Sponsored by: CARiD
Flat crank engine
Old Jan 8, 2020 | 10:45 PM
  #41
Dominic Sorresso's Avatar
Dominic Sorresso
Originally Posted by MitchAlsup
While I have no data on the GM FPC,
A Ferrari FPC is the same as a 4-banger:: up--down--down--up
The Ford FPC is like the Ferrari but cut at the center and one side flipped end to end:: up-down-up-down. This causes a "different" vibration pattern that apparently the Ford block was vulnerable to.
Thanks to both of u for the explanation.
Old Jan 8, 2020 | 11:40 PM
  #42
auburn2's Avatar
auburn2
The ford FPC was nothing but marketing hype. There are really only two advantages you get with a FPC
1. Even bank-to-bank firing. This improves exhaust scavaging and leads to a wider power band if you use equal length headers. Ford screwed this up by not using equal length headers.
2. It allows for smaller and lighter counterweights on the crank. The crank being lighter means it has a smaller moment of inertia and will rev faster. Ford screwed this up by using pretty beefy large counterweights.
The main disadvantage of a FPC on a V8 are 2nd order harmonics which will mean more vibration and fatigue on the engine.
So when you get down to it the FPC does nothing at all for Ford other than offer a marketing gimmick.
The real irony here is the 2.3L ecoboost Mustangs all have a flat plane crank too. For some reason ford didn't bother to put it "flat plane crank" on the valve covers of the 4-banger and make a big deal out of it like they did for the GT350.
Old Jan 9, 2020 | 05:50 AM
  #43
Rkreigh's Avatar
Rkreigh
I think a good strong billet crank like those fancy windbergs hold up just fine at higher rpms. Thanks for the explanation of FPC. Road and track was trying to say that a v8 won't turbo well WITHOUT a FPC and there seems to be so much misinformation about advantages and disadvantages.
For all out racing where a light rotating assembly and that improved scavenging helps at WOT, it's quite a bit of cost for relatively small improvements. So for arguments sake, say on a v8 it's worth 30 HP, I'd chase that HP elsewhere and have a smoother lower NVH engine that holds up better. Ford added so much metal back, that the rotating assembly wasn't light anymore to try and combat the NVH and paint shaker problem with a FPC
I dunno, I just don't see why they are so great for corvette. We'll see if they make it to the street. Ford isn't dumb, and they spent a crap ton of $ to finally decide the juice isn't worth the squeeze go away from the FPC on their new blown steed.
And to be blunt, those fancy ferraris sound a bit flatulent at lower rpms
Old Jan 10, 2020 | 05:19 PM
  #44
auburn2's Avatar
auburn2
Road and Track should tell AMG Mercedes that their biturbo V8 doesn't work well.
As far as racing goes, it makes sense if you have class rules limiting things like displacement or throttle body size or other things you could use to get extra hp. In that case you need to wring out everything you can out of a car within the bounds of the rules and you can't use another method to chase that power. Other than that small case I agree, no reason to have a FPC on a street car.
Old Jan 11, 2020 | 01:08 PM
  #45
Rinaldo Catria's Avatar
Rinaldo Catria
The flat plane will get tested and compared against its cross plane predecessor. By seasons end GM will have a pretty good idea how the two stack up under severe use conditions. Also, I hope theyve torn down a few Ford Shelby GT350 flat planes to figure out what NOT TO DO.. they are costing Ford a mint in warrantee work from what I’ve heard.
Old Jan 12, 2020 | 05:49 PM
  #46
Shaka's Avatar
Shaka
It's shocking that people talk with authority about things they no nothing.
Old Jan 12, 2020 | 07:03 PM
  #47
BJ67's Avatar
BJ67
The FPC design gave Ford high rpm and that helped with the 526 HP from 5.2 liters
Old Jan 12, 2020 | 07:41 PM
  #48
Rinaldo Catria
Fact about the Shelby GT350 flatplane engine: Ford released a supplement to the owner's manual stating that the engine might consume a quart every 500 miles under severe use.
