Hyd Roller to Solid Roller
Old Dec 13, 2004 | 01:50 AM
Simmo's Avatar
Simmo
Default Hyd Roller to Solid Roller
Is there much gain to be had going from a hyd roller to a solid roller?
Presently have 454 12/1 rec port heads and 238/244 @112 hyd roller. Thinking of a solid roller say 245/250 or there abouts. Its a lot of expense so Id want to believe there is a bit to gain.
Old Dec 13, 2004 | 10:44 AM
comp's Avatar
comp
what kind of RPM's you turning
Old Dec 13, 2004 | 05:56 PM
Simmo's Avatar
Simmo
Presently my low rise dual plane manifold is holding me back, power flattens off by only 5000rpm but when I get a single plane manifold, I'll set a max rpm of 6500, aiming for peak power close to 6000rpm.
Running factory steel crank and 7/16 dot rods on a purely weekend street car. M21 with 3.7 rear. A slightly bigger Hydraulic roller may be a simpler option.
Old Dec 14, 2004 | 10:21 AM
gkull's Avatar
gkull
You can run solid rollers on a HR cam. I'm doing it comp cams just told me to set the lash at .012
I would find out from the cam companies what the max rpm is for a BBC HR cam is for your larger duration. If they feel like your out of bounds the SR is the only way to go.
Old Dec 26, 2004 | 01:47 AM
cv67's Avatar
cv67
St. Jude Donor '05
With a SR you'll know you aren't losing anything up top (no lifter pump up). With a quality set of poly locks, you shouldn't need to adjust valves very often at all.
Old Dec 26, 2004 | 11:58 AM
gcrouse's Avatar
gcrouse
6000rpm is absolute max for any hydraulic lifter- unless you get something like the hydra-rev from AFR:
http://www.airflowresearch.com/pages/hydra_rev.htm
I'd say that's your best way to add those last 500rpms and not have the expense and constant adjusting of a solid roller...
Edit: aw crap they only list them for small blocks! But check around I'm sure there's other rev-kits available....
Old Dec 26, 2004 | 05:24 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
VETDRMS went from a hydro roller to solid, same cam as I have and he seemed pretty pleased, he shifts at 7000RPM's now
To Hyd Roller to Solid Roller
