I've got neither the knowledge or track experience to know if this guy is on to something or not. I'm not an auto engineer. Though I'm not a "black-belt" track guy, I do have a lot of track experience in my C6Z06, my C7 Grand Sport, and now my C8Z06. I've got 4,500 miles on my Z06 including 6 track days. I've not experienced issues similar to Vette Titans. I've totally enjoyed the car on track.
The engine is holding up, so far, and oil levels have remained steady. I haven't had to add a drop. I did a complete oil, DCT fluid and DCT filter change just before I hit 2,000 miles and after 2 track days.
The guy has stream of conscience complaints.....first it was the ELSD, then the carbon ceramic brakes, then the "tick", then the ABS, then gasoline in the oil. I don't know. Maybe we're the fools, not him. We'll see, I guess.
I'm in the not buying the LT6 is reliable until long-term ownership & high mileage proves it to be camp. Just from my personal experience with LS1s, LS6, and the thorough research I did on the LS7. I own a supercharged LS7 but that doesn't mean I don't believe/understand the inherent issues with it. Mine sees very limited use until I get around to replacing the heads.
The DCT has been shown, imo, to be a crap shoot in terms of reliability. I'd never own a C8 out of warranty.
All that being said, this guy is just running his mouth about who knows what & from what I've seen, doesn't have any actual proof of anything to back it up.
Tires hop when cold. He's completely right about this. I see the solution would be to program in power limitations in first and second gear until the car has been subjected to progressively increasing throttle inputs and/or cornering forces. This is the norm for motorcycles made by the Japanese manufacturers so novices don't kill themselves in first gear. I see the logic in this and what he is saying makes sense. I also have a science degree and understand physics. But I'm not an engineer. Do we have some engineers here who can make a statement about this?
When I was in Carlisle recently I spoke to either Tadge or Harlan (can't remember which one as I spoke to both of them) about this and they told me. They also said if you were truly getting gas in your oil your oil level would go up which wasn't the case for the people reporting it.
Neither Tadge nor Harlan are going to tell anybody anything about a potential problem with the vehicle, especially at Carlisle.
Ok so you are calling me a liar got it and it's not a potential problem (yet) in some cases it's not gas entering the oil system but a miss understanding from some owners smelling what they believe to be gas in their oil system but it's actually the smell of the oil itself. If the oil level on your dip stick doesn't increase than gas can't be entering your oil system.
Now if someone really does have gas in their oil system then the issue maybe a faulty fuel injector or other issues listed below but not necessary a major design issue. https://www.azom.com/article.aspx?ArticleID=16891
Ok so you are calling me a liar got it and it's not a potential problem (yet) in some cases it's not gas entering the oil system but a miss understanding from some owners smelling what they believe to be gas.
1. I didn't call you anything. I believe that's the nonsense answer they told you.
2. They're not going to tell you or anybody anything about a potential problem with the car. Ask them about the continued DCT replacements four model years in and they'll probably tell you some bs like "customers just aren't used to the driving characteristics of a DCT..."
3. oil smells like gas now, got it
* Tadge also said the LS7 didn't have problems, that C7 GS & Z06 wheels didn't bend/crack
Just came across this video on youtube. LT6 seized up at 621 miles. Not a ton of info. Owner basically says he did a proper break in. They were doing a little pull (its in the video, nothing crazy) and the engine started knocking and seized. City Chevy had a new engine in the car in about 2 weeks. GM didn't let the dealer open up the engine, I assume they had to ship it back to GM intact for some analysis.
Owner of the car says he knows of 3 engine failures. The one that died at like 50 miles that we all heard about, one other one, and his. So with about 1000 cars built, 3 engine failures. So about a 0.3% failure rate so far.
My 23 Z06 dropped a valve (and maybe some other failure?) at 3569 miles. I also got a complete, new engine, but my car was off the road for a month. I did a proper break in, as I did with my 2016 C7 Z06 and a prior 2021C8 Z51. I would echo the video in praising the dealer's service advisor and daily communication of what was going on, I have the car back, fully broken in (roughly 2400 miles on the new engine), again, and she's gong to the track for her inauguration this weekend. We'll she how she does! Oh, and mine is Smurf Blue (that's really what Rapid Blue is, isn't it?) and her name is, you guessed it, Smurfette.
Sorry to hear about your motor. Can you share any particulars on the failure? Was the car an early build? Did you have "ticking"? What was the scenario where the motor failed? Are you sure it was a dropped valve? Thanks if you are able to share.
Originally Posted by Redc8z06
The gas in the oil was explained the new required oil the Z06 takes when heated up smells like gas
Originally Posted by Mitchell_B
This explains why my oil analysis showed significant fuel dilution?
I have 15 cases of M1 Supercar 5w50 at work. I walked back and just opened one up, took a bottle out and cracked that open. It does NOT AT ALL smell like gasoline. None whatsoever. It has a sweet synthetic oil smell (actually kind of nice smelling lol).
Fuel smell in engine oil? = Fuel dilution. Where that dilution is coming from? Most likely causes are rings not seated, hung injectors or? Idling the car too much. I suppose that if these run rich it could lead towards it as well. As seen with the LT2, they do NOT like to sit idling for more than a minute after a cold start at the most. We've had 4 customers come with fouled plugs on LT2s because they did the old "start it once a month in storage and idle it for 10 minutes" only to have it towed to us running on 3 cylinders.
Also. You can have fuel dilution without a rise in oil level. You'd have to be losing a LOT of fuel into the oil to get a rise in level. Think Chevy Equinox with the 2.4 Ecotec where in 3000mi they'd come in 1/2 quart high, or more so well past 3% of the oil in the sump on those 5 quart systems.
@Mitchell_B what was the percentage for dilution? Ideally no more than 1.5% is ideal, anything past that is concern, above 3% there's problems.
