Reduced Engine Power warning at track
Old Jul 28, 2017 | 03:03 PM
  #121
onfire's Avatar
onfire
What ? Recalibration? Whodathunk ? I wonder if they will use the prior years map sensitivity table I posted.
Old Jul 28, 2017 | 03:54 PM
  #122
goshendad's Avatar
goshendad
I don't know. It will take a couple of weeks I am told. I should know the timing next week after their meeting on Tuesday. I don't know if I will ever know. Maybe I will ask!
Old Jul 28, 2017 | 11:29 PM
  #123
5thGear's Avatar
5thGear
Not sure why it's so complicated. Have the dealer replaced the MAP sensor?
Had the same issue with my 2017 Z06. Every time at the end of warm up lap. At the beginning it was a headache to find the root cause. The dealer replaced the MAP sensor and never had this problem again. Been to 4 track days since and car runs flawlessly.
Old Jul 29, 2017 | 08:23 AM
  #124
Z51Fan's Avatar
Z51Fan
Default Great News
This is great news. Sounds like GM has found the issue & is stepping up to the plate.
Old Aug 4, 2017 | 11:39 AM
  #125
onfire's Avatar
onfire
Any updates from GM ?
Old Aug 4, 2017 | 12:02 PM
  #126
goshendad's Avatar
goshendad
[QUOTE=onfire;1595289403]Any updates from GM ?[/QUOwTE]
waiting on approvals in GM for recalibration.
Old Aug 4, 2017 | 12:24 PM
  #127
davepl's Avatar
davepl
Update: Recalibration is required. GM has determined that the 2017 Z06 needs re-calibration. Meeting next Tuesday to obtain approvals. This will take a couple of weeks to get approvals done. I will wait and then test the car again at Pocono to verify.
Sounds like they "found the bug". That's encouraging. Too bad we'll likely never know what it was (unless something shows up in a table, but I'm going to speculate this will be outside the calibration tables).
Old Aug 5, 2017 | 10:31 AM
  #128
Chalky's Avatar
Chalky
St. Jude Donor '08-'09-'10
Default P0106 at cold startup
FWIW, just found this thread. I have 2016 M7 and experienced this code on a cold start while backing out of garage recently. Car has never been tracked. Running Mamo TB and filter. Approximately 5000 miles at time. I cleared code and no problems since clearing.
Old Aug 5, 2017 | 04:05 PM
  #129
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Sorry you had to go thru all this, I too had a similar fight with the P106 code on my M7 17 Z06, but I only got the code once I went with a a CAI... I'd been to 170+ plenty of time with out code before intake...
It would set the code at about 137 in forth, if I really loaded it up, might set in third, but usually forth.
I went a head and tuned it out, shut if off and told it not to report with HPT. Problem gone.
I spoke with GM techs at SEMA last year, and they told me the "air flow range" is tighter on the 17s. Maybe GM got tired of "popped" motors from bolt ons, and made it harder to do it on the 17s.
Since I was tuning, I went ahead and did the 15% overdrive as well as ported the snout and TB. Just added Long Tube headers, yet to get the the dyno since Header install, but the car seams to SCREAM nicely at part throttle, don't want to get into it too hard till updated tune is done next week...
Old Aug 5, 2017 | 04:16 PM
  #130
Swaglife81's Avatar
Swaglife81
Cruising
Is it possible to make a copy of all the various perimeters in the tables. Fuel temp, timing, maf voltage, 02 readings, spark, etc, with the stock calibration in a program if they make a make a TSB to be able to match against a new program. I would be curious to see the issue instead of a super secret recal.
Old Aug 5, 2017 | 05:07 PM
  #131
goshendad's Avatar
goshendad
that is great info. After all I went through with my 2016 I want to keep a warranty. I may ask GM to let me do headers and tune and honor the warranty. After all I let them test my car and helped them realize the issue right?
Old Aug 5, 2017 | 05:09 PM
  #132
goshendad's Avatar
goshendad
I will certainly ask what they changed when done but I have no way of getting that info myself. I could if I would
Old Aug 5, 2017 | 06:12 PM
  #133
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
I certainly would!!
Old Aug 7, 2017 | 06:58 PM
  #134
rikhek's Avatar
rikhek
MAP sensors, plural, are not the problem. The car has 2 MAP sensors. My dealer replaced both of mine at the direction of the Tech Center and it did not solve the problem.
Old Aug 13, 2017 | 09:37 AM
  #135
goshendad's Avatar
goshendad
Bulletin is done and the dealers should have the recal shortly to reflash the ECM to eliminate the CEL and reduced engine power at the track (p0106).
Old Aug 13, 2017 | 11:05 AM
  #136
breakskeet's Avatar
breakskeet
Originally Posted by LG Motorsports
just finished another Calloway LG Cooling package. It was having similar issues. Solved as we speak.
LG Motorsports
Are you saying that the Callaway Z06 pictured was going into reduced engine power as well at approximately 170 mph with normal coolant temps? How would your cooling solution fix this? The problem that the OP is describing seems to have nothing to do with the well known C7 Z06 cooling issue and track use.
I think your cooling solution is what GM should of done in the first place on these cars. I would definitely have it if I was tracking my car.
Old Aug 13, 2017 | 12:19 PM
  #137
goshendad's Avatar
goshendad
the issue has nothing to do with overheating or high intercooler temperatures.
To Reduced Engine Power warning at track
Old Aug 13, 2017 | 01:07 PM
  #138
djnice's Avatar
djnice
Is this a recall for all 2017's or do you need to show you have had the CEL? Do you think it will apply to already built 2018's as well?
Old Aug 13, 2017 | 01:49 PM
  #139
breakskeet's Avatar
breakskeet
I know that because I have read your entire thread and nowhere in it have your temperatures been elevated to a point of concern to cause a reduced power setting. The reason for my post was to enquire about LG Motorsports post regarding having this problem on a Callaway Z06 and fixing it with their cooling system. I don't understand the correlation if there installation does not require a tune. Just wanted some clarification from them.
Old Aug 13, 2017 | 07:04 PM
  #140
goshendad's Avatar
goshendad
got it thanks.
