Z06 Cam Install
Old Sep 26, 2018 | 03:01 PM
Kazman1960's Avatar
Kazman1960
Originally Posted by Rdubfalco
Any results on this build?
Are you asking 2017Z06 or me? i have my results in
Old Sep 27, 2018 | 12:52 PM
Rdubfalco's Avatar
Rdubfalco
The OP!! He's doing a significant build and would like to see the results.
However, if you have results on your setup I'd be interested in knowing since OP has not updated yet.
Old Sep 27, 2018 | 01:02 PM
Kazman1960's Avatar
Kazman1960
Hi , sure no problem , however , my build was not as significant . I had the pro charger F1A 94 , BTR cam ( lifters and push rods and other bits ) , Low side fuel, upgraded Meth from double to triple nozzle ,15% crank pulley to up the boost . Total boost is now just over 16 psi . However , we are maxed out on fuel again . The tuner informed me if i wanted to get the car to higher levels i would need to go Port injection . Just look at the torque , pretty high for a Centri type blower . Car drives / behaves OK , has a little bit of surge ( i think due to the cam install ) until you get up to cruising speed , however , if you want to race , you don't feel the surge .
Old Sep 27, 2018 | 01:21 PM
Rdubfalco's Avatar
Rdubfalco
That's a pretty nice setup, I bet the port injection isn't cheap. You're A8 I'm guessing. Maybe the surging is in the tune possibly?
Old Sep 27, 2018 | 01:58 PM
Kazman1960's Avatar
Kazman1960
Nope . M7 , the surge is nothing major its just there , once you know how it reacts you can drive around it so to speak .
Old Sep 27, 2018 | 04:00 PM
Rdubfalco's Avatar
Rdubfalco
Even better!! Stock clutch or upgraded? Quarter mile?
I heard that a ported stock Throttle body can help with all the surge, but not sure. Maybe others can chime in.
Old Sep 27, 2018 | 05:29 PM
Kazman1960's Avatar
Kazman1960
I think this is what people mean when say when they want a "streetable" cam .
The installer / tuner told me this before it was done .
He said to go for something "streetable" which is what we ended up doing .
Its like the car wants to go get up go at low speeds hence the little surge
Old Sep 28, 2018 | 11:18 PM
Rdubfalco's Avatar
Rdubfalco
How bout your clutch? What are you running? Stock? Aftermarket? How does clutch feel at that power level WOT pulls.
Old Sep 29, 2018 | 10:10 AM
Kazman1960's Avatar
Kazman1960
Still using the stock clutch . I had bad luck with an aftermarket clutch on an earlier car so stock until it dies . As for the power , owing to the car now having a pro charger , I feel that the power comes on more "progressive" than say the punch in the back from a PD type blower . In my opinion , you don't shock the clutch or drivetrain as hard with this set up . Time may prove me wrong but ,we'll see .
Old Oct 4, 2018 | 12:27 AM
PureSwank's Avatar
PureSwank
Originally Posted by 2017Z06
Well I have my car going into a shop to install the following this week:
Katech K 1 force cam shaft
Katech ported supercharger
Katech ported supercharger snot
Katech ported heads with new lifters and timing chain
PSI high lift valve springs
Katech 103m throttle body
Katech valve painted cover with relocation kit
MSD spark plug cables
Katech spark plug covers
Katech valley delete cover
New spark plugs
Meth kit
Griptec 2.40" supercharger pully
ATI super damper
ATI 15% overdrive supercharger drive pully
Tune of engian and transmission
How much does a package like this usually go for bud?
Old Nov 24, 2018 | 09:56 PM
2017Z06's Avatar
2017Z06
Install with materials was 13k
made good power thinking of upgrading my supercharger to magnuson that I wont have to modify my hood to gain a bit more power.
great build
Old Nov 25, 2018 | 01:07 PM
Rdubfalco's Avatar
Rdubfalco
great build
It's been awhile since you started the thread, was wondering how it turned out. Can you share details on build? i.e. rods/pistons, the shop that did build/tune? Also what were your results? Why did you decide to rebuild or upgrade the motor? thanks.
