Service Rear Axle message
I have just had error "Service Rear Axle" while on track and could not use PTM - car limped back to pits and no more caring that day.
I need to read computer to understand issues. Does anyone know how I can get hold of good quality deep scanning tool?
I live in Australia and there are "NO" Corvette dealers. My car is unsupported here in Australia.
I have a 2105 C7 Z06 A8.
Any help appreciated.
G'day mate!!
Sorry to hear of your problem, but it's not uncommon - and the fix may have nothing at all to do with the rear axle!!
My brother-in-law had the "Service Rear Axle" alert last year and I did a search here on the forum for what the problem may be - and I was surprised that most everybody that gets that message has an entirely different issue.
In many cases the Service Rear Axle message has turned out to be a problem with an injector or spark plug wire!!!
I told my b-in-law that, but he thought I was crazy that a Service Rear Axle alert meant an engine problem - but he had it towed to the dealer and they replaced a couple fuel injectors, and no more problem for many thousands of miles now.
Take a look at these threads - and do a search and you'll probably find a lot more relating the Service Rear Axle message to injector or spark plug problems:
https://www.corvetteforum.com/forums...ine-light.html
https://www.corvetteforum.com/forums...k-and-cel.html
https://www.corvetteforum.com/forums...r-problem.html
https://www.corvetteforum.com/forums...dy-please.html
Good luck finding the problem, but the past experience of forum members is that the Service Rear Axle message may indicate a problem in a totally unrelated area!!
i had to wait 2000 miles (as the approval process ensued) before they replaced the entire Rear Differential - they did not waste time with fluid changes, computer codes, nor anything else...they just simply replaced it - no issue since then (regarding Service Rear Axle) - 35,000 miles now - and only a stressed cracked windshield to deal with...thankfully warranty replacement approved
ICE enthusiast
I had a similar problem and it was a battery issue, changed the battery and never had it
s n v f f (08-31-2021)
G'day mate!!
I am just looking to see if we can read any codes to provide some direction. Very hard to chase all the various possible sources of the error. I am looking to get an OTC Encore Diagnostic Tool to see if we can isolate the cause.
Big problem for me - NO WARRANTY! Corvette not an approved import into Australia.
that happened to my 2015 - A8 - Z06 - back at 4500 miles - in addition to not being able to access PTM, the car would engage the brakes (StabilTrac light flashing) while entering the mildest of turns (extremely annoying) as it slowed you down
No warranty on this car so if a new diff is needed then I need to buy it and import to AUS. Not my preferred option!!
That would be a great outcome - not confident that will happen here.
Warranty not applicable in Australia - the car is unsupported right out of the box. Hard to find a tuner that can read all the codes, especially the driveline codes.
In Australia the car is called a black import and we have it converted from left hand drive to right hand side.
When the car is error free and not pulling timing due to temps she is great car but with errors and timing being pulled you might as well be driving a Prius!
i can understand that you have your hands full - just getting the car to Australia and thru customs had to be a chore unto itself - not even thinking about Left to Right Hand Drive !!
i've had my car since new (May 2015) and have had quite a few service visits...all issues resolved, but without my dealer, and their support from GM directly things would not be very smooth at all
i've had:
2 Flex Plates replaced
1 Torque Converter
1 Rear Differential
1 Windshield
none of this would be very easy without GM right there and ready to supply the parts - which usually arrived within the same week as my service visit (rear diff was longest wait at 5 days) - the repairs/replacements were pretty much 1 day affairs, maybe 2 for the first Flex Plate
doing any of this without GM support will be a test of your patience and intestinal fortitude - if you need help try the Customer Service Rep that is on the forums, specifically to help Chevrolet GM products
if i can help u anyway, PM me and i'll see if my dealer can get you a code definition
https://www.corvetteforum.com/forums...-cust-svc.html
i've had:
1 Torque Converter
1 Rear Differential
1 Windshield
jnvetteaus (06-08-2017)
Moderator
Received 3,623 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
Had the same thing last year. Z07 M7.
First they did a system reflash and update, problem came back. Had a dead battery next, loose cable was found. Once that was fixed, haven't seen the error since. Like others , when I researched found many different causes. Good luck
Received 1,817 Likes
What is happening to mine is the following:
1. When it gets hot out, around 85F. The first thing I notice is the diff is not locking correctly. It reacts slow to a wheels spinning in a corner and starts locking late.
2. When it gets a bit hotter or I have stopped driving for 20 min or so. Then the diff completely stops locking and runs as open diff with 0% on eLSD screen. No service rear axle message yet.
3. Next as it gets hotter outside, say 90F, the service parking brake light comes on followed by the "service rear axle" message. Once this happens I can't use PTM.
4. I keep driving and stop and restart then the "rear axle system off message" appears. At this point the eLSD screen you get dashes instead of 0%.
Fixed: New Alternator
It sounds like this message can be caused by a variety of issues in the electrical system. In my case, the problem was solved by a new alternator. The service manager explained that at mid to high RPM ranges it was generating too much voltage which tripped that message and several other codes. Replacing the alternator fixed the problem for me.
