Roll racing A8
Received 1,817 Likes
Excuse me, but aren't you the guy, who in another thread, didn't even realize that his A8 had rev-matching?
If have further questions call another dealer!
Your lack of understanding about the simplest of things has been proven over and over to me so I have no wish to argue with you.
Nor do I care what you may "think" is rev matching.
Now go back to tending your pot farm, and try not to waste so much of your potential profits on personal consumption.
Oh my, call dealers for tech information? How lame! In case you failed to notice, I'm in Detroit, which is practically crawling with gen-you-wine automotive engineers.
Maybe ask them why the A8 has the better 60ft over the M7 that is another thing that you have no idea about! Gen-you wine rev matching?
While cruising along push pedal to floor quickly release, the trans will go into performance shift mode it will show up on the display, it drops down to the lowest gear possible and is very aggressive, hang on and go.This is also in the owners manual
The following 5 users liked this post by DRLC5:
3 Z06ZR1 (01-09-2018),
JerriVette (01-15-2018),
jstewart (10-27-2018),
kenownr (11-01-2018),
SharkbyteLT4 (01-10-2018)
Danger!
I raced a Paxton supercharged ACR Viper this weekend in Mexico, https://www.youtube.com/watch?v=ggHg9vTKw4A
Dig
This ^^^
Your illusions of grandeur with the C6Z in every one of your posts is entertaining... BTW, I beat a head/cam C6Z from a 45 roll in my C7Z A8 this weekend...I had a car gap on him by 150... By your calculations, he should have RAPED me....
The A8 on the stock tune is very picky about starting and shifting points. The trick is to pull the shifter down into Manual, paddle to the gear you want to start in, as SOON as you nail it, shift it back to Drive and let it shift itself. If you are starting in 2nd, you can not start faster then 45 mph, even though you have plenty of RPMs, the computer/trans will not complete the 2-3 shift before its on the limiter.
The gear spacing for roll racing is awkward. 2nd gear starts are too high for anything over 45 mph.....And 3rd gear starts are WAY too slow for anything under a 75 roll.... You would think with 8 speeds, roll racing gear selection would be easier but..its not the case.
I raced a Paxton supercharged ACR Viper this weekend in Mexico, he wanted to start from 60 mph, which ended up being 55 mph....I was in 3rd and it just KILLED me on the start...he went through 2nd and some of 3rd before I even got through 3rd.... I still tied him at 143 mph though... He was quite surprised....(as was I...LOL)...Notice how long my car was in 3rd...starting at like 3400 rpms...
If we had gone from a 45 roll with me in 2nd, he would have been in trouble.
THIS..... can’t believe all the other crap posts. This is reality/works
Ajrothm stated, "The gear spacing for roll racing is awkward. 2nd gear starts are too high for anything over 45 mph."
Curious, why would 55 mph in 2nd be too high to start? Wheel spin or near red line already? I know the gearing is way different, but my M7 can nearly hit 100mph at the top of 2nd. I'd like to know what RPM you are running in 2nd @ 55.
I find the performance algorithm method way better than the method most of you guys are mentioning here. I find it too easy to move the level too hard and slap the car into neutral causing you the race.
in the mode i use, the shifts are faster and more harder than the transmission shifting in regular auto mode
#33
exactly what I'm trying to tell people in this thread. I find it too easy when your adrendaline is pumping to push it into neutral by accident.
The following 2 users liked this post by SharkbyteLT4:
kenownr (01-12-2018),
Shinobi'sZ (01-14-2018)
#34
Looking forward to trying some of these things, when the weather warms up enough to give me even a hint of traction.
If the "pedal tromp to downshift and hold that gear" method eliminates the possibility of the next shift failing to execute properly, that's sounding pretty good.
#35
#36
I wish the paddle shifting was better and quicker responding, that way we can control the shift points. I find on the stock trans tune, the trans shifts at different rpms for different gears...sometimes it shifts way early at 6100-6200... then other gears it’s at 6500... it’s weird, but I have gotten pulled before due to an early upshift and it’s annoying.
#37
2017 C7 of the Year Finalist
#38
I agree with the drop of the shifter and once you nail it pop it back into full auto. As far as a stock car, 30-130 starting in second I think is the bread and butter.
#40
What's the trick for getting the A8 into the power band for roll racing?
When I use the paddles to down-shift in auto mode, often the temporary "manual shift mode" doesn't time out soon enough for the transmission to make the next shift automatically, so it hangs on the rev limiter.
I'd rather have the trans in full auto mode after the start of a "race", because that seems to be faster.
Will it work to select "manual" on the console shifter, downshift with the paddles, start the race, and immediately move the console shifter back to Drive? Will that put it back into auto shift mode without any time delay?
Sorry for needing to ask, it's too cold here right now to experiment for myself.
I just leave it in auto and concentrate on hooking up and avoiding any nearby curbs or trees.
