Are headers worth it? I am waiting for my exhaust/sport cats to arrive (going you fabspeed) and have also read that headers add a decent amount of performance. My question is will headers (or anything else) add any decent amount of performance to the cats/exhaust? I don’t see the point in spending additional time/$ if the improvement would only be a couple hp or something, but if it would be 10-20 more then it might be worth it. Just curious what people think since I’d like to squeeze out as much performance as possible without going forced induction.
We found zero net gains installing our very own high flow cats on a C8. If there was an advantage to having them, like we do for C5, C6 and C7, we'd long since been offering them. The quickest and fastest N/A C8's are all ARH equipped and you'll be hard pressed to see that change any time soon. They both ran through factory cats. Snowblind 2.0 is a great source if you want detailed information. Thanks.
PS. For the forum member (bsDoc) that wonders if 12 RWHP is worth the money, line up next to someone that has the added power and watch what happens. It's game over! It may not matter to everyone but not everyone installs headers on their Vettes.
We haven't personally seen any noticeable gains on the headers we have installed on N/A cars but to be fair we haven't tested every set on the market and not all headers are created equally.
The aFe Twisted Steel headers added quite a bit of mid-range to my car. The Corsa cats added more volume & sharpness to the exhaust note, but the aFe headers did more performance-wise.
Yeah.....it seems like American Racing Headers and AFE are the only ones indicating horsepower gains. Kind of strange regarding the other name brands not indicating horsepower gains. I am on the fence also on my decision. But for the price AFE stands out.
Hey Kracka, would this be a DIY installation on the AFE? And are the AFE Headers available for the HTC? Thanks
yeah I just watched a video on ARH, which gained about 12hp added on to the gains produced by the LMR cats/exhaust system. Just need to figure out if 12 hp is worth the $ haha
I know for fact that the ARH are proven performance. I witnessed it the drag strip. One c8 with ARH including bolt-ons and another c8 with bolt-ons but without the ARH. The c8 with the ARH just continously pulled away from the bolt-on c8.....no contest. Do a search on YouTube.....Carlos Rioz and/or RearwheelDrive.
I have ARH headers.... they didnt have any noticeable gain at the track. I feel like there is probably a bit more than just headers going on in the race your witnessed as there are a lot of variables.
IMHO i would skip headers, the factory heat shielding on the stock headers is quite nice and the stock headers flow pretty well as demonstrated by the small gains, i would argue you lose more than you gain with the headers. To each their own.
The reason is actually quite simple, most of these aftermarket header brands are using 2.25-2.50" collector outlet flanges which is SMALLER than stock (2.75")! Kooks & Corsa are perfect examples of it, unfortunately. ARH & aFe are by far the best choices on the market considering both have factory-sized outlet flanges to match up to both stock and aftermarket cats, plus are 50-state emissions legal with CARB approval.
I installed my aFe headers working solo in the garage with the car on the ground; no reason to lift it, remove tires, wheel liners, etc. aFe recommends the Titanium Ceramic coated headers for use in the HTC due to thermal management. I have these ones in my car and engine bay temps are actually LOWER than factory temps due to the ceramic coatings keeping the heat where it should be, in the exhaust gas stream, plus improved ventilation airflow without all the bulky factory heatshields taking up space and retaining heat. aFe uses Cerakote Titanium V-164 ceramic coating; I used Cerakote Glacier Titanium C-7900 on my Corsa cats. Both are excellent coatings with great thermal properties. Here's my thread: https://www.corvetteforum.com/forums...port-cats.html
Titanium Cerakote Ceramic Outside Coating with Copper Ceramic Inside Coating:
This coating combination reduces the outside surface temperature of headers and reduces engine compartment temperatures by as much as 46% vs. non-coated headers. These headers are highly recommended for convertible applications where the top is stored over the engine compartment.
I really appreciate your information you provided to
myself and other members. Glad that I narrowed it down to those two headers. Again thanks a lot sir
The exhaust gains for the LT2 are in the catalysts. Sport cats are the best $ to HP you can spend. Not cheap at $3K+, but that is where your gains will be.
Just not proven at the drag strip alone. It appears that the hp gains for most headers are with the header/cats combo. Kooks is one of them.
This is kinda a misconception because you add them and the car instantly is louder. Most people aren't recognizing the fact that the stock cats are massive, because of their size they flow relatively well. The 'upgraded' higher flow cats are half the size of the stock units...
Upgraded cats arent the magic bullet for more power. I suggest everyone do their own research on this.
Nick
NICK.....you hit it right on the nose. Once you add the ARH to your combo mods this car starts gradually pulling away when compared to a c8 with combo but without the headers. I am convinced because I have seen it for myself. Cats are for sounds that is preferred to your liking. I cannot speak for any other headers at this point.
Hello Nick, I have a base model convertible. Anything different from the base model coupe or is it the same headers? Thanks in advance
Soul Performance claims some crazy gains with cats alone, like 17 whp and 20 wtq. The dynos are right in the photos within the product description. Fake news?
Check out Matt Peckham, he did before and after dyno runs for a customer on both the Attack Blue Air Filter and the Soul hi-flow cats/muffler. The Attack Blue gained 3 1/2 rwhp obove 5200 rpm. The Soul Hi-flow cats and muffler gained an additional 5-6 rwhp and 10 torque throughout the powerband. He also noted with the DCT trans fluid, as oil temps increase rwhp readings will increase slightly due to less friction of the thinner oil. So he made sure temps were similiar.
It really depends which time of cat cores you're using. Soul and Fabspeed use very large (and expensive) German HJS cores that flow quite well, hence the $3,000-3,500 price tag. At the opposite end of the spectrum you have the cheap generic Asian 200-cell cat cores (sub-$1,000 price range). In the middle, which is a nice balance between flow, power, sound, price, and being emissions-friendly, you have the North American made GESi G-Sport cats which are 49-state EPA cores with claimed gains in the 10-15 WHP range (these are the cores used by Corsa, Cicio, Paragon, and Kooks and cost in the $1,500-2,000 range). HJS & GESi cores do not trigger a CEL, but the generic ones are a total crap shoot as they do not meet any emissions standards.
"Do not trigger a cel".... well, even the HJS & GESi cores will trigger a CEL on track (roadcourse) if you push enough exhaust through those cats they will still trigger a CEL, they wont set off a CEL on the streets as you will never get close to pushing that much exhaust through the cats on the street as you do on a roadcourse... But i digress... Yes not all cores are created equal in this scenario.
