Lifter Problem
Old Nov 8, 2025 | 10:25 PM
  #41
cookk@aol.com's Avatar
cookk@aol.com
1st Gear
Hello! New to the forum. But I recently watched a video wherein the guy claimed that the AFM on the manual transmission only activates if you select "Economy" mode. He claimed the AFM will not activate in Tour, or Sport, or Track modes. I had a 2014 Chevy truck 5.3 motor and it stuck a lifter while it was still under warranty. I realize its not the same engine as the C7 - but I was advised by a savvy local mechanic to get the Range OBD plug-in and stop the AFM from activating. I saw no long term damage from the event - but the truck was at the GM dealer for about a month waiting on a GM rep to show up to authorize replacing the lifters.
Old Nov 9, 2025 | 10:07 AM
  #42
user051728's Avatar
user051728
Originally Posted by Chip E.
I understand the preference for precise terminology. However, within the context of a GM AFM system, the term 'lifter spring' is universally recognized in the automotive community to mean the internal spring responsible for collapsing the lifter. While 'plunger spring' is the more technically accurate name, using 'lifter spring' efficiently identifies the failed component in question, and most English language speakers, in this context, will understand it’s not a reference to a valve spring, nor to a conventional solid lifter:
So, what would you call this component, and why do you oppose the colloquialism—and widely accepted terminology—of 'lifter spring'?
Because it causes confusion, as it did in this thread.
Old Nov 9, 2025 | 10:08 AM
  #43
user051728's Avatar
user051728
Elgin Industries is a leading expert in GM valvetrains. Here’s a quote from them.
The lifter spring will stay compressed to prevent the pistons from contacting the valves. This lifter design is a huge improvement over the old/troublesome design of the active fuel management lifters!”
You can find the quote on this page.
https://northernautoparts.com/afm-li...-00Xe4K6erCW4W
Let me know how it goes when you tell them you know more than they do and they’re using the wrong words that matter.
And? This confusion in this thread is enough evidence to not use that phraseology. And yes, aftermarket companies use wrong terminology all the time.
Old Nov 9, 2025 | 10:10 AM
  #44
user051728's Avatar
user051728
Manual C7 only does AFM in Eco.
I'd avoid a range, it's a hack and frankly has other unknown side effects, if you want to disable it do it via an PCM/ECM tune where you "cal it off"
Old Nov 9, 2025 | 10:30 AM
  #45
aklim's Avatar
aklim
What is the GM term for this spring?
Old Nov 9, 2025 | 10:54 AM
  #46
user051728's Avatar
user051728
Everywhere I've read they only refer to the whole part, and its called an AFM Lifter.
OEMs tend to not have "official" names for anything that doesn't have a customer addressable part number. Since they only catalog parts by a part number, that's the only thing that gets assigned a name. I put "official" in quotes as the service team assigns the names in the part catalog and sometimes you get some weird names. Especially for fasteners.
It's listed in the part catalog as:
Lifter Assembly, Vlv (Afm)
Last edited by user051728; Nov 9, 2025 at 11:01 AM. Reason: Found part catelog name
Old Nov 9, 2025 | 10:57 AM
  #47
aklim's Avatar
aklim
OK. So what you are saying is it comes as a complete unit. IOW, no lifter or spring sold separately? So you can say that "the spring in the lifter failed" or simply put "lifter failure" and be correct, I would think.
Old Nov 9, 2025 | 11:04 AM
  #48
user051728's Avatar
user051728
Exactly.
Old Nov 9, 2025 | 11:13 AM
  #49
Tinkertech's Avatar
Tinkertech
Lifter spring isn't a thing, so we really don't know if he means valve spring or lifter. I mean an AFM lifter isn't a spring, per say (it has a spring component but its not removable).
This is why words are important.
This is the problem. The original poster appears to be new to the forums and possibly to the Corvette world.
If the above is all true, I can easily see him misunderstanding exactually what the repair shop conveyed to him. Terminology and words you know how they work.
An Inexperienced owner that is not mechanically inclined would not know the difference between a valve spring or a lifter spring. Thus, possibly the confusion in his post of the problem. Did he really know and understand all the nuances? In this case I sincerely doubt it.
If it was truly a lifter spring the shop would have stated that he had a collapsed AFM lifter or better, a broken AFM lifter and the unit would need to be replaced, and maybe more parts. I don't believe that the shop would have gone into such a technical description of the issue, especially to just to your every day, non-mechanical owner.
In the everyday world a shop would have reported to the owner that the car had a bad AFM lifter or a broken valve spring. These are the terms that the owner would have had a better chance of understanding.
Old Nov 9, 2025 | 12:23 PM
  #50
Chip E.'s Avatar
Chip E.
St. Jude Donor '16
The only confusion in this thread is a handful of members that can’t admit error in unfamiliarity with industry standards terms and colloquialisms.
Again, while the official GM name for the component is a “plunger spring”, the more common term for the metal compressible component of an AFM lifter is “lifter spring”. Whereas Elgin Industries is an OEM manufacturer for GM as well as others, to cast them as an aftermarket company disparages their expertise in the automotive industry.
While a repair shop advising a failure of an AFM lifter is correct terminology, using the verbiage that a lifter spring failed is also correct and gives insight to the failed component of the specific lifter. Saying the “plunger spring” may be confusing to someone less mechanically inclined or unfamiliar with the components of an AFM lifter, the term “lifter spring” is an accurate description in the vernacular.
In short, colloquialisms exist to build social bonds, communicate efficiently, and reflect cultural identity.
Words matter and understanding synonyms and colloquialisms matter as well. YMMV
Old Nov 9, 2025 | 12:36 PM
  #51
user051728's Avatar
user051728
You're trying to win on a technicality after getting argued with by at least 4 other people. I'd say that speaks enough for its self.
Also many large aftermarket companies also make OEM components. Frequently what suppliers (as we call them at the OEM) use their own terminology which is different than the OEM. So it's an irrelevant statement as to what terms they use.
AFM is a GM specific term anyway. The generic term is DoD (Displacement on Demand). You want to call it a DoD Lifter Spring, go ahead, in my mind you're just being obstinate. I only got involved in this argument when I saw how it was going and felt like it needed some common sense. This also seems to be a foolish thought on my part. Can't fix.... well you know the rest.
Old Nov 9, 2025 | 08:49 PM
  #52
Chip E.'s Avatar
Chip E.
St. Jude Donor '16
I understand you don't like the term, but that doesn't make it 'incorrect.' Language in technical fields is often driven by common usage. 'Lifter spring' is an established industry colloquialism, and its meaning is clearly understood in context.
My purpose here is to share accurate information that can help people. The evidence demonstrates that this term is in common use and effectively communicates the part's function. Insisting on a single 'correct' term, contrary to widespread practice, isn't particularly helpful for a community focused on sharing knowledge.
The idea that terminology you’re unfamiliar with or dislike makes that term incorrect or nonexistent, is childish at best, elitist worst and patently bizarre. I hope your kind of (you know what I mean) can be fixed. Language is constantly evolving, and your belief that the lexicon of knowledge need be blessed by you is also bizarre
