Bracket racing strategy...
I personally know that he was dumping me pretty hard, and that guy has more strategy than anyone. I would say that his claim of not braking is a disclaimer to keep others from relying on the brake pedal. There is a fine line between braking and excessive braking. You gotta be very careful on th brakes, not so much in a late model Vette with all the ABS equipment, but skidding the tires in an old muscle car or race car is on the edge of putting it into the wall. If you can do all the work by lifting you are on the right track, but some situations will make you keep your left foot cocked and ready.
My name is Jesse Adams, I am 27 years old from Northern California. My dad is Chuck adams, he was NHRA Winston S/ST World Champion in 1985,
and vented about the guys I see at my local tracks who think they are too cool to swallow their credit card horsepower pride and learn to race. Is that understandable?
Hopefully what I posted afterwords is somewhat useful.
I think you come across as a legit racer who knows what he is talking about
As for Jeanne she also races K/SA in NHRA.. if you ever come out East to race a divisional or National event it would be interesting ..
She runs them all here in the NorthEast...
Your tips here, along with others here are very helpful to a guy like me.
I have a total of 12 1/4 mile runs under my belt.
Next year I'd like to participate in a bracket series like the CC
This year, I'm just trying to figure out how to do this stuff.
I have a notebook and write stuff down for every run. I hope to get at least 100 runs in this year. Shouldnt be too hard.
I can already beat my buddy's slightly modded C5
Pete
Hi.
It is always easier to cut consistant lights on a pro tree because the chance of anticipating is not there. You either anticipate the possibility of the light, or you hit it the way you want, or you are late. That is pretty simple.
But on the full tree you have to teach yourself how to put a mental block on the other bulbs. Typically, I watch the third amber, I focus on the whole bulb, not just the center, or bottom half. I do not block out the top two ambers with a "blinder", which is a piece of cardboard or anything positioned in the field of vision to cover up the top two bulbs. Many good racers do use a blinder, but in my opinion it is too distracting to try and adjust my head into the perfect posistion after staging to cover those top two ambers. and when night racing you get glare off your hood, or light glare/pollution off the top two as they count down and that is distracting too. Most blinder racers hate racing at night. My eyes see the top bulbs counting down, but that is not where my focus is. They are just there, I make sure that my focal point stays on the bottom bulb alone. When I see that light come on at all, is when I leave. Treat the bottom bulb as the only bulb on a pro tree. Perephreal vision will not let you not notice the top two ambers, so just think of them as indicators that YOUR bulb is gonna light. The reason your lights vary so much is because the first shot you anticipate and go red, the next one you try to soften up and are late. The next one you cut a .014, then try to back that up or beat it and OOPS, you tried so hard to beat it you anticipated again and go Red.
Staging can help you adjust once you establish your comfort zone. Go to a test and tune, make 4 runs by barely turning on the bottom bulb, you want to be the same staging depth on all 4 runs, if you can manage to go .060 .065 .056 .074, that is a pretty nice group. So now you go up and stage, barely turn tht bottom bulb on, then pump the brake one....two......three times, taking about 2 inches at a time. Every 2 inches you bump in corresponds to about .010 of reaction time. So bumping in 6 inches should move your group down to .030, .035, .026, .044 If you can race in this ballpark each day you are going to do pretty well. If you want to get it in even deeper, and just barely let the top stage bulb turn off, you will be even quicker off the line, but deepstaging is a risky situation, you leave no room for error. If you accidently bump your launch RPM a little too high and cause the car to creep forward you have no safe zone.
There is a huge distance between staging shallow and TRUE deep staging, where the pre stage bulb turns off. It takes about 10-12 inches of forward motion to deep stage, Less if you have a small diameter tire, more for a larger one. Point being.....take a few test and tune runs to bump in 2 inches at a time, from shallow to DEEP, count the bumps. Now you know exactly how much room you have to help adjust your reaction time. Do it in both lanes, it may suprise you but they can be different from left to right, track to track. I doubt on your Vette it makes a difference at all because of your small sidewall tires, but on a car like mine with 15" rims and 26" tires, tire PSI will have an effect on R.T. More air makes the tire more round at the bottom, and does not have a wide, squished footprint like it would if there were less PSI. More PSI = quicker R.T. Less PSI = slower R.T.
Get yourself a practice tree. Even a hand held will work. Put it on the full tree mode and adjust the rollout to like 26. Then hit it over and over and over. DO NOT ATTEMPT TO CUT PERFECT .000 LIGHTS ALL THE TIME That is pointless because your car will not react like the practice tree. Just try to keep the most consistent group possible, try to hit 30 runs in a row within + - .020 The exersize is to learn how to see all 3 ambers, while only watching and reacting to the third one.
