Sponsored by: Wheel Design
Code name Zerv
Old Jan 28, 2018 | 07:43 AM
  #541
NoOne's Avatar
NoOne
Nothing is rare around here.
Wranglers, Corvettes, Porsche's, etc. are a dime a dozen.
3-4 Ford GT's I regularly see, 2 Veyron's, buncha R8's, someone has a La Ferrari that we see on the weekends.
The La Ferrari is probably the rarest car because I've only seen one but I hear there are 2 owners in the area.
Old Jan 28, 2018 | 08:05 AM
  #542
Shaka's Avatar
Shaka
Originally Posted by firstvettesoon
Several people requested it so...
also fixed a few details. Not sure about the nose fascia wingys...
Still can't figure out his part. There is an outlet on the hood which precludes the Ferrari type out lets on either side of it that you have. At least you are having a blast trying to figure it out.
Old Jan 28, 2018 | 09:21 AM
  #543
Walter Raulerson's Avatar
Walter Raulerson
Originally Posted by LT1 Z51
Jail only results from criminal activity. This would be a civil matter. He could be sued by GM and be responsible for financial damages GM has incurred. And his name would be mudd. But no jail.
People don't really understand the law. Only when you break a law can you be put in jail. Violating an NDA is a contractual issue not a criminal issue. Your employment contract usually contains some sort of NDA.
Uh IF you are CONVICTED
Old Jan 28, 2018 | 01:25 PM
  #544
skank's Avatar
skank
Originally Posted by firebirdfan
*edit* Here's a link to the images. I saved them this morning as soon as I saw them.
*edit again* GM must really not want this stuff online. My imgur album was deleted by someone other than me. Nice try GM, but I have the originals I downloaded from the OP.
https://imgur.com/gallery/H1gyL
These are straight up CAD images from the mid-engine car. This is your C8, people.
Somebody is gonna get so fired over this. Give it 2 hours, this will be all over Jalopnik, Autoblog, and others.
From the images:
-Coil springs (FINALLY).
-Magshocks (or spool valve, either way, fancy shocks).
-Upper front arms look to be similar to C5/6/7 with trunions.
-Lower front arms look to be similar to C5/6/7 with camber eccentrics.
-Rear subframe is HUGE and is a very strange mix of cast parts and welded tube. Can't tell if it's welded or bolted together in the middle.
-Engine is an LT1.
-Looks like factory shorty headers instead of cast manifolds.
-Engine has alternator relocated.
-Not sure what the upper-right accessory pulley is for. Upper left is water pump, lower right is AC.
-Oil filter looks easy to get to.
-Oil cooler clearly shown above filter.
-Half-shafts look to be the "bolt on flange" style (no draining trans to remove shafts).
-That transaxle is BEEFY. Like, dear god. Can't tell if it's auto or manual. If I had to wager, that's the automatic (guessing from shape of bottom of trans and what looks to be coolers hanging around it).
-Giant flat space above transaxle is more than likely for intake box/filter.
-No turbos shown.
-Frame looks to be similar to C5/6/7 with giant hydroformed rails (probably still aluminum). Disappointing. I was hoping for proper unibody. Hopefully with a fixed roof it'll be stiffer.
-Brake rotors are 1 piece. Calipers are MASSIVE.
-Side skirts are mechanically fastened just like C5/6/7. Still going to be horrendously expensive to fix if damaged.
-Brake ducts clearly shown on front.
Guarantee that Tadge is fighting some fires right now.
Can't wait to see this thing released.
It sure does appear that there are MagnetoRhealogical engine mounts(Porsche Tech) that were developed for the 911 on this new C8 ME chassis. What do you think ??
https://www.motorauthority.com/news/...ts-from-delphi
https://simanaitissays.com/2017/08/1...mounts-part-1/
https://www.caranddriver.com/feature...-engine-mounts
http://www.formula1-dictionary.net/d...eological.html
Old Jan 28, 2018 | 02:40 PM
  #545
RedLS6's Avatar
RedLS6
Good catch. Looks very very similar to the Porsche mounts.
