C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
LT6 engine failures/problems
Old Aug 23, 2023 | 07:45 AM
  #241
C8Zeb06's Avatar
C8Zeb06
Originally Posted by RapidC84B
You're off-base with the recommendation/interpretations and blaming this all on "abuse". People are having leaking transmissions at PDI or after only a few hundred miles of use. There are case porosity issues (bad castings) and various gasket and seal issues. If GM wanted to break-in to be differently they would have stated as such. The engine is broken in at assembly and first run-in. The other guidelines (500 and 1,500) are for the DCT gears to develop sufficient wear-patterns for a long service-life. The first 500 miles they suggest a lower redline and torque management is active. No launches, no hard use etc. From 500-1,500 you can launch and use the car, but no trackday use i.e. extended high heat or extended loading of the car.
The main issue sets with these cars so far are:
1. Engine vale lash (the tick)
2. Trans leaks (porosity, parts defects)
3. Trans debris causing premature valve-body failure (assembly debris, poor valvebody design)
One member is on his 4th valvebody and was told they recently redesigned it.
GM is adamant that the break-in is 7,500 and if you do the trans filter early, you MUST do it again at 7,500 to have warranty. On all 3 of my Stingrays I do the first oil change and trans filter at 2,000 miles and then again within 7,500 more. This was all before GM clarified the "YOU MUST DO IT AT 7,500 NO MATTER WHAT" update.
For my Z06 I will do oil and trans filter when I get it home from the NCM (about 1,200 miles) and then again at 7,500.
I never accused anyone of abuse. I simply stated what I interpreted as the recommended break in period. If I was off a bit on mileage of certain break ins well then please forgive me for being human. SMH....
Old Aug 23, 2023 | 02:05 PM
  #242
thebishman's Avatar
thebishman
This Tremec designed DCT may well end up costing GM a great deal in after sale warranty claims. One wonders how long before the NHTSA takes a look at it, and whether GM might have to end up with a stop sale on the car like Porsche had to do with the 2014 GT3s.
I sincerely hope not, and as many have stated before, the number of 'faults' are always amplified on forums. But I for one would be glad to be able to get a second or perhaps third model year car at this rate.
Old Aug 23, 2023 | 03:23 PM
  #243
RapidC84B's Avatar
RapidC84B
Sad thing is the trans is technically excellent. It seems the issue is production and assembly.
Old Aug 28, 2023 | 02:25 AM
  #244
okaythen's Avatar
okaythen
This guy got lots of metal shavings in his oil for his 1st oil change, is it normal?
I will have dealer change my 1st oil change at around 2500 miles since I don't do it myself, should I ask to look at the used oil and have them save some oil so I can send to lab? Or there is no need unless there is ticking noise and other problems?
Old Aug 28, 2023 | 06:37 AM
  #245
RUQWIKR's Avatar
RUQWIKR
FYI - on each DCT external filter change, whether part of regular maintenance or with a repair that still requires the external filter to be changed due to possible debris, there is a flush procedure through the dealer scan tool (MDI2). I don't know if any other aftermarket scan tool has access to the flush procedure. Of course, a fresh filter change without the flush procedure is better than a dirty filter.
This procedure is used to flush the transmission fluid through the filtration system before a repair is performed that may have been caused by debris in the fluid.
The following will occur when the scan tool control is enabled: Engine Speed = 2,000 RPM & Line Pressure = Increase — For 8 min
Old Aug 28, 2023 | 09:24 AM
  #246
LE MANSZ's Avatar
LE MANSZ
This is why we need Right to Repair laws: www.repair.org/policy . This tool, or access to the flush procedure function, needs to be made available to owners and independent shops at a reasonable price. All these manufacturers are trying to monopolize service using these methods.
Old Aug 28, 2023 | 12:37 PM
  #247
416vette's Avatar
416vette
https://www.youtube.com/watch?v=Guju1K8XLwo
https://www.youtube.com/watch?v=S8vCrZo4d_k&t=5m22s
https://www.blackstone-labs.com/prod...ree-test-kits/
Ask the techs to collect a sample and send it off. I'd ask the dealer to give you the old filter to cut open for piece of mind.
