Sponsored by: CARiD
My C8 won't start
Old Jul 8, 2024 | 04:23 PM
oooseun's Avatar
oooseun
Here are a few links with a lot more information than i can type
-> Longer more informative, if you wanna watch only one, watch this)
Old Jul 8, 2024 | 04:29 PM
oooseun's Avatar
oooseun
BUT TLDR;
1. open trunk
2. use t15 to unscrew entire rear hatch and cover of the airbox.
3. possibly remove airbox, idk if this is needed. i have a smaller airbox than stock
4. find park release and turn it.
Old Jul 3, 2025 | 01:26 AM
mammoth713's Avatar
mammoth713
Originally Posted by oooseun
BUT TLDR;
1. open trunk
Has your car been fine?
Old Jul 3, 2025 | 01:27 AM
mammoth713's Avatar
mammoth713
Originally Posted by kkiller46
In case anyone is interested I believe we have tracked random no start issue to the solenoid connector. Again car would not start randomly at track. Finally wouldn't start at all at end of day. Better yet it didn't start when we got home. Had 12v at solenoid connector (again). Plug it back in and the car starts. Got to looking at connector and there was quite a gap between metal leaves in the connector that provide female connection to male flat pin (.032" thick) on solenoid. Found another flat pin the same thickness and it just falls out of connector. So looks like inadequate spring tension between connector and solenoid pin. Tightened metal leaves in connector as much as possible (not much as you can't really move anything to any effect) and car has been starting fine. New connector on the way. And yes, race seat still in car.
Old Jul 3, 2025 | 01:03 PM
Bob Paris's Avatar
Bob Paris
Originally Posted by Corvette4Life_01
You said no mods, but you swapped you seats
His answer was "Nothing Engine Related" so I guess that is a "YES"
Old Jul 5, 2025 | 01:29 AM
kkiller46's Avatar
kkiller46
Traded in 21 Z51 on 25 Z06 in January this year. 21 Z51 started perfectly from the time I replaced the solenoid connector until traded it in.
