Sponsored by: CARiD
Track wheels TPMS?
Old Feb 17, 2020 | 01:09 PM
TJay74's Avatar
TJay74
Originally Posted by PeteC7
You have a C6 in your avatar. The older generations did work that way, the C7/8 do not.
I have a 2017 Camaro SS 1LE, same generation and system the C7 uses, you still have to use the TPMS relearn process if you want they cars TPMS system to know what wheel position the TPMS sensor is located in. That part of the process has not changed at all no matter what generation GM vehicle you have.
Old Feb 17, 2020 | 01:17 PM
TJay74's Avatar
TJay74
Originally Posted by serendib
I have never had to us any tool for my 2017 Z06/Z07 to pickup TPMS sensors when switching from one set of wheels to another. I switch back and forth quite often.
If you want the vehicle to know which wheel position it is located in you most certainly have to use the TPMS reset tool to relearn the wheels positions.
Old Feb 17, 2020 | 03:11 PM
jrhoades's Avatar
jrhoades
Is the TPMS reset tool something consumers can purchase at a reasonable cost?
Old Feb 17, 2020 | 03:30 PM
TJay74's Avatar
TJay74
Yes you can get the tool for about $50
Old Feb 17, 2020 | 07:52 PM
Edwardz's Avatar
Edwardz
I have switched wheels several times and it knows what wheel is where because if I add air it changes that tire in that position. The snow tires on now are directional so they are in same position. Maybe further investigation is warranted.
Old Feb 17, 2020 | 09:49 PM
serendib's Avatar
serendib
same here and we’ve done this at least a dozen times. On our 2009 cobalt SS we did have to use the older process
Old Feb 18, 2020 | 08:39 AM
PeteC7's Avatar
PeteC7
That is true for a Camaro, not for a C7 or newer Corvette. Our TPMS is a fixed 433 MHz and requires no programming.
Old Feb 18, 2020 | 10:41 AM
RapidC84B's Avatar
RapidC84B
That is not correct, you cant just install the wheels with the TPMS and drive. The sensors have to be paired to the vehicle and to each wheel position. The end user can do this as long as they have the TPMS reset tool depending on the frequency of the TPMS sensors.
@TJay74 that was only for the C6 gen. C7 completely did away with that. C8 should be the same.
THERE IS NO NEED TO PAIR TPMS ANYMORE. JUST INSTALL WHEELS AND DRIVE. THEY SELF-PAIR. YES, THERE IS A MANUAL METHOD IF THE SELF-PAIR FAILS, BUT IN MY 3 YEARS OF OWNING AND TRACKING MY C7 MINE NEVER FAILED TO WORK.
Old Feb 18, 2020 | 01:48 PM
TJay74's Avatar
TJay74
I have 433mhz sensors as well, my car is a 17 Camaro SS with the 1LE track package. So I have the E-Diff and the PTM modes and the dual mode TPMS sensors that provide air pressure and air temperature inside of the wheel, just like the C7 uses.
Yes the system knows the sensors have been paired to it, you still have to go to the TPMS screen on the DIC and put it into pairing mode and then use the TPMS tool to program where each wheel is located at on the vehicle. With a staggered fitment there is a 50/50 chance on each end of the car you could get the wheel back in the same position as last time, not always the case on a square fitment.
I have a 2nd set of wheels and then I also have 2 rear drag radials. While the car knows when they are on it because the sensors once they are activated register, I still have to tell the ECM where they are located at on the vehicle.
There is no way for the car to know where each wheel is located without using the TPMS tool to tell it that info. Sorry, but that is how it works yes even on the C7 and C8.
Old Feb 18, 2020 | 02:21 PM
RapidC84B's Avatar
RapidC84B
You're totally wrong... why do you keep posting bullshit? Let me tell you again... I tracked my C7 for 3 years 5-6 weekends a year. I never ever had to re-learn. You just swap the wheels and drive around the block.
Old Feb 18, 2020 | 02:29 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
TJay74?
You got it wrong on the C7. It is an automatic process and we don't have to do squat to get the TPMS to figure out what wheel they're on and to transmit the pressure reading.
Elmer
Old Feb 18, 2020 | 02:44 PM
Zymurgy's Avatar
Zymurgy
Moderator
WRONG!
