LT6 engine failures/problems
Fuel smell in engine oil? = Fuel dilution. Where that dilution is coming from? Most likely causes are rings not seated, hung injectors or? Idling the car too much. I suppose that if these run rich it could lead towards it as well. As seen with the LT2, they do NOT like to sit idling for more than a minute after a cold start at the most. We've had 4 customers come with fouled plugs on LT2s because they did the old "start it once a month in storage and idle it for 10 minutes" only to have it towed to us running on 3 cylinders.
Also. You can have fuel dilution without a rise in oil level. You'd have to be losing a LOT of fuel into the oil to get a rise in level. Think Chevy Equinox with the 2.4 Ecotec where in 3000mi they'd come in 1/2 quart high, or more so well past 3% of the oil in the sump on those 5 quart systems.
@Mitchell_B what was the percentage for dilution? Ideally no more than 1.5% is ideal, anything past that is concern, above 3% there's problems.
Direct injection engines are prone to dilution. The problem with the Z06 is the fuel system. If interested, I can go into detail.....
Here is a short version of my theory:
- Direct Injection startup, especially cold, uses a lot of extra fuel to "light-off" the combustion. Some of this excess fuel is not burned
- Some gasoline will migrate into the crankcase and oil under overly rich conditions when the fuel is not completely burned
- Normal light-duty driving of the Z06 does not heat the oil to full operating temperature. Typically less than 170 degrees F. At this low temperature it will take longer for any fuel in the oil from start-up to evaporate.
- Many Z06s are driven for lots of consecutive short trips without getting the oil above 170 F. This can cause more fuel to accumulate in the oil.
- Oil lab companies like Blackstone recommend the oil be sampled at operating temperature
- Samples taken after multiple short trips without a long run at 170 degrees F, or hard run at full operating temperature of 190+ degrees F for at lease 30 minutes will show higher % fuel-in-oil.
I believe even one start-up just prior to the oil change can increase the fuel-in-oil slightly.
For reference 8 quarts is 256 ounces, so 1% fuel-in-oil would be ~2.6 ounces gasoline to 256 ounces oil.
Conclusion:
Smell -- Most people can smell gasoline at less than 0.5 parts per million (PPM) in air. That's 0.0000005 to 1, or 0.00005%. It takes very little gasoline present to smell it, so smell is not a reliable tool.
Dipstick level -- In my experience the dipstick level will vary depending on operating conditions so a higher than normal level may-or-may not indicate fuel in oil.
Oil analysis reports -- To use and compare analysis reports for fuel-in-oil percentage, the sampling method and driving conditions prior to the collection must be known.
Seems like it could be easy to fix, but I know nothing of fuel systems.
Yikes that's high fuel in only 1500mi. When you are pulling your sample to send is the oil cold or do you drive it before changing it and get it nice and hot?
Yes, fuel dilution is an issue but its not a need for 2 pumps vs 1.
https://www.corvetteforum.com/forums...ick-it-up.html
