Sponsored by: CARiD
C8 jacking
Old Dec 4, 2019 | 07:45 PM
sixth_one's Avatar
sixth_one
Cruising
Default C8 jacking
I have a set of aluminum jacking pucks that I used for my C-6 Corvette. Will these work with a C-8?
Popular Reply
Dec 29, 2019, 01:39 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Originally Posted by NoSoupForU
Where is the pic of the underside of the car showing the C8 jacking points?
Hard to see but I circled.
Old Dec 4, 2019 | 08:31 PM
BIG Dave's Avatar
BIG Dave
Maybe. Someone will need to take delivery of a C8 before you can get an answer.
Old Dec 4, 2019 | 09:32 PM
dmaxx3500's Avatar
dmaxx3500
I just drive mine up on a 4 post lift,and use the center jacks
Old Dec 5, 2019 | 01:56 PM
JerryU's Avatar
JerryU
Hope one of my 3 sets of pads work! The slots are probably the same size as the car carries use them to hold down the car! However found my correct size per the C7 Owner's Manual, 2 1/2 inch diameter Katech aluminum pads were too tight in one slot of my Grand Sport. A grinder took care of that!
Note, had 3 inch diameter aluminum pads for my C6 but in one frame slot it hit my 2014 C7 composite panel, probably why the C7 Owner's Manual says use max 2 1/2 inch pads. Hockey pucks can work as the eye hooks most use have a thin shaft that can be pushed to one side of the frame slot!
Considering where the C8 engine drain plug is located, looks like jacking the rear only will have it slop to that area so no need to lift front and rear for an oil change.
Most of my 2014 C7 slots cleared the composite rocker with my 3 inch diameter pads BUT one did not. Bought the recommended 2 1/2 inch diameter pads.
Even if you have a lift or "Quick Jack," etc need pads as most dealer techs don't use them and tire shops don't have them. You risk having your composite rocker panels cracked! First time I brought my C7 to the dealer to have the dif oil level checked per a GM notice, mentioned to the service writer who I knew well from my C6, to be sure the tech used the 4 lifting pads I had in a clear plastic bag on the passenger seat- my usual MO with my c6. She said, "Don't worry I will insist they use our alignment drive on rack as we just cracked a Corvette rocker panel and it's in the body shop being repaired! They have one alignment rack and ~18 center post lifts with arms. Most tire shops use center post lifts as they want the tires unsupported so they can get to all 4 wheels!
Old Dec 5, 2019 | 03:35 PM
Katech_Zach's Avatar
Katech_Zach
Premium Supporting Vendor
C7 of Year Finalist (track prepared) 2019
I'll try to put one in a C8 at my earliest opportunity.
Old Dec 5, 2019 | 05:50 PM
Ragtop 99's Avatar
Ragtop 99
C6 jacking puck for those who live in NHL areas. I trust they will work on the C8.
Old Dec 6, 2019 | 12:22 PM
Young_Z06's Avatar
Young_Z06
I know no one probably knows the answer to this as no-one has the car yet and few have even seen it but any chance anyone is aware of the distance between the jacking points
Old Dec 6, 2019 | 12:33 PM
sixth_one's Avatar
sixth_one
Cruising
Columbus Blue Jacket pucks will work better.
Old Dec 6, 2019 | 08:29 PM
richie427's Avatar
richie427
Na, NYR... With a 3-2 win.
Old Dec 9, 2019 | 01:34 PM
NoSoupForU's Avatar
NoSoupForU
Old Dec 27, 2019 | 11:50 PM
GTS Bruce's Avatar
GTS Bruce
I made my own lift pads out of a stock pen mat. You can cut them to any shape or size and double up.
Old Dec 29, 2019 | 12:38 PM
elegant's Avatar
elegant
I confirmed with Josh Holder that the C7’s jacking pucks will work for a C8.
Old Dec 29, 2019 | 01:39 PM
JerryU's Avatar
JerryU
Old Jan 8, 2020 | 07:03 PM
sparro's Avatar
sparro
Toronto Maple Leaf's pucks work best.
Old Jan 10, 2020 | 07:51 PM
BadAV's Avatar
BadAV
Finally able to say St. Louis Blues pucks were best last year.....
Old Jan 26, 2020 | 07:50 AM
NickHall's Avatar
NickHall
Madison Wisconsin
Default C7 jack pucks work in C8???
Cool, thanks.
I will now order the C7 pucks for my C8!
they worked great on both my C7s. I built a puck lift jack so only the bottom and the first 90% of the side of the puck touch the puck lift holder. Works great. Can even move my jack while it smoothly pivots on the puck.
Old Jan 29, 2020 | 02:57 PM
AverageVetteNut's Avatar
AverageVetteNut
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
I was under a C8 this weekend at daytona and can confirm also that there are tie down holes in the bottom of the car that look to be the same ( or close ) in size for the T-hooks to work to tie the car down on a car trailer and for the pucks to work as well.
NOW... the bigger question is ... can you jack the car up on its sides or do they advise against it like the other aluminum - framed C7s and the C6Z/ZR1?
To C8 jacking
Old Feb 6, 2020 | 05:10 PM
RapidC84B's Avatar
RapidC84B
@AverageVetteNut Where have you ever seen that it was advised against to jack the car on the side rails for an aluminum chassis? The C6/7 had no issues with this and it was an approved jacking spot in the service manuals. I'm more curious if there are jacking points from the front/rear and ways to put jackstands on the cradles? Appears it's all covered up now and a quick jack is in order for any DIY service.
Old Feb 6, 2020 | 06:27 PM
JerryU's Avatar
JerryU
This info is from the C7 Service Manual, sure you can lift from the frame. Only caution is lifting from the hollow cast aluminum cross members, which was NOT recommended in my 2014 Service Manual BUT as noted was added as allowed in the 2016 Service manual IF you use a rubber pad or wood block.
Old Feb 10, 2020 | 06:36 AM
AverageVetteNut
THat's what I thought. Thanks Jerry for the sketch.
ToolHoarder - I got my info from a Sam Strano a couple years back. He was talking about jacking the C6Z up and said that you weren't supposed to jack the aluminum frame cars from those jacking spots. I guess I should've clarified using a floor jack, not lifting them up in general.
