Sponsored by: CARiD
How I changed my DCT fluid
Old Jul 3, 2024 | 03:59 PM
  #41
itsonlyairandfuel's Avatar
itsonlyairandfuel
drain plug torque spec, as per post. Install and tighten 25 N-m  (18 lb ft) ???
Old Jul 3, 2024 | 09:22 PM
  #42
RKCRLR's Avatar
RKCRLR
I used the specified torque and it didn't seem excessive but I don't remember the plug being aluminum. I have a 2020 with the die 1 pan, perhaps the later pans are different and the service manual has a different torque for the plugs in the cast aluminum pan?
Old Jul 6, 2024 | 12:52 PM
  #43
tsigwing's Avatar
tsigwing
Originally Posted by tsigwing
One thing that concerns me is the different variety of bolts being used. Is it possible to use the wrong one, or are there none of the same diameter/pitch with different lengths? If it is possible to use the wrong fastener, how do you keep track of them?
Ok, as long as you keep the bolts with the right cover, you can't mess it up.
Old Sep 17, 2024 | 04:28 PM
  #44
mmthomas's Avatar
mmthomas
Can you perform a filter only change on the transmission, and do you have to add some amount of fluid for the loss?
Is there a filter only change set of instructions somewhere?
Old Sep 17, 2024 | 05:22 PM
  #45
Andybump's Avatar
Andybump
Yes. The DCT filter replacement and the transmission fluid replacement are on two entirely separate schedules. And yes they have separate procedures - always. And yes, when the filter is replace there is a small amount of fluid lost - and are steps in the procedure to check and adjust fluid level.
The procedures are in the Service Manual for each.
The DCT filter must be changed between 7000-8000 miles even if done earlier, then at 22,500 miles, then every 22,500 miles after, or when the filter life monitor says so (if you have one), or every 24 hours of track use, whichever comes first.
The fluid must be replaced when the fluid life monitor says so, or every 45000 miles, or at least every three years,or every 24 hours of track use, whichever comes first.
So, you can see they will generally not happen at the same time - many will get to 3 years before reaching 45000 miles.
Old Sep 17, 2024 | 05:55 PM
  #46
Jacques Albrecht's Avatar
Jacques Albrecht
Default 2020 Corvette C8 Z51
Originally Posted by michelve
I've combined several threads, including this one, to create a comprehensive PDF guide. It contains detailed steps and manuals bound together for easy reference. I trust it will be helpful.
Let me know if anything is missing or needs to be added.
What would be swell is to find software / hardware that is useful on a 2020 Corvette C8 for the required Hydraulic System Flush. There's currently available software / hardware for newer model years but nothing for the 2020... yet.
### UPDATE: I've answered my own question...
The Foxwell NT710 Bi-directional Scan Tool (with software for GM) will perform the Hydraulic System Flush procedure on a 2020 C8 but unfortunately it won't perform the "Leak Test" ...
Old Sep 18, 2024 | 08:42 AM
  #47
tsigwing's Avatar
tsigwing
Or, don't worry about since the "flush" occurs as you drive.
Old Sep 18, 2024 | 11:13 AM
  #48
Andybump's Avatar
Andybump
t not at all clear to me that Josh said that the highway routine is "exactly the same" as the Hydraulic System Flush. Below is his statement. Its ambiguous in my opinion. He says when you are driving steady state down the highway we run a routine in the transmission that will force more fluid through the fine filter. He could have said when running in steady state down the highway we run the Hydraulic System Flush procedure. But he does not say that. He does not say that "routine" is the Hydraulic System Flush. As I have pointed out before, many believe that the HSF executes the seven different Transmission Services Cleaning Procedures in certain order. There is no direct proof of that, other than those 7 procedure reportedly disappeared when the HSF appeared as an option on the scan tools. But if is true, then its hard to believe that the highway routine is doing "exactly" the same thing. Each of those individual procedures was to address an issue with one, two, or three specific hydraulic control system valves. It would seem difficult to exercise those valves that way when cruising down the highway, since they control everything from fork movement, clutch action, park lock, and eDiff if you have it. But again, I agree its ambiguous, so I can understand where others want to interpret it differently. He also said you do not have to do it if your are doing it yourself - and that part was not ambiguous.
Here is Josh's statement - and I attached the list of 7 procedures again"
"The hydraulic system flush does kind’a the way its described. It forces transmission fluid through the fine filter that you replace. So, at a dealership they can hook up the dealer service tool to the and run a routine that will tell the trans control module to do this fluid filter flush. And because the car is already hoisted on the rack, the technician’s already got the panels off, there’s some other work he’s doing, this kinda happens in parallel in the background. So we’re doing it at a dealer visit because we can. And we can take the last bit whatever contamination might be in the oil and get it into the filter before the technician replaces it. Do it yourselfers have become nervous that hey now I can’t do it myself, I don’t have a service tool, I can’t force this routine. You don’t have to do the routine. Like I said we do it because we can, but the fine filtering routine happens during normal driving anyway. In fact, when you’re driving steady state like say down the highway, we run a routine [ my note - does "a routine" mean "the HSF routine" or something else? He could have said we run the HSF when cruising down the highway, but he did not say that. Why?] in the transmission that will force more of that fluid through the fine filter. So normal driving is doing this. If you are a do-it-yourselfer, you don’t want anyone else touching your car, you can change the trans filter without running this routine."
