Engine Experts - Help Needed Please
Old Jan 28, 2004 | 10:05 PM
edwards's Avatar
edwards
Default Engine Experts - Help Needed Please
A friend of mine has the following car. It's an 87 chassis with a 96 vert body. Fully tubbed, custom dash in interior with full cage.
Here's the engine:
Yes, it has NOS, a 500 shot.
When he originally bought the car, he was under the impression it was a 454 block. He's having some problems, and thinks that the engine is not what he thought.
Question is, how can he determine, without completely dismantling the bottom end, what size block it is. Are there numbers on it that would tell us? Second, can you measure bore and stroke by just removing the heads and measuring the cylinder and piston travel, to determine cubic inches?
Lastly, is there anyone in the Dallas/Ft. Worth area that really knows engines that can help us out?
Old Jan 29, 2004 | 11:02 AM
CFI-EFI's Avatar
CFI-EFI
Default Re: Engine Experts - Help Needed Please (edwards)
If it is a Mark IV big block, 454s and 427s used the same 4.250" bore blocks. Numbers won't help with the current cubic inch size. Could there possibly be a BETTER way to determine the cid, than measuring the bore and stroke? What is a guy that doesn't know THAT, doing with a car like THIS? Wish him my BEST of luck, and...
RACE ON!!!
Old Jan 29, 2004 | 03:04 PM
edwards's Avatar
edwards
Default Re: Engine Experts - Help Needed Please (CFI-EFI)
He saw this car built several years ago while living in Oregon. He tracked the car to it's second owner when he heard it was for sale. He knows what was in it originally, and the second owner "says" they didn't change anything.
He's now having some issues in the heads/manifold area, and wants to replace all that, but needs to be sure of the bottom end, before he can make a final determination and truly maximize the engine.
Old Jan 29, 2004 | 06:41 PM
CFI-EFI's Avatar
CFI-EFI
He, most of all, should know that the bore and stroke DEFINE the cubic inch size of an engine.
That, aside, what kind of "issues" is he having?
To Engine Experts - Help Needed Please
