X pipe.
Old Nov 6, 2023 | 02:41 PM
bradNTx's Avatar
bradNTx
I just installed a used Corsa catless X-pipe. It was a fun little project but I'm not sure it was anything close to being worth the cost of the part (and the tank of gas it took to go get it). I'm considering swapping back and selling the x-pipe locally to fund a new V1 G2. I can't tell any difference in sound to be honest. As someone else said maybe a slight increase in cold start which is cool but not worth $500.
Old Nov 7, 2023 | 02:23 PM
kodpkd's Avatar
kodpkd
In reference to the MacA1979 post I just got the original X-pipe off and measured it 3 times, it is exactly 54 inches long from the front flange surface to the back end of the pipe. I thought it was interesting, the rear clamps are welded to the X-pipe. Now waiting for the new pipe, should be here Thursday.
What I am going to check, is the length of slots at the ends of the new pipes compared to the original, obviously these slots need to be covered to prevent leaks. This will also determine how long the new pipe needs to be.
Old Nov 7, 2023 | 02:47 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (stock)
Also, as a reminder, when you put the clamps on to connect the two sections make sure the bolts are located on the top of the assembly. If not on top, then the bolts will hit the tunnel plate. Make sure you tightened them real good because you won't have access to them once you complete the installation.
Old Nov 7, 2023 | 07:00 PM
kodpkd's Avatar
kodpkd
Thank you. I have watched a lot of videos on the X-pipe install. Has anybody cut the bolts shorter so as not to hit the bottom cover?
Old Nov 8, 2023 | 08:26 AM
MacA1979's Avatar
MacA1979
Always Shiftin'
It's not so much the bolt length, it is the highlighted portion of the clamp (pic below) that comes in contact with the tunnel plate. And there is not enough clearance between the pipes and the actual tunnel to have them on the side.
Old Nov 9, 2023 | 12:15 PM
kodpkd's Avatar
kodpkd
I am so excited,,,,, the FedEx truck is coming soon. I am going to measure the length and connect the two half's before getting under the car.
Old Nov 9, 2023 | 01:42 PM
9sec's Avatar
9sec
I would suggest you install the rear section first. use the small clamps. then the front section with the large clamps slid on before connecting the sections. you have to configure the clamps so 1 is on top and the other is at an angle you can tighten the nuts. no room for both on top. at the downpipes remove the springs that come with the kit the bolts aren't long enough to use the springs and get the nuts started. just leave them off.once everything is fitted then you can tighten it all down and have the needed length
Old Nov 9, 2023 | 02:01 PM
kodpkd's Avatar
kodpkd
If I stand both pipes up and they are both the exact same length I think it will be ok and fit correctly.
Old Nov 9, 2023 | 02:52 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
This worked for me. And both clamps for connecting the two sections fit at the top on mine.
Good luck with the installation! Let us know how it goes!!
Old Nov 9, 2023 | 06:37 PM
kodpkd's Avatar
kodpkd
Got R done. My car is still up on the QUICKJACK, waiting for the front fender, it's kind of hard to tell if it's any different. It did seem to rev very quick. I hope the car will be together soon and I can take it for a proper test drive.
What worked for me,,,, Stand both pipes up side by side and make the new two piece pipe match the original. It's important to match the length as well as how the two pieces line up. Tighten up the middle clamps and install it like a single piece pipe. The center clamps can be installed facing up and a bit to the inside so they don't rub against the outside of the tunnel.
Old Nov 11, 2023 | 08:56 AM
MacA1979's Avatar
MacA1979
Always Shiftin'
Got R done.
Congratulations!
