Kook Headers & X-pipe Install Help
Old Sep 15, 2017 | 10:05 AM
walleyejack's Avatar
walleyejack
Originally Posted by lakemg
Here's a reasonable video with some pointers: https://www.youtube.com/watch?v=JMOf26YiWM0
On edit: I don't remember needing to remove the starter to get the Kooks installed, so you should be good too. Mine is a 2015 Z51.
I did mine using race ramps in the front and some wooden blocks to keep the rear off the ground along with multiple jack stands to keep things safe. It was still low enough in the front to access components in the engine compartment:
are you saying or showing us you gained 30 hp ? is this with or without a tune, i don t want to tune yet. if it is not tuned what would you predict, 15hp maybe ?
TIA
Old Sep 16, 2017 | 06:26 PM
lakemg's Avatar
lakemg
Nope, I've never said/claimed to gain 30 HP. I never dyno'd it stock and haven't dyno'd it after the header install so I have no data to claim a net gain. Additionally, I'm running the stock tune still. I believe that I have read instances on the forum where guys have claimed a 15 or so HP gain with just the addition of the headers with stock tune. Even if you gained 15 HP, that's a little over a 3 % gain. Quarter mile times and dyno measurements might measure the increase, but I don't think the butt dyno is sensitive enough to feel it. I know that I can't feel it. I only added my headers to make it sound better.
Old Sep 16, 2017 | 06:38 PM
walleyejack
Right on. I didn't mean to insinuate that you made 30 horse I read too many threads on this song I was just asking more or less but to spend that kind of money for 15 horse I don't know if it's worth that
Old Sep 16, 2017 | 07:39 PM
chefcg1's Avatar
chefcg1
C7 of Year Finalist (performance mods) 2019
You really need a tune to get the most out of a header install. Since the dealer will flag your car anyway if you have any drive train Warrenty claims you should just pull the trigger and do a tune.
Old Sep 16, 2017 | 09:24 PM
lakemg's Avatar
lakemg
I gotcha...I was hoping that I hadn't misstated something on here.
The cost is definitely not worth it for 15 HP, but for me it was worth it for the beautiful exhaust sound. It puts a smile on my face every time I mash the throttle...
Old Sep 16, 2017 | 09:32 PM
lakemg's Avatar
lakemg
You are spot on with respect to getting the most HP increase with the tune. From the various hearsay on the forums, I've gathered that if you have a tune, there's pretty much a 100 % guarantee that they will flag your warranty. If you have mods but no tune, I've gathered that there is still a chance they will honor your warranty. For me, it isn't worth tuning it at this point for the HP increase and 100 % chance of warranty denial.
Old Sep 17, 2017 | 03:46 PM
walleyejack
I agree somewhat, i have 20k km on it in a year, and am thinking if i have had no problems with km in a year, i think i am good to go. But would like to see 30 or so + to.make it worthwhile to me
Old Sep 17, 2017 | 10:49 PM
brettmess24's Avatar
brettmess24
You will get that from headers and a tune.
Old Sep 23, 2017 | 12:52 PM
Chazzmania's Avatar
Chazzmania
Started coating everything hopefully, I can get them on this weekend. What's the typically install time using car ramps?
Old Sep 23, 2017 | 01:13 PM
vtmike24's Avatar
vtmike24
With 2 people and a lift it took me every bit of 14hrs, but I also installed a corsa extreme exhaust so I had a bit more work.
Old Sep 23, 2017 | 01:25 PM
Chazzmania's Avatar
Chazzmania
Wow hopefully everything works out and I can get them on fairly quickly. I am so ready to hear the difference.
Old Oct 12, 2017 | 06:12 AM
Chazzmania's Avatar
Chazzmania
Ok so got everything in place but I have a small gap on the drivers side between the header and mid pipe which is enough to cause a small leak. Doesn't seem like there is much more room to move the pipe any. Does anyone have an ideas or maybe I am missing something. If someone could possibly post a pic of there install under the car might help out as well. I am gonna fool around with it when I get off to see if I can figure it out.
Old Oct 12, 2017 | 12:41 PM
  #33
vtmike24's Avatar
vtmike24
It took me several tries of putting the mid pipe on and taking it off to get it right. I ended up pulling the joint at the x-pipe apart slightly to move the entire mid-pipe closer to the header. I then adjusted the left and right cat pipes individually to get them to line up with the header. My driver's side had a great connection and my passenger side had a good fit, but it wasn't perfect. I had an exhaust leak at that joint so I ended up buying RTV gasket maker to help seal up the connection. Been good to go ever since. I ended up using the RTV gasket maker on several connection points to seal exhaust leaks.
Old Oct 12, 2017 | 01:10 PM
  #34
Chazzmania's Avatar
Chazzmania
Thanks for the tip, do you have any pics of how you actual and where you applied the gasket?
Old Oct 12, 2017 | 08:43 PM
  #35
vtmike24's Avatar
vtmike24
Sorry, no pics. I just applied a ring around the outside of the inner pipe at each slip joint if that makes sense.
Old Oct 12, 2017 | 10:20 PM
  #36
brettmess24
How big is the gap? When you put the ball type clamp on does it pull it tight?
Mine did the same thing and I had to pull the mid pipe and tighten the header clamp would have been nice to have a helper.
One of the biggest reasons I love kooks as that ball and socket connection is much better than a slip fit imho...
Old Nov 19, 2017 | 08:39 PM
  #37
walleyejack
i would like to know how you get the damn O2 sensors disconnected. impossible to reach from the top and too tight to in from the bottom, you take the cat off first and lower it down ?
To Kook Headers & X-pipe Install Help
Old Nov 19, 2017 | 09:09 PM
  #38
vtmike24's Avatar
vtmike24
I lowered the cats to get them out. I put the cat in a vice and used a breaker bar. There is a special socket you can use to remove the O2 sensors.
Old Nov 19, 2017 | 09:35 PM
  #39
Chazzmania's Avatar
Chazzmania
It is tight there if you can get your hands up by the O2s. They are attached to a plastic clip. If you can get that clip off that will drop the wires some. Then push up on the grey plastic clip, then disconnect the wires. Once they are disconnected you can drop the headers. Just be patient and not rush it so you don’t damage the wires.
Old Nov 19, 2017 | 09:54 PM
  #40
brettmess24
I unbolted my cats from the manifolds. Only way to get the manifolds out.
Make sure you bolt your longtubes on with o2 sensors in place.
