way that caused false readings in use. When he removed it stuff was rattling around inside.
edit: found it. Impact wrench killed his O2 and caused the same CEL as the OP. I think the dealer owes you a new sensor...
https://www.corvetteforum.com/forums...post1590289295
Old Oct 20, 2015 | 02:26 PM
JPK_NJ's Avatar
JPK_NJ
Dealer just called and GM authorized a new Cat replacement. Should be done by EOD and then they said to give it a few days for the CEL to clear. Fingers crossed yet again! But surprising a primary cat could fail soo soon, or was just damaged when they pulled the trans out for synchro repair.
Or maybe I just drive too fast!!
Old Oct 20, 2015 | 03:11 PM
Jim Barker's Avatar
Jim Barker
I would suspect damaged or loose plug in on the heated oxygen sensors which are in front of cats and behind cats of the exhaust system. This was probably all removed during trans removal.
To P0420 - Cat Code ???