I've always changed the oil on new cars at 1000km (600 miles) and sent out the sample.
Old Aug 29, 2023 | 07:12 AM
  #248
JABCAT's Avatar
JABCAT
Except it's going on the 5th model year of this transmission and no fix. I think as long as the demand stays high, GM has no incentive to fix it. People keep buying them, many will put very few miles on them, then outside of warranty the original or subsequent owners are going to be screwed.
At least with my Z06 I can buy a set of aftermarket heads and pretty much eliminate any potential issues with my LS7. C8 Z owners have no options for the DCT or LT6.
Old Sep 7, 2023 | 06:37 PM
  #249
mfain's Avatar
mfain
Is it just me, or have the incidences of LT6 failures, especially rapid onset of catastrophic failures at low miles, dropped off significantly in the past couple of months?
Old Sep 7, 2023 | 11:18 PM
  #250
smajicek's Avatar
smajicek
I don't know I only have 860 miles on mine, no tiking and runs just fine, not worried at all, just purchased my 7 year b2b warranty so my a*** is covered
Old Sep 8, 2023 | 12:16 AM
  #251
AustinVetter's Avatar
AustinVetter
I was just thinking the same thing. Certainly seems like it.
Old Sep 11, 2023 | 12:36 AM
  #252
douglasjre's Avatar
douglasjre
Old Sep 11, 2023 | 08:13 AM
  #253
JABCAT's Avatar
JABCAT
Originally Posted by douglasjre
Don't know the guy in the first two vids, but he seems to be just a clown who doesn't provide any factual information
Old Sep 11, 2023 | 09:25 AM
  #254
LE MANSZ's Avatar
LE MANSZ
Clown is an understatement. This "Vette Titans" guy is a known maniac in the C8 community, probably with mental health issues.
Old Sep 17, 2023 | 12:43 AM
  #255
douglasjre's Avatar
douglasjre
Lol
Where can I see his posts
Old Sep 17, 2023 | 10:15 AM
  #256
LE MANSZ's Avatar
LE MANSZ
Lol
@douglasjre Youtube, but don't give him the views/clicks.
Old Sep 18, 2023 | 04:49 PM
  #257
douglasjre's Avatar
douglasjre
Fit to break it to you You may not like his personality but he's correct. Just cuz you don't like how he conveys the information doesn't mean he's wrong about what he's saying.
To LT6 engine failures/problems
Old Sep 19, 2023 | 12:15 AM
  #258
JABCAT's Avatar
JABCAT
Fit to break it to you You may not like his personality but he's correct. Just cuz you don't like how he conveys the information doesn't mean he's wrong about what he's saying. I don't have enough time in my day to train you on these topics
He doesn't actually say anything, except "ooh I figured it out, once I expose this, GM is going down..." he hasn't figured anything out nor does he have anything to expose. He's an idiot, plain and simple.
Old Sep 19, 2023 | 03:17 PM
  #259
douglasjre's Avatar
douglasjre
I see your point. You're right about this
Old Sep 19, 2023 | 07:33 PM
  #260
dpascucci's Avatar
dpascucci
I've got neither the knowledge or track experience to know if this guy is on to something or not. I'm not an auto engineer. Though I'm not a "black-belt" track guy, I do have a lot of track experience in my C6Z06, my C7 Grand Sport, and now my C8Z06. I've got 4,500 miles on my Z06 including 6 track days. I've not experienced issues similar to Vette Titans. I've totally enjoyed the car on track.
The engine is holding up, so far, and oil levels have remained steady. I haven't had to add a drop. I did a complete oil, DCT fluid and DCT filter change just before I hit 2,000 miles and after 2 track days.
The guy has stream of conscience complaints.....first it was the ELSD, then the carbon ceramic brakes, then the "tick", then the ABS, then gasoline in the oil. I don't know. Maybe we're the fools, not him. We'll see, I guess.
