Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
List your Dyno Numbers
Old Jul 26, 2009 | 01:26 AM
9secondflat's Avatar
9secondflat
532/472 LPE 383/ tfs 215/ fast 92/ vrx5 cam/ kooks 1 3/4 and a few other things...
vid of dyno pull
http://www.youtube.com/watch?v=KAB1H4F5pvs
Old Jul 26, 2009 | 02:05 AM
Blk Btty C5's Avatar
Blk Btty C5
Old Jul 26, 2009 | 02:27 AM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Scanner down will post graph when I fix it. 412.6RWHP 396.4RWTQ.
2001 MN6 AFE Stage II CAI, LG Pro Long Tubes, Ported Throttle body, no cats, Borla Stingers, MS3 Cam kit springs and push rods, and tuned with EFI Live. Stock 241 heads and LS6 Intake Manifold.
Old Jul 26, 2009 | 11:33 AM
Blk Btty C5
keep em comin'
Old Jul 26, 2009 | 11:34 AM
Blk Btty C5
vid of dyno pull
very very nice
Old Jul 26, 2009 | 12:25 PM
Blu's Avatar
Blu
457rwhp 408 rwtq
H/C/I 99 FRC
Old Jul 26, 2009 | 12:54 PM
98vettedave's Avatar
98vettedave
605rwhp 589rwtq SAE smoothing 5
383 H/C mild nitrous hit...see sig.
Old Jul 26, 2009 | 12:57 PM
Blk Btty C5
Old Jul 26, 2009 | 02:29 PM
csexton's Avatar
csexton
ECS installed Novi 2000, RPM Level V Tranny, 3:42 rear
500 RWHP/480.4 RWTQ
Chuck
Old Jul 26, 2009 | 02:52 PM
Blk Btty C5
500 RWHP/480.4 RWTQ
Chuck
Old Jul 26, 2009 | 03:51 PM
Kurtomac's Avatar
Kurtomac
wish everyone would post sae corrected numbers...i see some STD numbers...if we were allowed to play that game i would post my old dyno where i did 485rwhp uncorrected
Old Jul 26, 2009 | 05:04 PM
STL94LT1's Avatar
STL94LT1
01 Vert, LPE twin turbo.
Old Jul 26, 2009 | 06:28 PM
  #33
Blk Btty C5
Old Jul 26, 2009 | 08:09 PM
  #34
legman's Avatar
legman
Default here's mine.....
Old Jul 26, 2009 | 10:44 PM
  #35
MJD's Avatar
MJD
Ported stock heads
crane cam 222/228 .551/.551 115
1.8 ratio rockers
full exhaust and intake
tuned for E85
see sig for dyno
Old Jul 27, 2009 | 12:26 AM
  #36
sixspdvet's Avatar
sixspdvet
Besides std and sae I see smoothing set at 1 to 5... what's the difference with that number?
Old Jul 27, 2009 | 12:56 AM
  #37
intoc6s's Avatar
intoc6s
427 NA- Heads, Cam, etc. 2001 Coupe 6-speed Ported L92/L76(heads/intake), 252/264 .647 .647 -110* , 1 7/8" Kooks LTs/offroad X-pipe, cat-back(no mufflers), Underdrive pulley,Motorsport 30# Red Top Injectors, Ported LS2 TB. Since the dyno i added- Vararam w/Halltech airbridge, lightweight aluminum flywheel & clutch(and now its not slipping, like it is on the dynosheet Look @ 3600 rpms), Meziere Electric Water Pump,Taylor 10mm wires and i now use Full Synthetic oil, since the engine has 6500 miles on it.
538.8rwhp 499.65 Tq I ve made a few upgrades since this dyno, and fixed my clutch problem. Will re-dyno soon and have current #s.
Sorry for the crappy pic.
To List your Dyno Numbers
Old Jul 27, 2009 | 02:42 AM
  #38
TransAm2002's Avatar
TransAm2002
Stock short block 346 PRC 5.3 Heads/ MS3 Cam, Kooks 1 7/8 headers, Borla, Vararam
450 RWHP 402 RWTQ
on a 125 shot
572 RWHP 667 RWTQ It is a torque monster.
Old Jul 27, 2009 | 07:25 AM
  #39
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
Still trying to find my dyno sheet but my numbers were 460-400 NA and 570-570 on a 100 shot. Here are my mods:
Cartek Stage 4X heads. Includes, full porting heads intake, exhaust, and combustion
chamber, Manley sever duty stainless valves, 2.02 intake, 1.57 exhasut, seals, Manley dual springs, spring seats, seals, titanium retainers, milled .030, cleaned and assembled.
Custom grind Cartek Stage 2X Cam computer verified.
228-232 582-598 116LSA
Cromoly hardened push rods.
Cometic heavy duty head gaskets.
ASP under drive pulley with belts.
Roll master dual roller timing chain.
Z06 ported oil pump setup for the roll master.
FAST 3 piece intake manifold ported to 4X with a 90MM throttle opening.
Ported LS2 throttle body.
ECU Reprogram 97-2004 LS1 full dyno tune.
Notch piston for clearance.
Complete NX system installed includes, NX wet kit with 10# bottle, purge, MSD digital RPM window switch, timing retard module, custom switch panel with micro switches and LED lights, all wires, Bosch relays, and labor to install. Also includes, blow down tube, full throttle switch, Kenny Bell Boostapump, and NGK TR6 spark plugs.
Nano kit.
4.10 gears.
C5 passenger and driver side 300M output shaft with side gear.
C5 line lock kit includes pre-bent line with braided flex hose, inline line lock solenoid, and switch installed.
Vararam intake
Vararam Power duct
GM Racing spark plug wires
160* thermostat
New Coolant crossover
American Racing Headers (1 7/8 primaries 3" collector)
American Racing X pipe
Borla Stinger catback
Built tranny by Lethal Performance
Hurst short throw shifter
Spec III Clutch and Billet aluminum flywheel
Brand new Slave cylinder
Upgraded Tick Performance Master cylinder
Old Jul 27, 2009 | 07:39 AM
  #40
Blk Btty C5
awesome guys keep em comin
