C7 for the track?
So who are the track experts here these days?
-How does the Z06 hold up under heat/ hard flogging?
-Weekest links on the car for the track? Overheating, tires, brakes?
-What are the big consumables?
-r comp Tire availability?
-how does GM feel about warranty on tracked cars?
Any other thoughts would be great from those that seriously track a C7 and tia.
I also changed the grill to Z06 for more airflow and added the extra brake cooling along with Ap racing discs
Each of the manual models come with an differential oil cooler and transmission oil cooler. The secondary radiator is either stock or can be added in the Z51, GS or Z06. As far as I know the ZR1 has all the cooling required right out of the box. The A8 models come with the diff cooler and two transmission coolers, one in the rear where the M7 cooler is located and one in the front where the Z51, GS and Z06 M7 cars have the secondary radiator. All of the cars have much better brakes than any of the C5s, the C6, Z51, and Z06 (non Z07 version) came with. The C7 GS Z07, C7 Z06 Z07 and ZR1 come with carbon ceramic brakes which are great but have very high consumable costs. I swapped my ceramic brake system to the Essex AP Racing BBKs front and rear and actually broke even on cost when I had to replace the front rotor rings the next time. With the rears I broke even on cost the day I replaced the rear ceramics.
2015 and 2016 M7 Z06s make great track cars as long as you add the GMPP Secondary Radiator that GM made standard on the 2017 models. They run long and hard at lots of tracks around the country. The 2017 Z06s also had a slight supercharger modification that improved the charge air cooling for the rear two cylinders of the engine which typically have higher combustion temperatures. The cooling bricks inside the S/C were tilted which required adding a taller lid to the S/C and changing the under hood insulator. That is why people recommend the 2017 models over the two earlier models.
The Z06 A8 cars tend to cause engine over heating due to running the engine in lower gears to maximize performance. People either over heat the oil or over heat the coolant. GM says to manually shift the car and to limit rpms. Some people interpret that as short shifting but I interpret that as running the car like I would an M7. Don't use the lower gears at all. The M7s can operate on most tracks using 3rd and 4th gears with some usage of 5th on long straights and occasional usage of 2nd on low speed corners but in most cases they are 3rd and 4th gear cars. The A8 has two similar gear selections which I believe are 4th and 5th but could be 5th and 6th. Like all Corvettes the Z06 has a large low end torque value. However, what most people don't realize is the torque value is stupendous compared to others beside the ZR1 which is insane. Torque doesn't make you go faster but it does generate the HP that does make you go faster so lots of low rpm torque generates more low rpm horsepower.
The iron brake systems that come on the cars seem to do fairly well under track duty but if running a lot of events I would upgrade the Z51 brakes to the GS/Z06 iron version for track duty at a minimum.
Tires you have a huge selection depending on which model you choose and what wheel size you choose. The GS Z07, Z06 Z07 and ZR1 track package all come with Michelin Sport Cup2 Run Flats which seem to be a damned good track tire but expensive compared to what is available in the used race tire market.
As Fleming explained these cars are heavier than previous models and that shows up in consumable costs as well. A Z06 run hard at VIR can get through maybe 30 minutes of track time before requiring 18 gallons of gas.
Bill
Weakest link is definitely cooling on the track, which is pretty typical for Corvettes. It's not really an issue on Grand Sports or Z51, but the GS is vastly superior to the Z51 on the track in terms of performance and reliability. Other than cooling, I'm not sure they really have a weak link. I haven't found it, if it exists
Consumables are the same as any other car. Tires, tires, tires, and brakes. Carbon Ceramic brakes are expensive. Steel rotors (GS/Z06) aren't that bad, but not great. $350/rotor ring is about right. They take some abuse though. I probably got 20 hours on mine and they're still good on tracks that are HARD on brakes and I'm running very aggressive pads. I'd definitely say you should add the OEMZ07 cooling ducts. They're only $80 or so.
Unless you're in a class that limits your wheel options, most opt for 18's and run R888R, NT01 or Hoosiers. They're all available in 315F and 335(or 345) rear.
The Competition seat isn't much better than the touring seat so don't bother. Just get a true race seat. Head room with a helmet can be an issue for people above 6'-2" ish with factory seats.
edit: Alignment seems to be the biggest hassle. Finding someone to adjust rear caster can be a pain.
Bill
Bill
2017 updates or not, you're going to be staring down cooling problems in a Z06 on a hot day. A lot of it probably has to do with the track you're running on, but on hot days, it will get very hot.
Any thoughts on tire wear for r comp or R7's? I only get 5-6 sessions with my current car and looking at alternatives that are easier on tires, but doesn't sound promising.
Bill
Bill
