Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
no reverse
Old Dec 7, 2011 | 07:08 AM
homeless's Avatar
homeless
Default no reverse
I went to the track to run the car. I got to make one pass it went a 1.77 60 ft 4.91 330 ft then when i went to 3rd gear the clutch stayed on the floor.It would not go in gear so i coasted across the line at 8.08 at 69 mph.Now the car does not want to go in reverse. Has any one had this problem.THANK for any input
Old Dec 7, 2011 | 09:22 AM
clemsondave's Avatar
clemsondave
Stock clutch? Stock master cylinder?
Old Dec 7, 2011 | 10:55 AM
PRE-Z06's Avatar
PRE-Z06
How does the fluid in the clutch master reservoir look?
Old Dec 7, 2011 | 01:08 PM
homeless's Avatar
homeless
stock clutch and master cylinder. Will go into every gear but very hard to get in reverse
Old Dec 7, 2011 | 01:09 PM
homeless's Avatar
homeless
Changed the fluid about 3 weeks ago when we put the cam in
Old Dec 7, 2011 | 01:31 PM
PRE-Z06's Avatar
PRE-Z06
How does it look now after the pass? Have you verified shifter alignment?
Old Dec 7, 2011 | 01:51 PM
homeless's Avatar
homeless
Fluid is a little dark, i have not checked nothing yet. THANKS for any input
Old Dec 7, 2011 | 02:20 PM
clemsondave
Two easy checks.
1. Shifter alignment like Pre-Z06 mentioned. However, if that was off and reverse didn't work, I suspect 6th gear would be difficult to get into as well.
2. Reverse lockout switch. It could have come unplugged. A little difficult to reach, but you can do it.
If it is neither of those, try a search in the Tech section.
Old Dec 7, 2011 | 02:55 PM
homeless's Avatar
homeless
Two easy checks.
THANKS i will check it
To no reverse