Again, this does not re-learn or pair the TPMS sensors with each wheel position. All this does is puts the vehicle in TPMS re-learn mode. At that point you have to use a TPMS reset tool and go to each wheel position starting with the drivers side front wheel and excite the TPMS sensor using the reset tool. Then follow the side marker lights to the next wheel position until you are done.
WRONG!
WRONG!
WRONG!
WRONG!
Your Camaro experience is irrelevant for the C7 (and probably the C8). The C7 automatically relearns.
This is from the Owners Manual:
TPMS Sensor Matching
Process — Auto Learn
Function
Each TPMS sensor has a unique
identification code. The identification
code needs to be matched to a new
tire/wheel position after rotating the
tires or replacing one or more of the
TPMS sensors. When a tire is
installed, the vehicle must be
stationary for about 20 minutes
before the system recalculates. The
following relearn process takes up
to 10 minutes, driving at a minimum
speed of 19 km/h (12 mph).
A dash (-) or pressure value will
display in the DIC. See Driver
Information Center (DIC) 0 114 and
Tire Messages 0 129. A warning
message displays in the DIC if a
problem occurs during the relearn
process.
Please stop spreading your incorrect information regarding the C7 (and probably C8) TPMS system.
Old Feb 18, 2020 | 03:20 PM
  #33
eboggs_jkvl
Moderator emeritus
Well, at least I've learned how to spell WRONG.
Elmer
Old Feb 20, 2020 | 09:27 PM
  #34
rb185afm's Avatar
rb185afm
I swap wheels all the time. I’ve done it at the track with back to back wheel swaps. Stock sized to 18’s with slicks. Took my car about 2 min of driving at 5 mph in the pits and my car always picks up the new sensors. No action needed other than swapping wheels with Oem Senors and driving.
Old Feb 25, 2020 | 10:58 AM
  #35
SouthernSon's Avatar
SouthernSon
I understand your question is in regard to the '19 C7. My '19 recognizes each wheel and resets itself. No intervention needed. It is, indeed, corner specific in recognition. The manual says it may take a few minutes. I have watched it work a couple of times. No problem. I had a GM product in the past that required letting some air out of the tire for the vehicle to recognize that particular corner. No longer needed on the '19 C7. Unfortunately there are some posts in this thread regarding other models/years. That is old information. Mount the wheels and simply get in the car and drive. No dirty hands.
Old Feb 26, 2020 | 02:43 PM
  #36
jcp911s's Avatar
jcp911s
Sorry to hijack this but the comment that the TPMS sensors input into the eDiff operation surprised me.
I have a 2016 Z51 and use MPSC2 on separate wheels for track. I did not get TPMS, as I always check my pressures after every session, and did not want to deal with them malfunctioning under extreme use...(e.g. bashing curbs).
Certainly I don;t want to compromise the performance of the eDiff... so question for you tech gurus...
How does the eDiff function without signal from the TPMS.??
My assumption is that the eDiff assumes the tires are at operational pressure, and only reacts if it detects an "out or range" condition 9either too low or too high)....so if the TMPS signal is missing, it just operates normally...
Is that correct, or does the absence of TPMS signal adversely impact operation?
Old Feb 26, 2020 | 03:35 PM
  #37
RapidC84B's Avatar
RapidC84B
I could never get a 100% definitive answer of what the eDiff does with no TPMS. Even Jim Mero told me on FB messenger that he couldn't recall. Thus, I went ahead and put TPMS in my track wheels. Never had an issue with them and I eat all the curbs at VIR.
We know the eDiff is less aggressive when TPMS tells the car the tires are cold... it's the temp data, not the pressure data, that matters.
To Track wheels TPMS?
Old Feb 26, 2020 | 04:36 PM
  #38
jcp911s's Avatar
jcp911s
Thanks, I didn't notice any weird behavior.... assuming it will work OK.
Old Mar 3, 2020 | 07:16 PM
  #39
jrhoades's Avatar
jrhoades
Perhaps not the best place to ask, but does anyone know if there's a way to purchase a set of TPMS sensors now? Preferably online? Have an aftermarket set of wheels and tires, would like to get the tires mounted, but need the sensors first.
Thanks,
Old Mar 3, 2020 | 11:29 PM
  #40
Zymurgy's Avatar
Zymurgy
Moderator
Wildhammer Motorsports Set of 4 with nuts $166.
TPMS: GM 13529771
Nut: GM 84413358
You must order the nuts as they are a separate part.
