Lets get one thing straight here. Any DCT out there is much slower than a Zeroshift transmission. If any of the transmission guru's on this forum could check out the possibility or probability of the Zeroshift technology being adapted to the 8L90 transmission that would be great. While all the DCT fans are touting the virtues of a 100 millisecond shift time, a Zeroshift is 0. I've seen zeroshift in action on the Honda and Ducati Moto GP bikes and it's dominant. Zeroshift is currently working on some hypercar transmissions. As their web site indicates, there wouldn't be any DCT's on the market had the Zeroshift transmission made it to market first. A DCT was developed by Ferrari early on than enhanced by the various (Porsche, BMW,etc.)companies later. The Zeroshift company is in the heart of Formula 1 country in Milton Keynes. Amazing transmission that would render a DCT obsolete. http://www.zeroshift.com/
My understanding of the Zeroshift is that it replaces the synchronizers on a manual transmission with rings. Since the 8L90 transmission doesn't have synchronizers, how can the Zeroshift rings be fitted to an 8L90 automatic transmission?
I wish the z06 would offer the new 8 speed auto but it won't.
JMO
Because the Audi's engine puts out more torque than Audi's dual-clutch seven-speed gearbox can handle, the RS7 uses an eight-speed automatic with a torque converter to put it's 560 HP and 516 lb-ft of torque to the pavement while accelerating it's porky 4,475 pounds to a 0-60 in 3.5 seconds and taking 11.6 seconds to run 1320 feet.
I would say the above it a good reason why a 585 HP/560 lb-ft Z06 would use a automatic transmission.
Because the Audi's engine puts out more torque than Audi's dual-clutch seven-speed gearbox can handle, the RS7 uses an eight-speed automatic with a torque converter to put it's 560 HP and 516 lb-ft of torque to the pavement ...
On the other hand the 991 Turbo S uses a 7-speed PDK transmission to put its 560 HP and 553 lb-ft of torque (with overboost) to the pavement.
proper manual gearbox only! no grannys in the Z06.. if you want an auto get a z51 and be happy being slower..
How 'bout both?
Auto for track junkies that only care about lap time / e.t., and manuals for canyon runners that blip and shift simply for the joy of doing so?
As far as DCT vs traditional auto, I too prefer the auto. While a DCT can be built strong (modded GTRs), a well designed 8 spd auto can be stronger and lighter, and shift just as quick, with better road manners.
An automated single clutch 7 speed Tremec with Zeroshift technology would sure be hard to beat, even with an automatic. But it would have to be beefed up over the current version in order to hold 700+ lb-ft of torque.
Skank...what happened to the NA 427? I was banking on you!
Sam, I'm still holding out on the NA 427 as that was what I was told by a pretty good source. The latest spoof on the Jalopnik site had a slightly twisted cant of the same info. http://jalopnik.com/an-exclusive-ins...tte-1481913886
Joe, I was wondering how it could relate to Corvettes existing transmissions. I wonder if the Vette engineers have analyzed the Zeroshift technology which is brilliant. Corvette could leapfrog the DCT's with this.
Reading Zeroshift's website, it appears that they are selling rights to use their technology and that existing manual transmissions can be easily re-engineered to a Zeroshift design.
I can see that happening before I can see a DCT going into the Corvette since the existing Tremec is already tooled(other than the Zeroshift components).
They could get the increased performance of zero millisecond shifting but retain the efficiency and fuel economy of the manual without having to retool much of the drivetrain in order to use a DCT.
Joe, That's how I read it as well. Corvette could really leapfrog every other transmission with this. Watching Honda's Moto GP bikes decimate the competition with this was eye opening. They were getting a second a lap advantage at Laguna Seca with this tech.
I've been waiting for Zeroshift to show up in a performance car for over 5 years.... Read about in a Race Engineering magazine awhile ago and seems to be proven. Apparently the Big Car companies are not ready to jump on the Zeroshift technology and I'm not sure why not. Seems like that technology solves any performance question.
Maybe they need to improve how they demonstrate/(smooze) the Big companies R&D Dept's or maybe they are asking for too high a price Licensing their tech?
Regardless of the reason/reasons why it has not arrived on a production car yet, I would LOVE to see Zeroshift on the Corvette.
The irony here is that motorcycle drag racers have effectively been doing this since at least the 80's. I started running a trans like this in 1991, no 'lift' or engine kill was required to make a shift...it was pretty well the only way back then to run 7 second or faster quarters, particularly for the 1-2 shift.
This machining of stock transmission gears coupled with an air shifter and an electronic controller which activated the air shifter at preselected rpm made for what was a completely automatic transmission once you dropped the clutch. The only drawback to the technology back then was IF you slammed the throttle shut without first disengaging the clutch, the force of the rear wheel driving the transmission (instead of the trans driving the rear wheel) would destroy the transmission. This could have been resolved through some kind of free-wheeling mechanism but there wasn't enough demand to develop such a thing.
Generally getting the clutch pulled in before shutting the throttle wasn't a big deal, but of course this was a little harder to get timed correctly IF you got completely out of shape and were mostly concerned with regaining control and not crashing
I doubt id buy another car with a manual transmission. I get absolutely no joy in driving it living so close to Chicago. If they came out with a DCT or something similar, id seriously consider it. Time GM brought the Corvette into the 21st century.
The ONLY folks who would want an automatic are those who never learned how to drive a manual You don't want people to have choices!! Everyone knows that the way that YOU want to do it MUST be the correct way. How utterly immaturely pretentious can you possibly be?
Love it when people make blanket statements like this.
100% WRONG.
I want an auto trans because I have left knee problems from football (long time ago, before they had the surgical techniques, etc. they have now), and although the clutches are much easier to depress than they used to be, I'm not real sure how many "depressions" of the clutch my knee will take.
BTW, in the 70s, every car I owned was a manual trans...
As long as it is still available in a manual, why would the option of an automatic be a disappointment and who would it disappoint?
How does what someone else wants be a disappointment? If someone wants or doesn't want a particular transmission, who does it impact? What's next? The available colors?
Sorry to bring up politics, but this reminds of a quote attributed to Jeff Foxworthy:
"If a Republican doesn’t like guns, he doesn’t buy one.
If a Democrat doesn’t like guns, he wants all guns outlawed.
If a Republican doesn’t like a talk show host, he switches the channel.
Democrats demand that those they don’t like be shut down.”
