Sponsored by: CARiD
Track wheels TPMS?
Old Jan 28, 2020 | 02:41 AM
jrhoades's Avatar
jrhoades
Default Track wheels TPMS?
C8 will be my first Corvette, mainly used for fun on the track, though I plan to drive it there and back.
While it may be too soon to know for certain, what is the latest tire pressure monitoring tech GM uses on the cars? Have a set of wheels on the way, and would like the computers and things to still work ok, mainly for those to/from drives.
In the old days you had to get a set of TPMS sensors and pair them with the car. Anybody have an idea what it’ll take to keep the C8 from freaking out with aftermarket wheels? What’s the process for a ‘19 C7? Tire f/r ratio is being kept stock.
Thanks!
Old Jan 28, 2020 | 12:34 PM
FN in MT's Avatar
FN in MT
I once had a rt rear blow out during a pursuit when I was at well over 100 mph. I did some cool NASCAR spinning skid marks on the highway and luckily stayed on 4 wheels. I often thought if a TPMS alert would have allowed me to slow down before the tire disintegrated? I personally would like TPMS if I tracked a car. I'm sure the real racers will come on and give you the answer. I'm curious.
Old Jan 31, 2020 | 02:37 PM
TJay74's Avatar
TJay74
TPMS only works on slow loss of air events, if it is sudden the TPMS cant react fast enough to be able to warn you. My wife ran oversomething in the road on her car, destroyed the sidewall of the tire are 20mph. She went a block into a parking lot and the TPMS never activated until after we had the spare swapped over.
Old Jan 31, 2020 | 06:05 PM
jrhoades's Avatar
jrhoades
Yeah not looking to have TPMS save me on track - just want to be sure I can use aftermarket wheels and keep the computers out of failure/limp mode. Bonus points if there is some way to keep TPMS functional and eliminate dash error lights.
Anybody have a late C7 with aftermarket wheels and have this figured out?
Old Jan 31, 2020 | 08:02 PM
PRE-Z06's Avatar
PRE-Z06
I’m curious too as I know on my C6 you have to run either all 4 corners with programmed sensors or not as if mix matched it will not allow you to turn off stability control. I almost found that out the hard way having it try to straighten me out and almost putting me into the curb trail braking into a corner at ~90, thought the car was possessed at first then realized it hadn’t turned everything off like I thought.
Old Feb 1, 2020 | 08:16 PM
rrsperry's Avatar
rrsperry
Welcome to the new days.
you don’t have to pair the sensors. The car will recognize them, (provided they are the correct sensors).
Old Feb 1, 2020 | 10:13 PM
Rinaldo Catria's Avatar
Rinaldo Catria
I picked up a sheet metal screw in my rear 325/30/19 C6 GS tire. I believe the monitor came somewhere below 25 psi. It was a slow leak. I had a 12v air pump and added air. Found out the pressure sensor sends an alert for too much pressure as well. (Over 40 I think). Allowed me to get home at night the 150 mile stretch without riding on the “run flat” sidewall . I stopped every time the pressure got below 25 psi. I’m a big fan of TPMS. The C7 shows the tire pressure along with other data in Track mode continuously. Small pressure changes show up reflecting tire heat changes. Tire heat also show up. Valuable info even if I’m told the heat is approx. I’ve found my TPMS readings to be very accurate because I verified mine against a professional grade dial pressure gauge. I would assume most people do that.
Old Feb 1, 2020 | 11:32 PM
PRE-Z06's Avatar
PRE-Z06
What if you run two wheels without sensors and two with, can you fully defeat stability control?
Old Feb 6, 2020 | 12:09 PM
SouthernSon's Avatar
SouthernSon
Absolutely correct! Might take a few minutes but the system works well on my '19.
Old Feb 6, 2020 | 05:22 PM
RapidC84B's Avatar
RapidC84B
Had this dilemma w/ my C7 Z51 that I setup for TimeTrials. Ended up adding TPMS to all my wheel sets. The C7 used the tire temp sensor data to feed the eDiff. If no data was present it would enter a default mode. Even Jim Mero wasn't 100% sure if it would default to a medium setting or max performance. On top of that, if you have a slow leak it's nice to know. A buddy who races a Mustang was notified of a puncture before heading down the back straight at Road Atlanta where he hits 150+.
