Track wheel set up
Old Dec 12, 2016 | 09:45 AM
Flick6468's Avatar
Flick6468
Cruising
Default Track wheel set up
I've just traded my 14 Z51 for a 17 Grand Sport 3LZ. Since I track about 8-10 days a year wanted to know best wheel and tire set up. Been tracking for 2 years and will try my first set of scrubbed slicks this summer. Presently run NITTO. NT01s 18 square
so I can rotate tires. Are 19 scrubs readily available? What is widest I can go without disrupting suspension or availability of scrubs.
Also, what kind of tune can I get to increase HP without voiding warranty?
Old Dec 12, 2016 | 01:10 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
What kind of tire do you want to use? If you are looking at slicks...Pirelli has a 19" slick that is out there so you can go that route.
Hoosier of course has 18 and 19 DOT slicks and R compounds
There is always the Cup 2 tires from the Z07 packages in the 19/20 but tires are going to be pricey.
Did you want to run something like the Nitto tire?
I don't know if you would want to do a square setup on this car. The biggest I have seen personally is a 18x10 with a 315 front tire and a 18x13 with a 345 at the back.
Old Dec 15, 2016 | 08:18 PM
Smart Line's Avatar
Smart Line
let me jump in here with a question, or 2
can i run my C6 zo7 wheels and slicks and does the TPMS sensor work from a 12 to a 17 Grand sport?
its a must to have TPMS working for me !!!
Old Dec 15, 2016 | 08:33 PM
X25's Avatar
X25
Sr.Random input generator
The sensors themselves are quite different, so you'll need to buy 4 new sensors. Besides that, wheels should work.
Old Dec 15, 2016 | 08:54 PM
Smart Line's Avatar
Smart Line
well crap lol when I went from the 07 to the 12 had the same problem....
but i need 12 as i have 3 set's of wheels ...at 44 each plus install thats a pretty penny..
Old Dec 15, 2016 | 09:13 PM
leadville1's Avatar
leadville1
The guys at GT Track Tires get a lot of scrubs, they have the 19" Pirelli's from the Ferrari Challenge cars, There are good tires if you have a trailer and can change tires at the track. I run R888's and they have worn really well.
They increase in lap speeds from an R888 to a Pirelli can be in the 1 to 3 second range per lap and they may last a weekend. I can get 4 or more track weekends out of the R888's to me not worth the pain of mounting and dismounting tires.
Old Dec 15, 2016 | 09:40 PM
Smart Line's Avatar
Smart Line
58 track days in 2016
using 07 Zo6,12 Grand sport,and the trusty Miata ...
NCM,VIR,Summit Point (3 tracks)and Dominion "the new track"
NCM track in Kentucky is great ...we will be there 3 times in 2017 Some of you guys should make the drive (its 10 hrs for me ugh)but well worth it !
Old Dec 18, 2016 | 05:48 PM
djnice's Avatar
djnice
Anymore suggestions on what are good 19" track wheels to run for the 2017 GS? Or should we stick with 18"?
Old Dec 18, 2016 | 05:55 PM
X25's Avatar
X25
I think 18" front, 19" rear wheel sets are the sweet spot. LG has a set, so does Crays (which don't clear Z06 brakes). I went with custom forged wheels for proper clearance of any size brakes, as well as lighter weight and more width. TSW Nurburgring or Interlagos at 18x10.5 square setup is also worth mentioning.
Old Dec 19, 2016 | 10:25 AM
Flick6468's Avatar
Flick6468
Cruising
I actually have set of Speedlines 10.5 x 18 that I have been running on present car. What would be largest rubber I could put on these wheels.
If I go 305 x 30 x 18 would that mess up setting? I run in Race 2 now
so most of Nannies are off.
Old Dec 19, 2016 | 10:16 PM
lobsterroboto's Avatar
lobsterroboto
2020 Corvette of the Year Finalist (track prepared)
C7 of Year Winner (track prepared) 2019
What is race 2?
Is that a new PTM mode on newer C7's?
for PTM I only have wet -> dry -> sport 1 -> sport 2 -> race
or just "off"
Old Dec 20, 2016 | 01:43 AM
X25's Avatar
X25
I've been running 315/30/18 NT01 tires on my front 18"x10.5" wheels with good results. I do have 325/30/19 rears on 19"x11.5" wheels.
To Track wheel set up