Let me know what you think. Is this what you were looking for? I don't know how to explain in short terms because bracket racing is not black and white. Every time I begin to explain one thing, 50 other scenerios need explaining. I do not mind at all, I hope it helps you be a better racer. Satisfaction is self improvement, you don't have to go win a bunch af races to enjoy yourself, as long as you understand why you won or lost, and can use that knowledge to do it again, or do it better the next time.
I don't care if you attach this to the forum or not, but let the guys on the forum know that I sent this to you and if it was helpful or not. I am still trying to fix my image after that first post.
Thanks, Jesse
Hi.
Thanks, Jesse
This looks like a page from the bracket racing class I attended a few years back.
Laydown on the desk with your feet to the left facing the monitor and use you reading glasses.
Since you will be leaving first most times, focus on leaving well and then take your first look over at about 330'....if your opponent is not going to catch you be ready to hit the brakes...I always leave my foot to the floor on the gas pedal while applying the brakes full blast as well...this way you regain some momentum if you need to take the stripe back...if he still is not going to catch you at the traps, lift off the gas and stay on the binders...the only way you can lose at that point is if you break out...
I raced a 93 vette for many years...I left first most of the time...one of the things I did was check out my opponents dial...if he was a much faster car I would dial hard since I knew he would be coming at me real hard at the traps...it is very difficult to judge the stripe with a car coming at you at 110+ mph if you are doing 75 mph...
If you run into an opponent who is dialing the same or slower than you then dial soft...in other words hold a couple of hundredths in the bank...when doing this be ready to hit the brake at the stripe...
As an example, if your car normally runs 9.00 in the 1/8th, dialing soft would be 9.02 to 9.04 and hard would be 8.98 to 9.00...1/8 mile racing happens fast and driving skills are much more apparent and necessary versus 1/4 mile racing...hope this helped a little...
BTW, I am the guy with the black primer Camaro that hangs out with Mike with the red 79 vette..we will be there tomorrow night for the points and down in palm beach for the super chevy on march 6th...
.020 during typical/familiar conditions is like giving up .020 on the tree. If you are doing all you can to get the advantage on the tree you should not be so generous to give up all that hard work. Make 'em earn it.
1/8 mile is all about tight packages. You need to rely on a good light, and be ready to dial dead on honest, or hard by .010..... Then I am never just ready for the brake pedal. I can tell by the 330 mark if I am gonna catch the other car, or if he's gonna catch me by a significant margin or not, then I start whackin the throttle accordingly. Like I explained in a previous "chapter, LOL" you have an Idea how much E.T. is being killed by working the throttle, not by hammering the brakes. The brake pedal is there if you screwed up and realize you did not scrub enough E.T. and want to tighten it up at the stripe because there is no other option, or to DUMP your opponent as they are going to get the stripe and you are not. If I think it is gonna be really close I will wing it when I get to the stripe, I can't really explain that because it is 100% natural instinct to do what needs to be done. I would be willing to bet that for every 50 rounds of eliminations, I may only run it all out 4 or 5 times. I can honestly tell you that I can not remember the last time I was in the throttle for the entire duration of the run (during eliminations). Like in the Biondo article, he explains the rate of closure....I have always refered to it as the rate of gain. But after you leave the starting line, you transfer all of the focus to that. Making the finish line a guessing game will not win many rounds. I run PRO and SUPER PRO at Sacramento Raceway (I claim points there, as it's my home track) I am driving my 69 Camaro this year, 11.50s 1/4mile 7.40s 1/8 383 SBC & Powerglide. At Sac they allow 2 categories in 1 car. I do not use a delay box in the Camaro, I bottom bulb in both categories. In all cars last year I probabaly made around 500 passes. check out our points stats...scan the event results and E.T. series stuff www.sacramentoraceway.com (Not trying to brag, just sharing because I'm proud) Also, I know a lot of the Vettes you guys are running are not as consistant as a "bare essentials" race car, but that can help you learn to drive the stripe. Have any of you tried the freeway practice yet? You can learn how to put 6" on cars all day long, too bad they won't know what the hell you are doing. And since you are all in Vettes, not many guys can get fed up with your games and leave you in the dust.Last edited by jadams67; Feb 21, 2009 at 04:58 AM.
thanks for the input...DDBS (Todd)