Yes it's a little extra expense, but you ensure all systems work and with the C7 (assume the C8 is the same) the sensors auto-sync so you don't have to do anything other than swap your wheel set and drive a little.
Old Feb 7, 2020 | 02:22 PM
TJay74's Avatar
TJay74
As said, if you got the Z51 or if your C8 has the eLSD rear diff you will have to use TPMS sensors. The TPMS sensors on cars with the eLSD rear diff actually do 2 things, they provide PSI and temperature inside of the tire. It affect the calibration for the eLSD.
I would ask the wheel company which sensors their wheels are setup for, the GM ones that I have messed with use a long shank style nut on the outside of the wheel t secure the TPMS to the wheel. And contrary to the other posts responses, you do need to sync the TPMS sensors to their position on the car. If they are new sensors they also need to be paired to the vehicle and then sync'd to the position on the car. Once GM releases the sensor info that will help you determine what Mhz sensor to order and if the current TPMS reset devices on the market will work or not.
Old Feb 7, 2020 | 03:25 PM
jrhoades's Avatar
jrhoades
In the C7, could the owner perform the TPMS pairing? With my Vipers you had to take it to the dealer for them to do it with a special interface tool. Which meant the "Lo Tire" thing was on constantly with the track wheels.
Have both my selling and courtesy delivery dealers looking to see if they can get a spare set of TPMS sensors at delivery time.
Old Feb 7, 2020 | 04:18 PM
RapidC84B's Avatar
RapidC84B
No pairing needed... install wheels and drive.
Old Feb 7, 2020 | 09:13 PM
Newton06's Avatar
Newton06
^this^
TPMS data is integrated into PTM and all of the underlying systems. Given the minuscule expense, if you are planning on utilizing track wheels (i.e. my Forgelines were almost $5k) why would you even think about forgoing TPMS?
Looking forward to seeing your C8 @VIR soon! Not sure I will have my Z06 back in time for instruction with THSCC at the end of this month. If not, I'll be out in the Type-R.
Old Feb 14, 2020 | 04:46 PM
Edwardz's Avatar
Edwardz
Thanks!
I have three sets of tires and you just swap the tires and the car recognizes them by the time I leave the driveway. When driving fast I always display the pressure in the middle display. If you get a rapid loss of air you will see it almost instantly. Not sure if you will always have time to slow before tires failure but you are better off the not measuring. I hit a medal bar the poked a large hole with about 5 second loss of pressure. The rapid drop indicated helped me pull over very quick. Really a great feature.
Old Feb 15, 2020 | 08:31 PM
PeteC7's Avatar
PeteC7
I just learned there is a way to pair, or reset the TPMS by going to the tire pressure display while the car is running and hold the right side select button on the steering wheel for 5 seconds. The horn will beep and it'll reset the TPMS. I've been swapping between street and track wheels for 3 years and just recently, for the first time, the car didn't recognize them when I changed. The previous process fixed it though.
They are only like $35 on amazon and definitely worth it when running high speeds on non run flats.
Old Feb 17, 2020 | 09:53 AM
TJay74's Avatar
TJay74
That is not correct, you cant just install the wheels with the TPMS and drive. The sensors have to be paired to the vehicle and to each wheel position. The end user can do this as long as they have the TPMS reset tool depending on the frequency of the TPMS sensors.
To Track wheels TPMS?
Old Feb 17, 2020 | 10:00 AM
TJay74's Avatar
TJay74
Again, this does not re-learn or pair the TPMS sensors with each wheel position. All this does is puts the vehicle in TPMS re-learn mode. At that point you have to use a TPMS reset tool and go to each wheel position starting with the drivers side front wheel and excite the TPMS sensor using the reset tool. Then follow the side marker lights to the next wheel position until you are done.
Old Feb 17, 2020 | 10:49 AM
serendib's Avatar
serendib
I have never had to us any tool for my 2017 Z06/Z07 to pickup TPMS sensors when switching from one set of wheels to another. I switch back and forth quite often.
Old Feb 17, 2020 | 11:00 AM
PeteC7's Avatar
PeteC7
You have a C6 in your avatar. The older generations did work that way, the C7/8 do not.
