Weathered rubber help?
16 Vettes and counting…..
Aside from replacement of the weather stripping, any good products to help this?
I'd like to find out what is causing that to happen to the weather stripping. I have a new-to-me 2006 Z06 now and don't want it to happen to that car.
1) Remove all the top layer of rubber for more "uniformed" look
2) Replace weatherstripping and understand what happened
Shoot. My 2008 (build 9/07) coupe was doing this. I couldn't figure out what (if anything) I was using that made it do that. Did you just post something similar to this on the "other" Corvette forum?
Former Vendor
I believe its the lubricant used at the factory discoloring the rubber. I have done several coats of Einszett and quite happy with the difference.
http://www.autogeek.net/1z-einszett-...are-stick.html
Looks like it is out of stock?
St. Jude Donor '17
gummi Pflege!!
Check this stuff out.
Seems to be a BMW connection, but I ordered some, and like it lots better than silicone grease.
Made my weatherstripping look new again.
