Reached 2.5 Seconds Today
are you talking about that one? Or a different timer?
I didn't see a Pic in the first post of it?
You can't go by the timer...
In my 2023 C8 Z51 it always said 2.8, even when the Dragy was 3.3s.
When it did 3.19, the PDR said 2.8.
I won't even look at the PDR in my c8 Z06.
Sure the in-car PDR will be correct once in a while, but even a broken clock is correct twice a day.
Makes sense on a longer run, 0.2 difference in the 1/4 is a lot different than 0.2 difference 0-60.
123sugey (03-30-2024)
E-Ray, 3LZ, ZER, LIFT
Received 9,677 Likes
23/C8Z (03-30-2024)
Received 2,069 Likes
Also don't know if this test is tied to the Cosworth PRD that uses a video camera and GPS or accelerometers (more likely IMO.) I recall with the latest MRC they went away from the spindly position sensors that were used to provide input for MRC to accelerometers.
"Compared to previous magnetic ride control dampers, MR 4.0 is a revolution, and completely changes how the Corvette adaptive suspension technology and new accelerometers inputs that have a wonderfully complex but fully tunable system."
Yep posted this pic years ago of the older MRC input devices on the "A" frame.
“There are two main things that happened,” Hurley explains (re the latest MRC.. “One is that we went away from position sensors at each corner calculating roll and pitch, to an actual accelerometer at each corner.”
The result is more accuracy, and therefore more exact control for suspension calibration.
“There’s a lot more fidelity there, a lot more precision,” said Hurley. “You’re getting rid of the linkage and the mechanical bits that are involved in a position sensor. You’ve got a much better signal to work with at each corner to start with.”
True AWD like in my Porsche has the ability to send 50% of the power to the front and rear axles if needed.
The Eray only sends 160hp to the front and 495hp to the rear which seems to be enough, more like 25% front 75% rear. Any more horsepower than that and the 160hp would be overmatched IMHO.
p.s.
E-AWD is also hugely different in one key way. Torque. Max torque on ICE will vary based on RPM, gearing, etc. But on a motor, that torque can be all available precisely wherever it is mapped (usually down low, where it will be most frequently beneficial on the front wheels of an AWD car). So conceivably you could be making 150 tq at the rear wheels in a given situation, but the front is churning out 135; darn near 50/50.
The situations where 50% at the front wheels is needed--is a miniscule fraction of driving situations. Anything over 60/40 even--is overkill for most things. Can these things help in situations with wet roads and high-speed cornering? Sure. The rest of the time, you end up with probably more power at the front than you can use.
p.s.
p.s.
Don't get me wrong, if they put the E-ray set-up on the C8 Z06 I would buy it in a second, 160hp to the front is much better than 0hp to the front.
Mine went the "fastest from a Stop to 60!" I posted my pic not knowing if all 2024's had the test or perhaps all but my 2020 C8 as it did not have it!
JerryU (03-31-2024)
Received 7,010 Likes
JerryU (03-31-2024)
Can't wait to get >1500 miles and use Launch Control. And he showed all-season tires! I have the ZER option Summer tires!
#33
JerryU (03-31-2024)
#34
i have the adjustable 4 bar link rear suspension in my street rod set so the "instant center' (look it up in a quality drag race car chassis tuning book like the one from Chris Alston) several feet in front of the car. Adjustable rear coil overs set to offset torque steer for equal tire patch load at launch.........
And a twin turbo C8, as the one in pic I posted, is probably set a good as possible. BUT the C8 does not have a suspension designed for that much power NOR is it adjustable as a quality drag race chassis!!
#35
Looks like 50%+ of ER's have been ordered in gray.
Shinobi'sZ (03-31-2024)
#36
Got to 2.5 Seconds 0 to 60 today! Yea I know can't go by GM's timer BUT on the same 3/4 mile long road, right after I reached 500 miles tried 3 times. All 3 were 2.7 seconds. Thought, have to wait until I get ~1500 miles where I will use what GM calls Boost Shift, putting power through both clutches slipping them for a few milliseconds on launch!
So today's result is interesting as straight, brake, press throttle release brake resulted in reaching 2.5 seconds. What occurred today from the start may be of interest:
- At 10:30 took friend for a short ride. Cloudy and 55F (tomorrow will start the day at 37 and will only be ~50 by noon.) On a 0 to 60 run, rear tire lost traction. With those 345's hard to understand so attribute to my ZER Summer tires and 55 temp.
- Went into town as promissed anther friend who wanted to see the car. Had his staff come out. When I left, they were standing to hear the E-Ray as I took off, rolling at about 10 mph a chirp as a tire lost traction as I accelerated.
- On the ~25 mile, back road trip home kept it in Z-Mode. Noticed it was charging the battery with ~25 hp showing on the gauge. Battery was charging past the 80% max I saw in MY Mode. You'll not in pic, after 30 to 107 and the 0 to 60 test it was 91%,
- Turned onto the 3/4 mile long road near my home, mostly farm fields on the sides, and with WOT accelerated from ~30 mph to 107. Stopped to try a 0 to 60 run, expecting possibly some tire spin. It was 63F, zero spin and dash showed whet you see below. Assume driving in Z-Mode for ~25 miles caused the battery to be at a high % charge as the `80% I saw in MY Mode. Rounding that corner fast and accelerating to 107 probably put some heat in the tires. But no tire sound and this 2.5 second result.
- PS: understand may not be super accurate but same road I tried on 3 times and only reached 2.7 seconds (matching Tim McGraw record of how long he stayed on a Bull named Fu Man Chu! ) As Einstein would say, it's all relative!
"Supposedly" MRC is tweaked for ZER option, does anybody have details on that?
#37
Yep, it definitely gets colder in NC as well other parts of SC. But in the NE SC we have the benefit of the ocean temps moderating how cold it gets. I seldom have to drive when below 40F. Has not snowed in 3+ years and when it did, gone by noon.
Had not heard that re MRC.
#38
on MRC this is noted: "The ZER Package will outfit your E-Ray with the Michelin summer only performance tires and you’ll receive the FED Suspension with Magnetic Selective Ride Control that is programmed specifically to the E-Ray"
#39
Yep that IMO is marketing Hype! At the Steve Garrett Podcast after the last BASH, Tadge, John Holder and Harlan Charles laughed as they said it was the E-Ray is the 1st model where they did not have to change ANYTHING when they went to Summer tires. They usually tell folks can't switch without a compromise as settings, bushing compliance that match tire construction and thread compound etc are different. They said NOT with the E-Ray.
So not sure what the descriptive words mean on the Option List or why there is a different suspension code. Good question to ask at this years BASH!
#40
Tell blogger to edit it as well..
https://www.corvetteblogger.com/2023...y-to-cost-500/
