NPP engine sound management question
Old Mar 8, 2020 | 02:19 PM
johny125's Avatar
johny125
Default NPP engine sound management question
When I try to change the tone of my exhaust on my 2014 Stingray and enter the infotainment center under settings, I enter the Engine Sound Management screen, but the drop down menu with the selections, ie sport, track etc, does not appear. Does anyone have any idea what is going on and how to correct it? Thanks
Old Mar 8, 2020 | 02:30 PM
Maxpowers's Avatar
Maxpowers
Do you have NPP? Try pulling fuse 42 for open exhaust 100% of the time. I believe 2014s had a different menu setup than later models but i could be wrong.
Old Mar 8, 2020 | 02:32 PM
johny125's Avatar
johny125
Yes, I have NPP. The menu used to pull down and I could select. I am currently stuck in "sport" mode.
Old Mar 8, 2020 | 08:02 PM
dbaker's Avatar
dbaker
I think this is correct.If not...let me know.
\db2
NPP Fuse #41 (2014), #42 (2015 - 2018), #87 (2019).
Old Mar 8, 2020 | 08:08 PM
RonC7's Avatar
RonC7
The menu for sound management on 2014's was AUTO or OFF. AUTO _ Link to Drive mode. OFF = Track.
Fuse numbers / years listed above are correct.
Ron
Old Mar 8, 2020 | 09:24 PM
johny125's Avatar
johny125
Thank you all!!!! I now have the answer. John
Old Mar 9, 2020 | 09:33 AM
JMII's Avatar
JMII
Originally Posted by RonC7
The menu for sound management on 2014's was AUTO or OFF. OFF = Track.
Correct - and "auto" is basically Link-To-Drive mode where the exhaust sound is unique for Tour, Sport and Track modes.
This is most comprehensive NPP post I've found around here: https://www.corvetteforum.com/forums...ck-result.html
Old Mar 16, 2020 | 09:11 PM
tzoid9's Avatar
tzoid9
\db2
I do believe this is correct, but I have a second question. Does it matter if the engine is shut off or must it be running when you pull the fuse to get the full open exhaust affect?
Old Mar 17, 2020 | 08:34 AM
dbaker's Avatar
dbaker
Not sure about that.When I picked mine up at the dealer,first thing I did was to pull #42 on my '17.
I would just pull it while it's off.
\db2
Old Mar 18, 2020 | 11:53 AM
BLACKCREEK's Avatar
BLACKCREEK
The valves are powered closed they open when no power is applied. It takes about a second for them to close after start so you get a loud bark at start up.
Old Mar 18, 2020 | 08:36 PM
tzoid9's Avatar
tzoid9
\db2
Did what you suggested and just popped the hood and pulled fuse 42 out with my fingers. Started it up and just ran 50 miles. Works perfect, exhaust was open the entire way, accelerating or cruising and no codes, whatsoever. Just a little stronger sound, but not obsessive, in my book. My only other wish, which I believe is impossible unless I replace the system with an aftermarket system, I wish all 4 of the exhaust pipes breathed, especially in colder weather when you can see the exhaust. Oh well. I guess there's always something!
To NPP engine sound management question