Old Jan 28, 2018 | 03:00 PM
  #546
user051728's Avatar
user051728
Um, convicted of what? You aren't convicted in a civil trial. It's not criminal so there is no conviction possible.
In a civil trial you lose the judgement and would be held liable. That's not a conviction.
Again, people do not understand the difference between criminal and civil law.
Old Jan 28, 2018 | 03:27 PM
  #547
Steven Beaver's Avatar
Steven Beaver
All you have to do is check out genius Walt’s Facebook and Twitter feeds to see where his mental state is (or lacks). It’s pure comedy
Old Jan 28, 2018 | 06:21 PM
  #548
Walter Raulerson
A person doesn't go to jail unless they are convicted of braking the law. If you lose in a civil case you have been convicted you lose you pay that's a conviction. Maybe not in jail time but you lose
Old Jan 28, 2018 | 06:23 PM
  #549
Walter Raulerson
Investigated journalism. Another FAN. I use my name not a handle
Old Jan 28, 2018 | 06:27 PM
  #550
Walter Raulerson
Must be a trumper. We can get into it here STEVIE or find where I post
Old Jan 28, 2018 | 06:28 PM
  #551
firstvettesoon's Avatar
firstvettesoon
Who's part?
I agree the Ferrari outlets are/may not (be) accurate. Can you explain what you mean.? But what do you see that precludes it? Are you talking about the center C7 style chevron style camp pad?
Many feel this could be a fake detail so I took the liberty to show another option. May previous versions had the center style vent.
Old Jan 28, 2018 | 06:30 PM
  #552
WKM's Avatar
WKM
Walter looks like you don’t live to far from me.
Old Jan 28, 2018 | 06:34 PM
  #553
Walter Raulerson
Okay
Old Jan 28, 2018 | 06:51 PM
  #554
Walter Raulerson
Please accept my apology for the post that follows I just saw "The Andy Griffith Show' and Andy explained everything to Barney know what? You're right
Old Jan 28, 2018 | 07:51 PM
  #555
Walter Raulerson
Originally Posted by elegant
Originally Posted by Zymurgy
Why does it have such a high tunnel in the cockpit if it is a mid-rear? AWD Possibly?
Torsional rigidity.
Isn't that an age thing?
Last edited by Zymurgy; Jan 28, 2018 at 08:58 PM. Reason: Added missing [/QUOTE] tag
Old Jan 28, 2018 | 08:39 PM
  #556
JerriVette's Avatar
JerriVette
I think I see the dual shafts for the dct transmission ...hope that's what we are looking at.
Old Jan 28, 2018 | 08:44 PM
  #557
Speednet's Avatar
Speednet
Wrong. A conviction is a term only used in a criminal proceeding, not a civil matter.
And it's "breaking" the law, not "braking" like you'd do in a car.
To Code name Zerv
Old Jan 29, 2018 | 08:27 AM
  #558
Latterlon's Avatar
Latterlon
Don’t forget the Louisville Chevy Dude’s leak of the front fenders. They align perfectly with the leaked painted fascia and the last headlight/fender leak from Zerv.
Old Jan 29, 2018 | 10:11 AM
  #559
Atari_Prime's Avatar
Atari_Prime
Well this thread is getting entertaining. Ignoring most of what has been said, Zerv cannot be criminally cited for the leaking anything. If he were taking the photos and selling them to a competitor, it would be possible to go after him for embezzlement but even that would be a hard sell. In short, there is virtually no way a government entity could or would hold him liable. This is a civil matter between Zerv and GM only. No jail, only money and/or injunction...which is not a conviction.
Old Jan 29, 2018 | 10:40 AM
  #560
Jeff V.'s Avatar
Jeff V.
I thought that was proven to be a click bait hoax?
