Block check
Old Feb 13, 2006 | 05:41 AM
Performance nut's Avatar
Performance nut
Default Block check
Looking to get the same casting for my '91 Corvette (L98). Its a California smog law that I have to use the same year or newer. And since that will mean converting to LTx or LSx, I would rather stick with the '91 block. Anyone have the casting number for the 1991 L98 block? Thanks.
Old Feb 13, 2006 | 11:09 AM
CFI-EFI's Avatar
CFI-EFI
I cannot imagine that 1991, 350 engines have a unique casting number. I'm sure any 1986-up, L98 (and other 350s, too) would have the same cast number. Besides the BLOCK has nothing to do with the smog equipment or compliance of any of the parts bolted to to it. Does California really check casting numbers? I'll bet $100.00, if you take any year block, correct casing number or not, and bolt all your stock L98 parts on it, they'll never even guess that the block wasn't born in 1991.
RACE ON!!!
Old Feb 13, 2006 | 11:48 AM
Pete K's Avatar
Pete K
Old Feb 14, 2006 | 12:52 AM
Performance nut
RACE ON!!!
No, the average joe blow smog inspector wouldnt know the difference between an L98 block and Dart Iron Eagle block. Those guys arent the ones that concern me. Its the smog referree that will most likely check. Granted, it isnt the easiest thing to check for on my car (hence why I asked before ripping things off to find it) but it is a law in California. Better safe than sorry.
Thanks Pete K, I appreciate it.
Old Feb 14, 2006 | 09:27 AM
Pete K's Avatar
Pete K
No problem. I just so happen to have my oem 87 block and an 89 vette block in the garage. Both have the same casting number. The 95 truck block and the 89 truck blocks I have also share that number. Looks to be quite common.
Old Feb 14, 2006 | 06:04 PM
Performance nut
Yeah, I researched it on the net and kept getting conflicting data... it was the 2 bolt block for the Camaro, block for trucks (forgot what years), and a 4 bolt block for the vette. Once I got your number, I found that it was all the same block.
According to Sallee Chevrolet, the block is only rated for 350HP...
To Block check