Old Jan 13, 2020 | 07:16 PM
  #49
NY09C6's Avatar
NY09C6
This is the Internet. It is here for our entertainment. Don’t confuse it with real life.
Old Jan 14, 2020 | 10:04 AM
  #50
Shaka's Avatar
Shaka
I keep forgetting. Thanks for the heads up. Jim Hall has a fantastic video where he says the world is very different to a mechanical engineer. I think the supreme court judges should be comprised of retired mechanical engineers. They serve only two years as a service to their country. It is quit disturbing to witness the level of ignorance displayed on this forum. They chase the good guys away. It is always the usual suspects that make it unpleasant for others. I think the cause is total insecurity and low self esteem. Why do they do it otherwise?
I fell much better after our talk. Thanks.
Old Jan 14, 2020 | 11:38 AM
  #51
vndkshn's Avatar
vndkshn
I think another part of it is the invincibility afforded by the Internet. People can say things online they would never say to someone's face. People have largely forgotten how to have a civil discussion of opposing views on the Internet, and it is slowly translating to real life.
Long list of those types of people here, I finally got tired of blocking people, I just scroll past their crap now, not worth getting worked up over and not worth spending the time to block them.
Old Jan 14, 2020 | 08:11 PM
  #52
auburn2's Avatar
auburn2
The high RPM is primarily due to the valvetrain and head design, not the FPC and one of the Ford engineers that designed it even said so in an interview.
If you look at the crank, unlike most other FPC V8s, the weights on the GT350 are not significantly smaller than a traditional crossplane crank. The lower moment of intertia normally associated with smaller counterweights on a FPC is what lets it rev quicker (not necessarily higher).
Old Jan 14, 2020 | 08:20 PM
  #53
auburn2's Avatar
auburn2
Originally Posted by Rinaldo Catria
. The picture of the engine bay above clearly show its not DOHC heads. The horsepower and torque numbers are never a tell under IMSA BoP rules because any type engine can be intake constricted down to the mandated max hp. Years back the Viper ran the full 8 liter displacement but the engine was breathing through a straw. At that time I wondered why Dodge wouldn't have rather destroke or sleeved the engine down to under ~6 L instead but for whatever reason they preferred to nearly suffocate their full displacement mill. I never thought the engines ran very efficiently that way.
The power an engine produces is directly related to the volumetric efficiency and mass air flow rate. Reducing the displacement doesn't do anything, the "straw" can still only flow so much air. Putting a physically smaller and lighter engine will mean less weight to move (assuming you don't have to add it elsewhere) and improving efficiency inside the engine will yeild more power, but using the same engine and port and valve layout with a smaller displacement won't help,, the engine will still be choked.
Old Jan 15, 2020 | 05:51 AM
  #54
Rkreigh's Avatar
Rkreigh
take a close look at the cyl heads and intake and it shows how ford got that hp and can rev to the moon.
they abandoned flat plane cranks and I think while they are great for racing, I can find other ways to get a crap ton of reliable hp other than this extreme.
Old Jan 15, 2020 | 08:35 AM
  #55
Shaka's Avatar
Shaka
If you look at the crank, unlike most other FPC V8s, the weights on the GT350 are not significantly smaller than a traditional crossplane crank. The lower moment of inertia normally associated with smaller counterweights on a FPC is what lets it rev quicker (not necessarily higher).
At last, the correct use of the term, 'Moment of Inertia'. Thank you sir. If only the forum would have an index that each member must refer to before posting their crap. It would be so easy to raise the standard. A page of definitions could be a good start. I have to stop now, lest I be given another vacation.
Old Jan 15, 2020 | 09:20 AM
  #56
BJ67's Avatar
BJ67
True the dohc heads account for higher rpm operation than a pushrod in block cam design. But if you notice the most Ford gets out of there Non FPC engines is 74- 7500 rpm. The FPC engine is 8250 and other non Ford FPC engines all scream 8 to 9k rpm. Do not see this on DOHC engines with a crossplane crank.
