E85 Questions
Old Nov 19, 2021 | 04:29 PM
  #61
Internets_Ninja's Avatar
Internets_Ninja
Originally Posted by aklim
So, sensor, tune and fuel pump. Are the injectors good to go or are we going to be running on the ragged edge?
A Bone stock Z06 may get away with running pump Ethanol (~E70) on the ragged edge.
Old Nov 19, 2021 | 04:32 PM
  #62
aklim's Avatar
aklim
Stock LT1?
Old Nov 19, 2021 | 04:45 PM
  #63
Gary barnes 1098's Avatar
Gary barnes 1098
Stock lt1 no problem Full E85
Old Nov 19, 2021 | 05:26 PM
  #64
aklim's Avatar
aklim
So just sensor and a dyno tune?
Old Nov 19, 2021 | 11:33 PM
  #65
99vetteran's Avatar
99vetteran
What is the gain for the NA LT1?
Mine made 395/410 on 93 and on E70 with tune it made 434/440. My car now made about 460/480 with long tubes, ported lt1 IM/ported lt1 87mm TB. I haven't had it on the dyno since the Ported Msd and stock 95mm TB but we picked up about a 10th in the 1/4 with the Ported MSD/95mm TB so it obviously picked up a few hp and those were under not so good temps around 80 and DA about 2600. Good air and DA it will run maybe some 10.70 or low 80s at 130 mph. I went out a few weeks ago when temps were in the 50s and DA was under 500 and we couldn't get hold of the track, poor prep and about 150 street cars dragging water up to the starting line. Made 2 aborted passes and loaded up and came home. Waste of time and money so I'll wait till spring and give it another shot again.
Old Nov 20, 2021 | 09:58 AM
  #66
Internets_Ninja
Stock LT1?
A stock LT1 can handle pump flex fuel. Still close to the limits but not like the LT4 is.
Old Nov 20, 2021 | 10:04 AM
  #67
aklim's Avatar
aklim
How close do you think and how are the injectors? Just trying to sum up the project so I don't end up screwing myself over by saving $100 today and spending $1000 next year because I should have done something at the time.
Old Nov 20, 2021 | 10:08 AM
  #68
99vetteran's Avatar
99vetteran
Ninja you are right and I have not issues at all with Full E85 when I can get it. My low side drops into the upper 40s going thru the traps and my high side which is turned up a little stays right about 2500 psi. I log every pass just to make we never have an issue of running the rails dry. Ninja you know as a tuner that AFR on these motors is crucial to keeping the motor living and making the most power so we are right at about 12.9 to 13.0 on E so I love this stuff. My injector pulse width is about 4.8 to 5.2 which is pretty much right one point.
Old Nov 20, 2021 | 12:27 PM
  #69
Travlee's Avatar
Travlee
Stopped by the shop and Matt already knew what questions I was going to ask, said he saw this thread
Car goes in on 11/31 for the sensor, dyno tune (price he quoted reflects that the car has already been tuned), and oil change. I will post up the results
Old Nov 20, 2021 | 01:58 PM
  #70
99vetteran's Avatar
99vetteran
Cool we had a conversation on the topic and glad you picked E85. It will be worth it.
Old Nov 20, 2021 | 11:14 PM
  #71
Internets_Ninja
You can run intake and headers and flex fuel on the LT1s and run full pump E(E70-E75) without a problem. When you go true E85 or E90 it is a bit too much for my liking on the LT1 stock fuel system. So as I said, it is close, but you're good with the proper calibration.
Add a JMS booster and things will be even better.
Old Nov 21, 2021 | 12:23 AM
  #72
aklim's Avatar
aklim
For now, I would run just the sensor and a tune. Maybe later, I will change things out more but do you see any insufficiencies with just the sensor and a dyno tune? Without the booster, would I lose anything with a stock LT1 and the sensor and a dyno tune? Do you see any danger? Any gains if I use the booster?
Old Nov 21, 2021 | 08:33 AM
  #73
Travlee's Avatar
Travlee
I inquired about the booster, he said it wasn't necessary at this time
Old Nov 21, 2021 | 08:39 AM
  #74
99vetteran's Avatar
99vetteran
Mine does drop a little more on the low side when I get close to E85, I've not seen a power gain really beyond E65 on the dyno or at the track. I have dozens of logs on this set up and stock internals it just doesn't matter above E65 as it might with more internal mods.
Old Nov 21, 2021 | 10:04 AM
  #75
Internets_Ninja
no issues
Exactly this. E65 is really plenty on the street. The only thing I hate about E60-E65 is that you have to blend the pump e85 here with 93 because we have pretty much E80 at all of our pumps year round. I typically run ~E60 on my daily Z06. I've seen no gains in 60-130 draggy above E60.
Old Nov 22, 2021 | 08:51 AM
  #76
99vetteran's Avatar
99vetteran
no issues
We can't get true E85 in my area, only E65 to E70. I have a VP station about 60 miles from me and he has his own E85 pump mixture that is X98 and 93. I usually buy about 25 gallons of it when I start drag racing and will usually use it when I go to the track and will just run the tank down below an 1/8 and put in a couple gallons on top of that and try to keep it about E74 to E76 for each pass. Low side drops to about 47 psi in the traps but really not worried about that drop for that short of time.
Old Nov 22, 2021 | 09:47 AM
  #77
aklim's Avatar
aklim
I'm not sure I understand since I have not followed this. What is true E85? Are you saying that it isn't E85 or are there different grades?
To E85 Questions
Old Nov 22, 2021 | 09:55 AM
  #78
Travlee's Avatar
Travlee
e85 is about 85% ethanol, it is out there but most are blends. the tuner said that above E60 there isnt really any more power to be made
E85 (or flex fuel) is a term that refers to high-level ethanol-gasoline blends containing 51% to 83% ethanol, depending on geography and season
Old Nov 22, 2021 | 10:15 AM
  #79
aklim's Avatar
aklim
So if the pump says E85, that should be about right then.
Old Nov 22, 2021 | 10:24 AM
  #80
Travlee's Avatar
Travlee
i cant answer that, my guess is it would depend on the station.