Old Oct 24, 2025 | 03:57 PM
  #49
Gary0426's Avatar
Gary0426
Default C8 DCT Transmission Servicing
Originally Posted by Andybump
Post 14 has your answer. But there is no transmission procedure called a "back flush" although that term does appear in the Service Manual in the context of a cooling system flush. We do not know exactly what the Hydraulic System Flush does. What we know about it is the name of the procedure, and we know that its purpose is to manipulate the valves with the goal of freeing any debris in the lines and valves and moving it to the filter before changing the filter. Whether or not it involves reversing the flow in the lines is unknown but if it did, would the dirt end up on the wrong side of the filter? It could be a rapid activation/deactivation of the valves, or operation at higher than normal operating pressure, operating the valves in a special sequence - we just don't know. Sometimes a "back flush" implies attaching of an external machine to force fluid in a backward direction - that's not the case here. Its all done with a computer while the engine is idling.
if you go to you tube there’s a few good videos showing step by step instructions to perform the back flush for the filter removal.
purchase from Amazon the Foxwell NT510 elite OBD2 hand held scanner for around $189. I backflushed mine with it and it’s easy to use and works great for the flush and has a boat load of other uses.
Old Oct 25, 2025 | 12:34 PM
  #50
RKCRLR's Avatar
RKCRLR
What year is your car? I know some aftermarket scanners will perform a HSF on later cars but the software isn't built in for the earlier cars. I've seen one post reporting that the Foxwell worked on a 2020 but the leak test didn't work. I have a 2020.
Old Oct 25, 2025 | 12:40 PM
  #51
Andybump's Avatar
Andybump
Again, no such procedure called back flush for the C8 transmission - which sound like some sort of reverse flush that you might to with an exeternal device. The procedure performed as step one of the filter change procedure is called the Hydraulic System Flush. Its described like this in the Service Manual: "This test executes a procedure in the TCM software to actuate the solenoids in a specific manner to flush debris from the system."
Old Oct 25, 2025 | 12:57 PM
  #52
Gary0426's Avatar
Gary0426
Default Dct fluid flush
Again, no such procedure called back flush for the C8 transmission - which sound like some sort of reverse flush that you might to with an exeternal device. The procedure performed as step one of the filter change procedure is called the Hydraulic System Flush. It’s described like this in the Service Manual: "This test executes a procedure in the TCM software to actuate the solenoids in a specific manner to flush debris from the system."
in the service manual I’m not sure what it’s called as I stated I just seen it when the tech showed me what it’s doing. You are correct it opens the solenoids to clear any debris so it gets caught in the filter. The tech stated they started doing this procedure after the many DCT failures they were experiencing.
its not recommended obviously in our owners manual.
Old Oct 27, 2025 | 08:20 AM
  #53
Kenny94945's Avatar
Kenny94945
Good thread, worth reading all responses
Old Nov 7, 2025 | 07:44 PM
  #54
Stev-o's Avatar
Stev-o
Related question for the experts if you don't mind:
We have a '20 with just over 5K miles and I'm thinking it may be time to change the DCT fluid.
Old Nov 7, 2025 | 07:45 PM
  #55
tsigwing's Avatar
tsigwing
every 3 years or 45k miles.
Old Nov 8, 2025 | 01:23 PM
  #56
f1rob's Avatar
f1rob
to maintain your warranty, you are required to change the DCT fluid every 36 months, regardless of mileage.
Old Nov 8, 2025 | 01:39 PM
  #57
Gary0426's Avatar
Gary0426
Default Dct fluid warranty requirements
100% Correct 3 years no matter mileage unless your over the 36k mileage requirement.
To How I changed my DCT fluid
Old Nov 8, 2025 | 05:56 PM
  #58
Andybump's Avatar
Andybump
45k miles not 36k miles.
Old Nov 8, 2025 | 10:17 PM
  #59
Gary0426's Avatar
Gary0426
Default Manufacturers Warranty
The statement I made was in regards to the Manufacturer’s Warranty which is 3 years or 36 thousand miles not the DCT fluid change specifications of 3 years or 45 thousand miles.
One is required maintenance schedules, and the other I was referring to was the Manufacturer Warranty which covers the warrantable components nothing to do with the required maintenance requirements.
if you still not in agreement with these statements refer to your owners manual.
regards,
Old Nov 8, 2025 | 11:50 PM
  #60
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
But the DCT isn't subject to the 36K B2B warranty, is it? I thought it is covered by the drive train warranty. If so, your 36K is STILL incorrect.