Old Jan 15, 2020 | 09:40 AM
  #57
Shaka's Avatar
Shaka
Brake Mean Effective Pressure (BMEP) is the yardstick for comparing the performance of an engine of a given type to another, and for evaluating the reasonableness of performance claims or requirements.
Mercedes F1 team's latest 1.6-litre V6 turbo hybrid produces over 900 bhp and achieves more than 45 percent thermal efficiency. It can even harness heat energy in the exhaust downstream by sophisticated waste heat recovery system, thus achieving more than 50 percent efficiency!!! Toyota's new 2,8-litre diesel engine 1GD-FTV achieved an efficiency of 44%. This is considered to be the highest in the world. Class 8 tractors trailers are close to that. Diesel Electric locomotives even more. The General Electric 7HA and 9HA turbine combined cycle electrical plants are rated at over 61% efficiency.
At the end of the 2014 NASCAR Cup series season, the engines from one major NASCAR engine manufacturer were producing in the neighborhood of 880 HP at about 9000 RPM, and they operate at a max race rpm in the vicinity of 9400 rpm. By regulation, CUP engines have a maximum displacement of 358 CI (5.87 L). They must use a cast-iron 90° V8 block with a 4.500 inch bore spacing and a 90° steel crankshaft. The cylinder heads are purpose-designed and highly-developed, limited to two valves per cylinder, specific valve angles, specific port floor heights, etc.. The valves are operated by a single, block-mounted, flat-tappet camshaft (that's right, still no rollers as of 2014; switching to roller cam followers for the 2015 season) and a pushrod / rocker-arm / coil-spring valvetrain. It is further hobbled by the requirement for a single four-barrel carburetor (until 2011) The fact that, to produce 880 HP at 9000 RPM, requires 513 lb-ft of torque, for a peak-power BMEP of nearly 216 PSI (14.92 bar, torque ratio of 1.43). Peak torque for that same engine was typically about 535 lb-ft at 7800 RPM, for a peak BMEP of over 226 psi (15.6 bar, torque ratio of 1.50). Nothing is even close to that.
To Flat crank engine
Old Jan 16, 2020 | 06:06 AM
  #58
Rkreigh's Avatar
Rkreigh
nascar has taken the development of those engines to another level. some of the super comp guys build little buz bomb sbc and now ls motors that scream up
john lingenfelter made a name by running big bore short stroke dragsters that buzzes to 10k and makes great power. thanks for posting some really interesting info.
I'm also enamored by the top fuel guys cranking out 11k hp out of those nitro swilling monsters.
Lots of ways to make big power, vette is now able to hook it a bit better. I hope the next tremec goes with a bit taller gears to compliment the big torq
Old Jan 17, 2020 | 12:36 PM
  #59
Shaka's Avatar
Shaka
Ford's marketing department. Ford turned “flat-plane crank” into a sexy catch phrase that sounds really impressive to people who know absolutely nothing about engines. Everyone’s talking about the GT350’s flat-plane crank, and you got to hand it to Ford for pulling off one heck of a PR coups that transformed the entire automotive press corps into a flat-plane crank propaganda machine.
Ford designed some badass CNC ported heads for the new 5.2L, but no one’s talking about that. Ford designed the F1-inspired roller finger follower DOHC valve train that makes OE pushrod motors look stupid, but no one’s talking about that. The camshaft profiles and a variable valve-timing strategy that—when combined with the phenomenal low-lift airflow of the 5.2L’s four-valve cylinder heads enables it to produce 24% more torque per cubic inch than GM’s 7.0L LS7 (1.36 vs. 1.10), but no one’s talking about that. All of these factors play a far more substantial role in both the 5.2L’s specific output and high-rpm capability than its flat-plane crank, but no one’s talking about that.
Old Jan 17, 2020 | 12:40 PM
  #60
vndkshn's Avatar
vndkshn
And didn't Ford stray away from the standard "flat crank" design in terms of firing order? I haven't found hard evidence (such as firing order combined with Ford's cylinder numbering versus say Ferrari's), but I've read that several times. Makes me wonder if that is the reason for the issues.
