Nov 13th Software Update
GM appears to stagger it's downloads, as you can see from this thread. So patience is required. Unless of course you car is fairly recent, in which case it might already be up to date.
If you can't get either cellular or WiFi while the car is parked in the winter storage, you would then have to dive the car out to an open area to at least let it connect to OnStar signal. If you do drive it out to do it, download it first, and then when you are ready to install it, make sure you park the car and not driving it, as in the end of the installation the software needs to shutdown the entire system. Unable to do that due to the car is in the middle of driving, may cause the update to fail - or I should say it most likely will fail, based on a few folks comments here.
Looks like a trivial update anyway so not in a rush!
Does anyone know what problem(s) / issue(s) the TCM had that required a software repair?
